    electron-rebuild and MagicMirror v2.18 (and more)
    40 Posts 16 Posters 29.3k Views 21 Watching
    • bugsounetB Offline
      bugsounet Banned @lhops
      I have open this PR (Pull Request) for commit this change with MagicMirror-rebuild to @paviro to accept it (or not)
        susl @bugsounet
        @bugsounet I followed your instructions but the rebuilding step failed with the following message:
        MagicMirror Building module: epoll, Completed: 0gyp: name ‘openssl_fips’ is not defined while evaluating condition ‘openssl_fips != “”’ in binding.gyp while trying to load binding.gyp
        ✖ MagicMirror Rebuild Failed
        An unhandled error occurred inside electron-rebuild
        node-gyp failed to rebuild ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll’.
        Error: gyp failed with exit code: 1
        Error: node-gyp failed to rebuild ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll’.
        at ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/module-rebuilder.js:193:19)
        at processTicksAndRejections (node:internal/process/task_queues:96:5)
        at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:180:9)
        at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:143:17)
        at async /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:141:9
        Do you know what the problem is? Thanks!
        bugsounetB 1 Reply Last reply Reply Quote 0
          bugsounet Banned @susl
          @susl :
          • Recommended version of npm: v6.14.15
          • Recommended version of node: v14.x.x or v16.x.x
          to verify, try this in a terminal (or ssh):
          node -v
          npm -v
            susl @bugsounet
            @bugsounet
            node version: v17.3.0
            npm version: 8.3.0
            So obviously not the correct version :-( Do you know how I can change the versions?
              sdetweil @susl
              @susl you can use n to install or select different versions of node (and npm)
              to install n
              sudo npm install n -g
              then to install or use a version of node
              n 16
              to switch
              n
              the select from the list
                susl @sdetweil
                Thanks a lot. I works now!
                • cowboysdudeC Offline
                  @bugsounet Thank you for this!! It works like a charm ;)
                    selyjohns
                    Wow, perfect ! Thank you so much !
                    • michael5rM Offline
                      michael5r Module Developer
                      Thanks for doing this - much appreciated!
                        bugsounet Banned @michael5r
                        @michael5r with pleasure ;l
                          selyjohns
                          Hi @bugsounet
                          Same problem after update to 2.19 :(
                          During the update, i needed to force because a log say the package-lock.json has been modified. Maybe my error.
                          Trying to reproduce the procedure, but
                          pi@MagicMirror:~/MagicMirror/modules/MMM-PIR-Sensor $ ./node_modules/.bin/MagicMirror-rebuild
                          ⠋ Searching dependency tree
                          Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                          Error: Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                              at Object.getAbi (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:39:9)
                              at new Rebuilder (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:100:48)
                              at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:249:23)
                              at doRebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:272:16)
                              at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:115:45
                          Did you know how to solve this ?
                          bugsounetB T 2 Replies Last reply Reply Quote 0
                            bugsounet Banned @selyjohns
                            @selyjohns
                            MMM-PIR-Sensor state is :
                            This repository has been archived by the owner. It is now read-only.
                            I will not doing a patch on every update for this @paviro module
                            Just use another maintened pir module
                              selyjohns
                              @bugsounet said in electron-rebuild and MagicMirror v2.18 (and more):
                              Thank you for this quick reply.
                              I see, so no solution for this update…Any idea of equivalent module to replace MMM-PIR-Sensor ?
                                @selyjohns I done NO ads in this forum, sorry
                                • S selyjohns referenced this topic on
                                • T Offline
                                  tanvir586 @selyjohns
                                  @selyjohns
                                  hi can you try
                                  Cd MagicMirror/modules/MMM-PIR-Sensor
                                  And then
                                  npm i magicmirror-rebuild
                                  Then
                                  It might work.
                                    sdetweil @tanvir586
                                    @tanvir586 see
                                    https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/25?_=1648232499740
                                      selyjohns @sdetweil
                                      @sdetweil @tanvir586
                                      Yes…Already tested. No fonctionnal
                                        sdetweil @selyjohns
                                        @selyjohns correct.
                                        the author of the magicmirror rebuild tool said he will not fix it for this module.
                                        as the module is in archived status
                                        wishmaster270W 1 Reply Last reply Reply Quote 1
                                        • wishmaster270W Offline
                                          wishmaster270 Module Developer @sdetweil
                                          I generally suggest the same as bugsoutnet…The best way would be to use one of the other PIR modules.
                                          But i also found an solution which worked in my setup. I used the sdetweil script to install the current version of MagicMirror.
                                          In the module directory of MMM-PIR-Sensor you need to delete package-lock.json and the node_modules folder:
                                          rm -rf ~/MagicMirror/modules/MMM-PIR-Sensor/node_modules
                                          rm -rf ~/MagicMirror/modules/MMM-PIR-Sensor/package-lock.json
                                          Then you need to replace the whole content of package.json file with the following one that uses the MagicMirror-rebuild library of bugsounet…
                                            "name": "Magic-Mirror-Module-PIR-Sensor",
                                            "version": "1.1.0",
                                            "description": "PIR motion sensor module for the Magic Mirror.",
                                            "repository": {
                                              "type": "git",
                                              "url": "git+https://github.com/paviro/MMM-PIR-Sensor"
                                            "keywords": [
                                              "magic mirror",
                                              "smart mirror",
                                              "PIR-Sensor",
                                              "module",
                                              "motion"
                                            "author": "Paul-Vincent Roll",
                                            "contributors": "https://github.com/paviro/MMM-PIR-Sensor/graphs/contributors",
                                            "license": "MIT",
                                            "bugs": {
                                              "url": "https://github.com/paviro/MMM-PIR-Sensor/issues"
                                            "homepage": "https://github.com/paviro/MMM-PIR-Sensor#readme",
                                            "scripts": {
                                          	  "postinstall": "node_modules/.bin/MagicMirror-rebuild"
                                            "dependencies": {
                                              "onoff": "latest",
                                              "magicmirror-rebuild": "latest"
                                          Then you need to run npm install
                                          npm install
                                            sdetweil @wishmaster270
                                            @wishmaster270 did u try the upgrade script?
                                            it does delete both file and folder and then npm install
