    electron-rebuild and MagicMirror v2.18 (and more)
    40 Posts 16 Posters 30.2k Views 21 Watching
    • bugsounetB
      bugsounet Banned @lhops
      @lhops said in electron-rebuild and MagicMirror v2.18 (and more):
      npm ERR! JSON.parse “name”: "Magic-Mirror-Module-PIR-Sen’
      If you have modified the “package.json” file … and you do not respect the syntax.
      here is the result ;)
      (Info: it is not like this that we rename a module)
      to correct your issue try this:
      cd ~/MagicMirror/modules/MMM-PIR-Sensor
      rm -rf node_modules package-lock.json
      git reset --hard HEAD
      npm install magicmirror-rebuild --save
      npm remove electron-rebuild
      npm install
      (Sometime, i’m very kind… So kind for me)
      @bugsounet
      • L
        lhops @bugsounet
        @bugsounet
        That did the trick. How can I thank you. It is working like it should!!
        bugsounetB 1 Reply Last reply Reply Quote 0
        • bugsounetB
          I have open this PR (Pull Request) for commit this change with MagicMirror-rebuild to @paviro to accept it (or not)
            susl @bugsounet
            @bugsounet I followed your instructions but the rebuilding step failed with the following message:
            MagicMirror Building module: epoll, Completed: 0gyp: name ‘openssl_fips’ is not defined while evaluating condition ‘openssl_fips != “”’ in binding.gyp while trying to load binding.gyp
            ✖ MagicMirror Rebuild Failed
            An unhandled error occurred inside electron-rebuild
            node-gyp failed to rebuild ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll’.
            Error: gyp failed with exit code: 1
            Error: node-gyp failed to rebuild ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll’.
            at ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/module-rebuilder.js:193:19)
            at processTicksAndRejections (node:internal/process/task_queues:96:5)
            at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:180:9)
            at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:143:17)
            at async /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:141:9
            Do you know what the problem is? Thanks!
            • bugsounetB
              bugsounet Banned @susl
              @susl :
              • Recommended version of npm: v6.14.15
              • Recommended version of node: v14.x.x or v16.x.x
              to verify, try this in a terminal (or ssh):
              node -v
              npm -v
                susl @bugsounet
                @bugsounet
                node version: v17.3.0
                npm version: 8.3.0
                So obviously not the correct version :-( Do you know how I can change the versions?
                  sdetweil @susl
                  @susl you can use n to install or select different versions of node (and npm)
                  to install n
                  sudo npm install n -g
                  then to install or use a version of node
                  n 16
                  to switch
                  n
                  the select from the list
                    susl @sdetweil
                    Thanks a lot. I works now!
                    • cowboysdudeC
                      @bugsounet Thank you for this!! It works like a charm ;)
                        selyjohns
                        Wow, perfect ! Thank you so much !
                        • michael5rM
                          michael5r Module Developer
                          Thanks for doing this - much appreciated!
                          • bugsounetB
                            bugsounet Banned @michael5r
                            @michael5r with pleasure ;l
                              selyjohns
                              Hi @bugsounet
                              Same problem after update to 2.19 :(
                              During the update, i needed to force because a log say the package-lock.json has been modified. Maybe my error.
                              Trying to reproduce the procedure, but
                              pi@MagicMirror:~/MagicMirror/modules/MMM-PIR-Sensor $ ./node_modules/.bin/MagicMirror-rebuild
                              ⠋ Searching dependency tree
                              Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                              Error: Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                                  at Object.getAbi (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:39:9)
                                  at new Rebuilder (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:100:48)
                                  at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:249:23)
                                  at doRebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:272:16)
                                  at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:115:45
                              Did you know how to solve this ?
                              bugsounetB T 2 Replies Last reply Reply Quote 0
                              • bugsounetB
                                bugsounet Banned @selyjohns
                                @selyjohns
                                MMM-PIR-Sensor state is :
                                This repository has been archived by the owner. It is now read-only.
                                I will not doing a patch on every update for this @paviro module
                                Just use another maintened pir module
                                  selyjohns
                                  @bugsounet said in electron-rebuild and MagicMirror v2.18 (and more):
                                  Thank you for this quick reply.
                                  I see, so no solution for this update…Any idea of equivalent module to replace MMM-PIR-Sensor ?
                                  • bugsounetB
                                    @selyjohns I done NO ads in this forum, sorry
                                    • S selyjohns referenced this topic on
                                    • T
                                      tanvir586 @selyjohns
                                      @selyjohns
                                      hi can you try
                                      Cd MagicMirror/modules/MMM-PIR-Sensor
                                      And then
                                      npm i magicmirror-rebuild
                                      Then
                                      It might work.
                                        sdetweil @tanvir586
                                        @tanvir586 see
                                        https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/25?_=1648232499740
                                          selyjohns @sdetweil
                                          @sdetweil @tanvir586
                                          Yes…Already tested. No fonctionnal
                                            sdetweil @selyjohns
                                            @selyjohns correct.
                                            the author of the magicmirror rebuild tool said he will not fix it for this module.
                                            as the module is in archived status
                                            wishmaster270W 1 Reply Last reply Reply Quote 1
