    MMM-RAIN-MAP (new: version 2.x)
    192 Posts 38 Posters 269.7k Views 41 Watching
    • JalibuJ Offline
      Jalibu Module Developer @gabrielm9
      Hi @gabrielm9 ,
      contribution is always welcome :-)
      You have to compile the Typescript sources using npm run build.
      Let me know, if you have problems. I‘m waiting for your PR
      • JalibuJ Offline
        Hi @gabrielm9,
        the latest version 2.5.x supports different color schemes now.
        swvalentiS G 2 Replies Last reply Reply Quote 0
        • swvalentiS Offline
          swvalenti Project Sponsor @Jalibu
          Outstanding work fellas
          • G Offline
            gabrielm9 Project Sponsor @Jalibu
            Hi @jalibu,
            Thanks very much! I was about to spend time figuring it out how to variabalize the code but I’ve learned from what you did. I would have taken me a week to figure it out :slightly_smiling_face:. The wife thanks you as well.
            • F Offline
              fmarcu @bhepler
              @bhepler
              osmMapUrl: "https://cartodb-basemaps-{s}.global.ssl.fastly.net/dark_all/{z}/{x}/{y}.png"
              I’m using the dark map referenced above on a black background but every time the module changes zoom level it fills with a white background until the new map tiles populate. It’s worst when zooming out,
              Does anyone know if it there is a parameter I can change so the blank tiles between zoom levels stay black?
              This is a minor annoyance with an otherwise great module.
              Thank you!
              JalibuJ 1 Reply Last reply Reply Quote 0
              • JalibuJ Offline
                Jalibu Module Developer @fmarcu
                @fmarcu said in MMM-RAIN-MAP (new: version 2.x):
                try to add this to your custom.css
                .MMM-RAIN-MAP .leaflet-container {
                  background: #000;
                F karsten13K 2 Replies Last reply Reply Quote 0
                • F Offline
                  fmarcu @Jalibu
                  @jalibu said in MMM-RAIN-MAP (new: version 2.x):
                    background: #000;
                  That worked! Thank you!
                  • karsten13K Offline
                    karsten13 @Jalibu
                    @jalibu
                    this is the current rain situation and I don’t understand the differences, first picture your module, second one https://www.wetteronline.de/regenradar .
                    And the second one is reality …
                    • JalibuJ Offline
                      Jalibu Module Developer @karsten13
                      @karsten13 Unfortunately, I can’t tell you that. I am only responsible for the display layer, not for the weather data :-)
                      The radar layers come from the Rainviewer API, which I have actually had quite good experiences with in the past.
                      Is it the usual case on your mirror that the displayed radar images do not match the reality?
                      What I can see is that RegenRadar.de and RainViewer have different scales. With RainViewer it needs a much higher degree of cloudiness to be displayed on the map.
                        karsten13 @Jalibu
                        @jalibu
                        Unfortunately, I can’t tell you that. I am only responsible for the display layer, not for the weather data 🙂
                        I’m aware of this …
                        saw such differences this week the first time
                        will oberve this but the differences are heavy and AFAIS not only explainable with the different scales. Meanwhile I was already asking myself if the rain layer is showing a total different location …
                        JalibuJ 1 Reply Last reply Reply Quote 1
                        • 13
                        • 14
                        • 15
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 15 / 20
