    electron-rebuild and MagicMirror v2.18 (and more)
    40 Posts 16 Posters 30.2k Views 21 Watching
      susl @sdetweil
      Thanks a lot. I works now!
      • cowboysdudeC
        @bugsounet Thank you for this!! It works like a charm ;)
          selyjohns
          Wow, perfect ! Thank you so much !
          • michael5rM
            michael5r Module Developer
            Thanks for doing this - much appreciated!
            bugsounetB 1 Reply Last reply Reply Quote 0
            • bugsounetB
              bugsounet Banned @michael5r
              @michael5r with pleasure ;l
                selyjohns
                Hi @bugsounet
                Same problem after update to 2.19 :(
                During the update, i needed to force because a log say the package-lock.json has been modified. Maybe my error.
                Trying to reproduce the procedure, but
                pi@MagicMirror:~/MagicMirror/modules/MMM-PIR-Sensor $ ./node_modules/.bin/MagicMirror-rebuild
                ⠋ Searching dependency tree
                An unhandled error occurred inside electron-rebuild
                Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                Error: Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                    at Object.getAbi (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:39:9)
                    at new Rebuilder (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:100:48)
                    at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:249:23)
                    at doRebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:272:16)
                    at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:115:45
                Did you know how to solve this ?
                bugsounetB T 2 Replies Last reply Reply Quote 0
                • bugsounetB
                  bugsounet Banned @selyjohns
                  @selyjohns
                  MMM-PIR-Sensor state is :
                  This repository has been archived by the owner. It is now read-only.
                  I will not doing a patch on every update for this @paviro module
                  Just use another maintened pir module
                    selyjohns
                    @bugsounet said in electron-rebuild and MagicMirror v2.18 (and more):
                    Thank you for this quick reply.
                    I see, so no solution for this update…Any idea of equivalent module to replace MMM-PIR-Sensor ?
                    • bugsounetB
                      @selyjohns I done NO ads in this forum, sorry
                      • S selyjohns referenced this topic on
                      • T
                        tanvir586 @selyjohns
                        @selyjohns
                        hi can you try
                        Cd MagicMirror/modules/MMM-PIR-Sensor
                        And then
                        npm i magicmirror-rebuild
                        Then
                        It might work.
                          sdetweil @tanvir586
                          @tanvir586 see
                          https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/25?_=1648232499740
                            selyjohns @sdetweil
                            @sdetweil @tanvir586
                            Yes…Already tested. No fonctionnal
                              sdetweil @selyjohns
                              @selyjohns correct.
                              the author of the magicmirror rebuild tool said he will not fix it for this module.
                              as the module is in archived status
                              wishmaster270W 1 Reply Last reply Reply Quote 1
                              • wishmaster270W
                                wishmaster270 Module Developer @sdetweil
                                I generally suggest the same as bugsoutnet…The best way would be to use one of the other PIR modules.
                                But i also found an solution which worked in my setup. I used the sdetweil script to install the current version of MagicMirror.
                                In the module directory of MMM-PIR-Sensor you need to delete package-lock.json and the node_modules folder:
                                rm -rf ~/MagicMirror/modules/MMM-PIR-Sensor/node_modules
                                rm -rf ~/MagicMirror/modules/MMM-PIR-Sensor/package-lock.json
                                Then you need to replace the whole content of package.json file with the following one that uses the MagicMirror-rebuild library of bugsounet…
                                  "name": "Magic-Mirror-Module-PIR-Sensor",
                                  "version": "1.1.0",
                                  "description": "PIR motion sensor module for the Magic Mirror.",
                                  "repository": {
                                    "type": "git",
                                    "url": "git+https://github.com/paviro/MMM-PIR-Sensor"
                                  "keywords": [
                                    "magic mirror",
                                    "smart mirror",
                                    "PIR-Sensor",
                                    "module",
                                    "motion"
                                  "author": "Paul-Vincent Roll",
                                  "contributors": "https://github.com/paviro/MMM-PIR-Sensor/graphs/contributors",
                                  "license": "MIT",
                                  "bugs": {
                                    "url": "https://github.com/paviro/MMM-PIR-Sensor/issues"
                                  "homepage": "https://github.com/paviro/MMM-PIR-Sensor#readme",
                                  "scripts": {
                                	  "postinstall": "node_modules/.bin/MagicMirror-rebuild"
                                  "dependencies": {
                                    "onoff": "latest",
                                    "magicmirror-rebuild": "latest"
                                Then you need to run npm install
                                npm install
                                  sdetweil @wishmaster270
                                  @wishmaster270 did u try the upgrade script?
                                  it does delete both file and folder and then npm install
                                  • wishmaster270W
                                    @sdetweil Hi, i did a fresh install and added the module manually. I do not use MMM-PIR-Sensor but some other users had the same problem with MMM-Gestures (which i do not use either). Did a clean install of MagicMirror on a development Pi with your script and added modules manually.
                                    • karsten13K karsten13 referenced this topic on
                                    • O OliWer referenced this topic on
                                      Rags
                                      Awesome. It really works. I had the same issue and it was really frustrating, until i stumbled upon this solution. Great my PIR-sensor module was revived. I just followed the steps mentioned and voila…it has come back to life. Thanks a ton, it is selfless gentlemen like yourself who keep this world going. Kudos.
