    new update/upgrade script, ready for testing
    328 Posts 27 Posters 724.4k Views 24 Watching
      bobwilliams @sdetweil
      @sdetweil unfortunately I can’t. in the morning, raspberry did not turn on
        @sdetweil a month ago when I installed the mirror according to your script, everything worked right away. but did not start yesterday.
          sdetweil @bobwilliams
          @bobwilliams Ok. Send me the log if u get a chance. Thx
          • buzzkcB Offline
            buzzkc
            @sdetweil I did run this the other day when I was having an issue with node_helper not found. It didn’t fix that, but another message you posted did. The upgrade worked fine, but may be worth adding that git checkout of the node_helper index file to the script as a quick fix.
            Darren
            My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
              sdetweil @buzzkc
              @buzzkc Good idea. I can check if the file is present and restore it if not
                @sdetweil a few days ago I copied the image from a flash drive, now I restored it and everything repeats, again these files that he asks to save or not … if you say yes, the update does not work, if you say no then the mirror stops working
                  @bobwilliams i need to see the MagicMirror/installers/upgrade.log…
                  and also, open the developers window (ctrl-shift-i) and select the tab labebed ‘console’ and scroll up to find any errors…
                  also the pm2.log
                  B 2 Replies Last reply Reply Quote 0
                    @sdetweil ok try to do tomorrow, today was a hard day very tired
                      @sdetweil Everything has appeared to be simpler than we thought. I moved the files which were the obstacle on the way of working of your script to another folder, then updated the mirror using your script. After that I moved those files back and now mirror is working.
                        @bobwilliams What files? My script should handle it. So I want to understand.
                          @sdetweil /MagicMirror/installers/mm.sh
                          /MagicMirror/modules/default/calendar/calendar.js
                            /MagicMirror/modules/default/currentweather/currentweather.js
                          /MagicMirror/modules/default/weather/weather.js /MagicMirror/modules/default/weatherforecast/weatherforecast.js
                          /MagicMirror/package-lock.json
                          /MagicMirror/run-start.sh
                          when updating, your script asked to save these files or not. if I wrote yes, it was not updated, if I wrote no, the update went fine but the mirror stopped working. I just moved these files, updated the mirror, and put them back in place. and the mirror works
                            @bobwilliams Ok. I put a fix in for Save=yes. Save=No should replace them w local repo version…and then upgrade.
                            Will have to build test. Really want to see the upgrade log, and pm2 logs for why it stoppexy
                              @sdetweil sent by mail
                                @bobwilliams got them thanks… you didn’t happen to save that ‘failing’ MagicMirror folder did you?
                                  @sdetweil no, it didn’t work out
                                    @sdetweil Have you looked at what was the problem?
                                      @bobwilliams yes, the merge returns an error i don’t handle… but I don’t know what the error means…
                                      so was hoping u had the folder saved, so I could get a copy to test with…
                                        sdetweil
                                        I have submitted this script as part of pull request 1789
                                        • swvalentiS Offline
                                          swvalenti Project Sponsor
                                          @sdetweil Idk why or if this is even the case but I updated MMM-EventHorizon and now I get a black screen and server shows errored below…any ideas how to fix?
                                          pi@raspberrypi:~ $ pm2 restart mm
                                          Use --update-env to update environment variables
                                          [PM2] Applying action restartProcessId on app [mm](ids: 1)
                                          [PM2] [mm](1) ✓
                                          │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
                                          │ mm          │ 1  │ N/A  │ fork   │ online  │ 5   │ 0%     │ 2.5 MB   │
                                          │ omx_stream1 │ 2  │ N/A  │ fork   │ online  │ 28  │ 0%     │ 2.8 MB   │
                                          │ omx_stream2 │ 3  │ N/A  │ fork   │ online  │ 28  │ 0%     │ 2.7 MB   │
                                          │ omx_stream3 │ 4  │ N/A  │ fork   │ online  │ 28  │ 0%     │ 2.7 MB   │
                                          │ server      │ 0  │ N/A  │ fork   │ errored │ 0   │ 0%     │ 0 B      │
                                          swvalentiS Mykle1M 2 Replies Last reply Reply Quote 0
                                            swvalenti Project Sponsor @swvalenti
                                            @sdetweil Actually idk what the issue is…black screen even though all show online. Odd
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 16
                                            • 17
                                            • 8 / 17
