    remoteFile in compliments module
    71 Posts 14 Posters 96.2k Views 15 Watching
    • yawnsY Offline
      yawns Moderator @DvdEnde
      @DvdEnde
      no, this information is wrong. And you should avoid modifying module files.
      Try what I have written above, it is working fine
        DvdEnde @yawns
        @yawns Sorry but your option did not work for me.
        Also please check the original compliment.js file:
        https://github.com/MichMich/MagicMirror/blob/develop/modules/default/compliments/compliments.js
        it is standard prepared there.
        Please also check line 50:
        if (this.config.remoteFile != null) {
        At first I also thought this would be the major config file, but it is not. Its the module.
        If you console.log(this.config) it will give you an object like this. All information from the compliment.js
            updateInterval: 30000,
            remoteFile: null,
            fadeSpeed: 4000
        That is why i think @schlachtkreuzer6 should give this a try.
        You have also the latest version?
        I understand that modules should not be changed.
        Just trying to help.
        Please do correct me if I am wrong!
        strawberry 3.141S schlachtkreuzer6S 2 Replies Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @DvdEnde
          @DvdEnde the part from the config in the config.js overwrites the values in default with Object.assign()
          so when you define remoteFile in the config.js the null value is overwritten
          • yawnsY Offline
            yawns Moderator
            @DvdEnde Please don’t get me wrong, but this is basic javascript.
            this.config.remoteFile != null checks if the variable “remoteFile” is set in your config file. Afterwards you only have two scenarios:
            1. the variable is not set -> this if clause fails and no remote file is loaded.
            2. the variable is set to any value -> this if clause is true and the function complimentFile() is called, which tries to load the file defined in your config file, in my case “compliments.json”.
            If loading the remote file fails you see an error message in console output of your browser. Otherwise it does not produce any log.
              DvdEnde @yawns
              @yawns
              Don’t worry, i know it is basic javascript.
              @strawberry-3-141
              i thought so too, but it is NOT
              I just now changed the compliment.js (and deleted the remoteFile completly from here) and added this within the config.
              My object is simple
                  fadeSpeed: 4000
              On line 33 console.log(this.config.remoteFile) = undefined
                jcorraliza @yawns
                @yawns OK I created a compliments_test.json file and pasted your example into it and it worked. It looks like it just doesn’t work with the currentweather objects in my compliments.json file for some reason. Do I need to nest the currentweather objects within the morning, afternoon, and evening arrays perhaps?
                schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
                • schlachtkreuzer6S Offline
                  schlachtkreuzer6 @jcorraliza
                  @jcorraliza post your config.js and your remotefile pls
                    jcorraliza @schlachtkreuzer6
                    @schlachtkreuzer6 said in remoteFile in compliments module:
                    Hi there, I posted them a few posts up. It works with the time of day objects, but not with the currentweather objects in my .json file. I’m using v2.1.0, dev branch, and I’m using the currentweather default module.
                      schlachtkreuzer6 @DvdEnde
                      @DvdEnde MM is up to date and every module i git pull the latest version, nope it says it´s a invalid .json in the MM-Admin-Interface. i just can not use this config @yawns post:
                      	module: 'compliments',
                      	position: 'lower_third',
                      		remoteFile: 'compliments.json'
                      if i try to start MM, it´s showing up, that the config is broken. even when i adjust it to the MM-Admin code:
                      	"module": "compliments",
                      	"position": "lower_third",
                      	"config": {
                      		"remoteFile": "compliments.json"
                      I´m not in javascript or anything coding. But nothing worked for me. maybe my system is somehow broken…
                        DvdEnde @schlachtkreuzer6
                        @schlachtkreuzer6
                        The way you do it is the way it should be.
                        BUT i also cannot get it to work like this.
                        please try following:
                        Open config/config.js and remove
                        "config": {
                        Then open your compliments.js and check:
                        defaults: {
                        		remoteFile: null,
                        		fadeSpeed: 4000
                        change remoteFile to a useable name:
                        defaults: {
                        		remoteFile: "~/path to your/compliments.json",
                        		fadeSpeed: 4000
                        then restart MM (or restart the PI)
                        • 6
                        • 7
                        • 8
                        • 3 / 8
