    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 316.1k Views 42 Watching
    • JalibuJ
      Jalibu Module Developer @gabrielm9
      Hi @gabrielm9,
      the latest version 2.5.x supports different color schemes now.
      swvalentiS G 2 Replies Last reply Reply Quote 0
      • swvalentiS
        swvalenti Project Sponsor @Jalibu
        Outstanding work fellas
        • G
          gabrielm9 Project Sponsor @Jalibu
          Hi @jalibu,
          Thanks very much! I was about to spend time figuring it out how to variabalize the code but I’ve learned from what you did. I would have taken me a week to figure it out :slightly_smiling_face:. The wife thanks you as well.
          • F
            fmarcu @bhepler
            @bhepler
            osmMapUrl: "https://cartodb-basemaps-{s}.global.ssl.fastly.net/dark_all/{z}/{x}/{y}.png"
            I’m using the dark map referenced above on a black background but every time the module changes zoom level it fills with a white background until the new map tiles populate. It’s worst when zooming out,
            Does anyone know if it there is a parameter I can change so the blank tiles between zoom levels stay black?
            This is a minor annoyance with an otherwise great module.
            Thank you!
            JalibuJ 1 Reply Last reply Reply Quote 0
            • JalibuJ
              Jalibu Module Developer @fmarcu
              @fmarcu said in MMM-RAIN-MAP (new: version 2.x):
              try to add this to your custom.css
              .MMM-RAIN-MAP .leaflet-container {
                background: #000;
              F karsten13K 2 Replies Last reply Reply Quote 0
              • F
                fmarcu @Jalibu
                @jalibu said in MMM-RAIN-MAP (new: version 2.x):
                  background: #000;
                That worked! Thank you!
                • karsten13K
                  karsten13 @Jalibu
                  @jalibu
                  this is the current rain situation and I don’t understand the differences, first picture your module, second one https://www.wetteronline.de/regenradar .
                  And the second one is reality …
                  • JalibuJ
                    Jalibu Module Developer @karsten13
                    @karsten13 Unfortunately, I can’t tell you that. I am only responsible for the display layer, not for the weather data :-)
                    The radar layers come from the Rainviewer API, which I have actually had quite good experiences with in the past.
                    Is it the usual case on your mirror that the displayed radar images do not match the reality?
                    What I can see is that RegenRadar.de and RainViewer have different scales. With RainViewer it needs a much higher degree of cloudiness to be displayed on the map.
                    • karsten13K
                      karsten13 @Jalibu
                      @jalibu
                      Unfortunately, I can’t tell you that. I am only responsible for the display layer, not for the weather data 🙂
                      I’m aware of this …
                      saw such differences this week the first time
                      will oberve this but the differences are heavy and AFAIS not only explainable with the different scales. Meanwhile I was already asking myself if the rain layer is showing a total different location …
                      JalibuJ 1 Reply Last reply Reply Quote 1
                      • JalibuJ
                        @karsten13 let me know your findings
                        • JalibuJ
                          A few days ago, Openstreepmap obviously made some changes with their tile servers. They seem to block requests now, when the requests come from Electron applications. This is the case in most MagicMirror installations. As a consequence, MMM-RAIN-MAP does not show map tiles anymore.
                          I suspect, that also other modules are effected.
                          One possible fix is using another tile server for MMM-RAIN-MAP. One that still works at the moment, is the German fork “https://a.tile.openstreetmap.de/${z}/${x}/${y}.png”.
                          I will adjust the module soon, to use this tile server as a default.
                          You can also change the tile server by setting this property in the module config:
                            mapUrl: "https://a.tile.openstreetmap.de/${z}/${x}/${y}.png"
                          T plainbrokeP 2 Replies Last reply Reply Quote 1
                          • T
                            trlynch @Jalibu
                            @jalibu
                            Woohoo!!
                            Thank you for posting this change. I was going nuts trying to figure out why my radar map became a white background.
                            Bummer the .org site is blocking connections.
                            I’m curious, is there a way to make the radar images more transparent? Here in Ohio we get a lot of deep greens and blues so they hide the map entirely.
                            Playing with rpi’s and now weather fun.
                            • karsten13K karsten13 referenced this topic on
                            • JalibuJ
                              the german tileserver fork is default now
                                pminich @Jalibu
                                @Jalibu I am getting a message that MMM-RAIN-MAP is 2 commits behind but I can’t see to update it. I have run NPM Update from inside the directory to no result. Is there a different process?
                                  sdetweil @pminich
                                  @pminich did u do the git pull in the module directory to get the latest code?
                                    pminich @sdetweil
                                    @sdetweil All set, thanks. Still learning my way around npm, git, etc…
                                    • O
                                      ossman
                                      Seems like we’re in the same Boat! Weirdly enough, it hasn’t rained today. I’ll have an eye on it once it starts again!
                                      • K
                                        kevsfastz
                                        Is it possible to add a layer for tropical storm/hurricane tracks similar to how NHC does with their ‘interactive map’?
                                        https://www.nhc.noaa.gov/refresh/graphics_at1+shtml/122110.shtml?gm_track#contents
                                        • plainbrokeP
                                          plainbroke @Jalibu
                                          @Jalibu said in MMM-RAIN-MAP (new: version 2.x):
                                          How do I go about getting that for the usa in particular kansas.?
                                          • JalibuJ
                                            Jalibu Module Developer @plainbroke
                                            @pminich the same way. The German fork contains world wide map data.
                                            • 10
                                            • 8 / 10
