    electron-rebuild and MagicMirror v2.18 (and more)
    40 Posts 16 Posters 29.7k Views 21 Watching
      selyjohns
      @bugsounet said in electron-rebuild and MagicMirror v2.18 (and more):
      MMM-PIR-Sensor state is :
      This repository has been archived by the owner. It is now read-only.
      I will not doing a patch on every update for this @paviro module
      Just use another maintened pir module
      Thank you for this quick reply.
      I see, so no solution for this update…Any idea of equivalent module to replace MMM-PIR-Sensor ?
      bugsounetB 1 Reply Last reply Reply Quote 0
      • bugsounetB Offline
        bugsounet Banned @selyjohns
        @selyjohns I done NO ads in this forum, sorry
        • S selyjohns referenced this topic on
        • T Offline
          tanvir586 @selyjohns
          @selyjohns
          hi can you try
          Cd MagicMirror/modules/MMM-PIR-Sensor
          And then
          npm i magicmirror-rebuild
          Then
          ./node_modules/.bin/MagicMirror-rebuild
          It might work.
            sdetweil @tanvir586
            @tanvir586 see
            https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/25?_=1648232499740
              selyjohns @sdetweil
              @sdetweil @tanvir586
              Yes…Already tested. No fonctionnal
                sdetweil @selyjohns
                @selyjohns correct.
                the author of the magicmirror rebuild tool said he will not fix it for this module.
                as the module is in archived status
                wishmaster270W 1 Reply Last reply Reply Quote 1
                • wishmaster270W Offline
                  wishmaster270 Module Developer @sdetweil
                  I generally suggest the same as bugsoutnet…The best way would be to use one of the other PIR modules.
                  But i also found an solution which worked in my setup. I used the sdetweil script to install the current version of MagicMirror.
                  In the module directory of MMM-PIR-Sensor you need to delete package-lock.json and the node_modules folder:
                  rm -rf ~/MagicMirror/modules/MMM-PIR-Sensor/node_modules
                  rm -rf ~/MagicMirror/modules/MMM-PIR-Sensor/package-lock.json
                  Then you need to replace the whole content of package.json file with the following one that uses the MagicMirror-rebuild library of bugsounet…
                    "name": "Magic-Mirror-Module-PIR-Sensor",
                    "version": "1.1.0",
                    "description": "PIR motion sensor module for the Magic Mirror.",
                    "repository": {
                      "type": "git",
                      "url": "git+https://github.com/paviro/MMM-PIR-Sensor"
                    "keywords": [
                      "magic mirror",
                      "smart mirror",
                      "PIR-Sensor",
                      "module",
                      "motion"
                    "author": "Paul-Vincent Roll",
                    "contributors": "https://github.com/paviro/MMM-PIR-Sensor/graphs/contributors",
                    "license": "MIT",
                    "bugs": {
                      "url": "https://github.com/paviro/MMM-PIR-Sensor/issues"
                    "homepage": "https://github.com/paviro/MMM-PIR-Sensor#readme",
                    "scripts": {
                  	  "postinstall": "node_modules/.bin/MagicMirror-rebuild"
                    "dependencies": {
                      "onoff": "latest",
                      "magicmirror-rebuild": "latest"
                  Then you need to run npm install
                  npm install
                    sdetweil @wishmaster270
                    @wishmaster270 did u try the upgrade script?
                    it does delete both file and folder and then npm install
                      @sdetweil Hi, i did a fresh install and added the module manually. I do not use MMM-PIR-Sensor but some other users had the same problem with MMM-Gestures (which i do not use either). Did a clean install of MagicMirror on a development Pi with your script and added modules manually.
                      • karsten13K karsten13 referenced this topic on
                      • O OliWer referenced this topic on
                        Rags
                        Awesome. It really works. I had the same issue and it was really frustrating, until i stumbled upon this solution. Great my PIR-sensor module was revived. I just followed the steps mentioned and voila…it has come back to life. Thanks a ton, it is selfless gentlemen like yourself who keep this world going. Kudos.
                        • T torte22 referenced this topic on
                          Dresch360 Project Sponsor
                          Hoping someone can help. Having the same issue with MMM-Reddit since updating to MM v2.20.0 . Spent a couple days scouring this as well as other forums for a fix. I already tried everything from this thread. Still getting the error below, no matter what I try. Any help would be greatly appreciated.