                                      • T torte22 referenced this topic on
                                        Dresch360 Project Sponsor
                                        Hoping someone can help. Having the same issue with MMM-Reddit since updating to MM v2.20.0 . Spent a couple days scouring this as well as other forums for a fix. I already tried everything from this thread. Still getting the error below, no matter what I try. Any help would be greatly appreciated.
                                        • MM v2.20.0
                                        • Node v16.17.1
                                          -Node-gyp v9.2.0
                                          -NPM v8.15.0
                                        This is the code I get for any rebuild or npm install…etc:
                                        npm ERR! code 1
                                        npm ERR! path /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass
                                        npm ERR! command failed
                                        npm ERR! command sh /tmp/postinstall-fdc6f405.sh
                                        npm ERR! Building: /usr/bin/node /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js rebuild --verbose --libsass_ext= --libsass_cflags= --libsass_ldflags= --libsass_library=
                                        npm ERR! gyp info it worked if it ends with ok
                                        npm ERR! gyp verb cli [
                                        npm ERR! gyp verb cli ‘/usr/bin/node’,
                                        npm ERR! gyp verb cli ‘/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js’,
                                        npm ERR! gyp verb cli ‘rebuild’,
                                        npm ERR! gyp verb cli ‘–verbose’,
                                        npm ERR! gyp verb cli ‘–libsass_ext=’,
                                        npm ERR! gyp verb cli ‘–libsass_cflags=’,
                                        npm ERR! gyp verb cli ‘–libsass_ldflags=’,
                                        npm ERR! gyp verb cli ‘–libsass_library=’
                                        npm ERR! gyp verb cli ]
                                        npm ERR! gyp info using node-gyp@3.8.0
                                        npm ERR! gyp info using node@16.17.1 | linux | arm
                                        npm ERR! gyp verb command rebuild []
                                        npm ERR! gyp verb command clean []
                                        npm ERR! gyp verb clean removing “build” directory
                                        npm ERR! gyp verb command configure []
                                        npm ERR! gyp verb check python checking for Python executable “python2” in the PATH
                                        npm ERR! gyp verb which failed Error: not found: python2
                                        npm ERR! gyp verb which failed at getNotFoundError (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:13:12)
                                        npm ERR! gyp verb which failed at F (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:68:19)
                                        npm ERR! gyp verb which failed at E (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:80:29)
                                        npm ERR! gyp verb which failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:89:16
                                        npm ERR! gyp verb which failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/isexe/index.js:42:5
                                        npm ERR! gyp verb which failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/isexe/mode.js:8:5
                                        npm ERR! gyp verb which failed at FSReqCallback.oncomplete (node:fs:206:21)
                                        npm ERR! gyp verb which failed python2 Error: not found: python2
                                        npm ERR! gyp verb which failed at FSReqCallback.oncomplete (node:fs:206:21) {
                                        npm ERR! gyp verb which failed code: ‘ENOENT’
                                        npm ERR! gyp verb which failed }
                                        npm ERR! gyp verb check python checking for Python executable “python” in the PATH
                                        npm ERR! gyp verb which succeeded python /usr/bin/python
                                        npm ERR! gyp ERR! configure error
                                        npm ERR! gyp ERR! stack Error: Command failed: /usr/bin/python -c import sys; print “%s.%s.%s” % sys.version_info[:3];
                                        npm ERR! gyp ERR! stack File “”, line 1
                                        npm ERR! gyp ERR! stack import sys; print “%s.%s.%s” % sys.version_info[:3];
                                        npm ERR! gyp ERR! stack ^
                                        npm ERR! gyp ERR! stack SyntaxError: invalid syntax
                                        npm ERR! gyp ERR! stack at ChildProcess.exithandler (node:child_process:400:12)
                                        npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
                                        npm ERR! gyp ERR! stack at maybeClose (node:internal/child_process:1093:16)
                                        npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
                                        npm ERR! gyp ERR! System Linux 5.15.61-v7l+
                                        npm ERR! gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js” “rebuild” “–verbose” “–libsass_ext=” “–libsass_cflags=” “–libsass_ldflags=” “–libsass_library=”
                                        npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass
                                        npm ERR! gyp ERR! node -v v16.17.1
                                        npm ERR! gyp ERR! node-gyp -v v3.8.0
                                        npm ERR! gyp ERR! not ok
                                        npm ERR! Build failed with error code: 1
                                        npm ERR! /home/pi/.npm/_logs/2022-10-07T02_52_13_196Z-debug-0.log
                                          sdetweil @Dresch360
                                          @Dresch360 said in electron-rebuild and MagicMirror v2.18 (and more):
                                          looks like u don’t have python version 2 installed
                                          do python -v
                                            Dresch360 Project Sponsor @sdetweil
                                            @sdetweil Thanks Sam! Ughh…I feel pretty silly that I didn’t realize that. Was looking at the least obvious issue. Works perfectly after installing Python 2. Thanks again!
