    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 309.3k Views 42 Watching
    • G Offline
      gabrielm9 Project Sponsor @lishmalinyjames
      Thanks @Jalibu for a fantastic module!
      Last year I modified the v1 code to change the color of the radar images to RainViewer color 4. My wife associates blue with snow, not rain, hence the preference for the Weather Channel scheme.
      I accomplished this by modifying 2 instances of the URL in utils.js, consistent with the API documentation. Where I found “/256/{z}/{x}/{y}/2/1_1.png” in the code, I simply changed it to “/256/{z}/{x}/{y}/4/1_1.png”, with the 4 being the preferred radar color.
      I’m unable to do the same in version 2.x. I found the URL in Client.ts, but modifying it had no effect on the output.
      I’m happy to file an enhancement request if that’s the best route. I’m skilled enough to do find and replace in code, but I’m not a JS dev!
      Thanks!
      JalibuJ 2 Replies Last reply Reply Quote 0
      • JalibuJ Offline
        Jalibu Module Developer @gabrielm9
        Hi @gabrielm9 ,
        contribution is always welcome :-)
        You have to compile the Typescript sources using npm run build.
        Let me know, if you have problems. I‘m waiting for your PR
        • JalibuJ Offline
          Hi @gabrielm9,
          the latest version 2.5.x supports different color schemes now.
          swvalentiS G 2 Replies Last reply Reply Quote 0
          • swvalentiS Offline
            swvalenti Project Sponsor @Jalibu
            Outstanding work fellas
            • G Offline
              gabrielm9 Project Sponsor @Jalibu
              Hi @jalibu,
              Thanks very much! I was about to spend time figuring it out how to variabalize the code but I’ve learned from what you did. I would have taken me a week to figure it out :slightly_smiling_face:. The wife thanks you as well.
              • F Offline
                fmarcu @bhepler
                @bhepler
                osmMapUrl: "https://cartodb-basemaps-{s}.global.ssl.fastly.net/dark_all/{z}/{x}/{y}.png"
                I’m using the dark map referenced above on a black background but every time the module changes zoom level it fills with a white background until the new map tiles populate. It’s worst when zooming out,
                Does anyone know if it there is a parameter I can change so the blank tiles between zoom levels stay black?
                This is a minor annoyance with an otherwise great module.
                Thank you!
                JalibuJ 1 Reply Last reply Reply Quote 0
                • JalibuJ Offline
                  Jalibu Module Developer @fmarcu
                  @fmarcu said in MMM-RAIN-MAP (new: version 2.x):
                  try to add this to your custom.css
                  .MMM-RAIN-MAP .leaflet-container {
                    background: #000;
                  F karsten13K 2 Replies Last reply Reply Quote 0
                  • F Offline
                    fmarcu @Jalibu
                    @jalibu said in MMM-RAIN-MAP (new: version 2.x):
                      background: #000;
                    That worked! Thank you!
                    • karsten13K Offline
                      karsten13 @Jalibu
                      @jalibu
                      this is the current rain situation and I don’t understand the differences, first picture your module, second one https://www.wetteronline.de/regenradar .
                      And the second one is reality …
                      • JalibuJ Offline
                        Jalibu Module Developer @karsten13
                        @karsten13 Unfortunately, I can’t tell you that. I am only responsible for the display layer, not for the weather data :-)
                        The radar layers come from the Rainviewer API, which I have actually had quite good experiences with in the past.
                        Is it the usual case on your mirror that the displayed radar images do not match the reality?
                        What I can see is that RegenRadar.de and RainViewer have different scales. With RainViewer it needs a much higher degree of cloudiness to be displayed on the map.
                          karsten13 @Jalibu
                          @jalibu
                          Unfortunately, I can’t tell you that. I am only responsible for the display layer, not for the weather data 🙂
                          I’m aware of this …
                          saw such differences this week the first time
                          will oberve this but the differences are heavy and AFAIS not only explainable with the different scales. Meanwhile I was already asking myself if the rain layer is showing a total different location …
                          JalibuJ 1 Reply Last reply Reply Quote 1
                          • JalibuJ Offline
                            @karsten13 let me know your findings
                            • JalibuJ Offline
                              A few days ago, Openstreepmap obviously made some changes with their tile servers. They seem to block requests now, when the requests come from Electron applications. This is the case in most MagicMirror installations. As a consequence, MMM-RAIN-MAP does not show map tiles anymore.
                              I suspect, that also other modules are effected.
                              One possible fix is using another tile server for MMM-RAIN-MAP. One that still works at the moment, is the German fork “https://a.tile.openstreetmap.de/${z}/${x}/${y}.png”.
                              I will adjust the module soon, to use this tile server as a default.
                              You can also change the tile server by setting this property in the module config:
                                mapUrl: "https://a.tile.openstreetmap.de/${z}/${x}/${y}.png"
                              T plainbrokeP 2 Replies Last reply Reply Quote 1
                              • T Offline
                                trlynch @Jalibu
                                @jalibu
                                Woohoo!!
                                Thank you for posting this change. I was going nuts trying to figure out why my radar map became a white background.
                                Bummer the .org site is blocking connections.
                                I’m curious, is there a way to make the radar images more transparent? Here in Ohio we get a lot of deep greens and blues so they hide the map entirely.
                                Playing with rpi’s and now weather fun.
                                • karsten13K karsten13 referenced this topic on
                                • JalibuJ Offline
                                  the german tileserver fork is default now
                                    pminich @Jalibu
                                    @Jalibu I am getting a message that MMM-RAIN-MAP is 2 commits behind but I can’t see to update it. I have run NPM Update from inside the directory to no result. Is there a different process?
                                      sdetweil @pminich
                                      @pminich did u do the git pull in the module directory to get the latest code?
                                        pminich @sdetweil
                                        @sdetweil All set, thanks. Still learning my way around npm, git, etc…
                                        • O Offline
                                          ossman
                                          Seems like we’re in the same Boat! Weirdly enough, it hasn’t rained today. I’ll have an eye on it once it starts again!
                                          • K Offline
                                            kevsfastz
                                            Is it possible to add a layer for tropical storm/hurricane tracks similar to how NHC does with their ‘interactive map’?
                                            https://www.nhc.noaa.gov/refresh/graphics_at1+shtml/122110.shtml?gm_track#contents
                                            • 10
                                            • 8 / 10