                          • MM v2.20.0
                          • Node v16.17.1
                            -Node-gyp v9.2.0
                            -NPM v8.15.0
                          This is the code I get for any rebuild or npm install…etc:
                          npm ERR! code 1
                          npm ERR! path /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass
                          npm ERR! command failed
                          npm ERR! command sh /tmp/postinstall-fdc6f405.sh
                          npm ERR! Building: /usr/bin/node /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js rebuild --verbose --libsass_ext= --libsass_cflags= --libsass_ldflags= --libsass_library=
                          npm ERR! gyp info it worked if it ends with ok
                          npm ERR! gyp verb cli [
                          npm ERR! gyp verb cli ‘/usr/bin/node’,
                          npm ERR! gyp verb cli ‘/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js’,
                          npm ERR! gyp verb cli ‘rebuild’,
                          npm ERR! gyp verb cli ‘–verbose’,
                          npm ERR! gyp verb cli ‘–libsass_ext=’,
                          npm ERR! gyp verb cli ‘–libsass_cflags=’,
                          npm ERR! gyp verb cli ‘–libsass_ldflags=’,
                          npm ERR! gyp verb cli ‘–libsass_library=’
                          npm ERR! gyp verb cli ]
                          npm ERR! gyp info using node-gyp@3.8.0
                          npm ERR! gyp info using node@16.17.1 | linux | arm
                          npm ERR! gyp verb command rebuild []
                          npm ERR! gyp verb command clean []
                          npm ERR! gyp verb clean removing “build” directory
                          npm ERR! gyp verb command configure []
                          npm ERR! gyp verb check python checking for Python executable “python2” in the PATH
                          npm ERR! gyp verb which failed Error: not found: python2
                          npm ERR! gyp verb which failed at getNotFoundError (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:13:12)
                          npm ERR! gyp verb which failed at F (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:68:19)
                          npm ERR! gyp verb which failed at E (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:80:29)
                          npm ERR! gyp verb which failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:89:16
                          npm ERR! gyp verb which failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/isexe/index.js:42:5
                          npm ERR! gyp verb which failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/isexe/mode.js:8:5
                          npm ERR! gyp verb which failed at FSReqCallback.oncomplete (node:fs:206:21)
                          npm ERR! gyp verb which failed python2 Error: not found: python2
                          npm ERR! gyp verb which failed at FSReqCallback.oncomplete (node:fs:206:21) {
                          npm ERR! gyp verb which failed code: ‘ENOENT’
                          npm ERR! gyp verb which failed }
                          npm ERR! gyp verb check python checking for Python executable “python” in the PATH
                          npm ERR! gyp verb which succeeded python /usr/bin/python
                          npm ERR! gyp ERR! configure error
                          npm ERR! gyp ERR! stack Error: Command failed: /usr/bin/python -c import sys; print “%s.%s.%s” % sys.version_info[:3];
                          npm ERR! gyp ERR! stack File “”, line 1
                          npm ERR! gyp ERR! stack import sys; print “%s.%s.%s” % sys.version_info[:3];
                          npm ERR! gyp ERR! stack ^
                          npm ERR! gyp ERR! stack SyntaxError: invalid syntax
                          npm ERR! gyp ERR! stack at ChildProcess.exithandler (node:child_process:400:12)
                          npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
                          npm ERR! gyp ERR! stack at maybeClose (node:internal/child_process:1093:16)
                          npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
                          npm ERR! gyp ERR! System Linux 5.15.61-v7l+
                          npm ERR! gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js” “rebuild” “–verbose” “–libsass_ext=” “–libsass_cflags=” “–libsass_ldflags=” “–libsass_library=”
                          npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass
                          npm ERR! gyp ERR! node -v v16.17.1
                          npm ERR! gyp ERR! node-gyp -v v3.8.0
                          npm ERR! gyp ERR! not ok
                          npm ERR! Build failed with error code: 1
                          npm ERR! /home/pi/.npm/_logs/2022-10-07T02_52_13_196Z-debug-0.log
                            sdetweil @Dresch360
                            @Dresch360 said in electron-rebuild and MagicMirror v2.18 (and more):
                            looks like u don’t have python version 2 installed
                            do python -v
                              Dresch360 Project Sponsor @sdetweil
                              @sdetweil Thanks Sam! Ughh…I feel pretty silly that I didn’t realize that. Was looking at the least obvious issue. Works perfectly after installing Python 2. Thanks again!
                              • LusbuebL Offline
                                Lusbueb @bugsounet
                                Thank you very much :-)
                                it works for me with another module “MMM-Buttons”, I’m so happy!
                                do you have to run npm i magicmirror-rebuild every time in each module folder?
                                  MMRIZE @Lusbueb
                                  @Lusbueb
                                  Usually, No.
                                  Only the magic mirror module which use “native node module” needs it. but it would be hard to distinguish by a normal user.
                                  • LusbuebL Lusbueb referenced this topic on
