    Can't clone from GitHub
    107 Posts 3 Posters 74.4k Views 3 Watching
      MMRPi1 @sdetweil
      @sdetweil I tried reinstalling git and I got the same error.
        sdetweil @MMRPi1
        @MMRPi1 just to recheck
        git clone https://github.com/sdetweil/MagicMirror_scripts.git
        fails with the same error…
        do this
        cat ~/.gitconfig
        is there a
        [http]
            proxy = http://mydomain\\myusername:mypassword@myproxyserver:8080
          MMRPi1 @sdetweil
          @sdetweil I got this instead: [http]
          sslVerify = false
            sdetweil @MMRPi1
            @MMRPi1
            https://stackoverflow.com/questions/51088635/git-clone-error-gnutls-handshake-failed-an-unexpected-tls-packet-was-receive
            ok, here is a solution I think… second response, recompile git with openssl
            link to script that does the work.
              MMRPi1 @sdetweil
              @sdetweil what do I put instead of <my_proxy>
                MMRPi1 @MMRPi1
                @MMRPi1 my_proxy
                • bheplerB Offline
                  bhepler Module Developer
                  I still want that connectivity check. The Pi can see the Windows box, but I want confirmation that the Pi can see the internet.
                    MMRPi1 @bhepler
                    @bhepler Oh yeah sorry, I did that and it worked fine, I got a bit of html
                      sdetweil @MMRPi1
                      @MMRPi1 no… the second answer
                      Might be issue with gnutls Package. we have to compile a git Package with openssl instead of gnutls. Follow the below steps,
                        MMRPi1 @sdetweil
                        @sdetweil That one shows up first for me. In any case I tried and it still doesn’t work
                          sdetweil @MMRPi1
                          @MMRPi1 u recompiled the git with openssl?? then it should give the gnutils error
                          sudo apt-get install -y build-essential fakeroot dpkg-dev
                          sudo apt-get -y build-dep git
                          sudo apt-get install -y libcurl4-openssl-dev
                          mkdir git-openssl
                          cd git-openssl
                          apt-get source git
                          cd git-*
                          sed -i -e 's/libcurl4-gnutls-dev/libcurl4-openssl-dev/g'
                          ./debian/control
                          sed -i -- '/TEST\s*=\s*test/d' ./debian/rules
                          sudo dpkg-buildpackage -rfakeroot -b
                          sudo dpkg -i git_2.7.4-0ubuntu1.6_arm64.deb
                          #CleanUp
                          cd ../../
                          sudo rm -rf git-openssl
                          You can follow This Bog or You can find simple script here to do that
                            MMRPi1 @sdetweil
                            @sdetweil I tried that and got gnutls_handshake() failed: Close notify
                            But that’s the same error as before :/
                              sdetweil @MMRPi1
                              @MMRPi1 then you are not running the openssl git…
                              u may have to run the pi admin tool for software and updates to enable source download… I had to
                              M bheplerB 2 Replies Last reply Reply Quote 0
                                MMRPi1 @sdetweil
                                @sdetweil How do you do that?
                                • bheplerB Offline
                                  bhepler Module Developer @sdetweil
                                  “gnutls_handshake() failed: Close notify”… I’m sorry, I don’t understand this. Can you type out the exact error that you’re seeing? Including all the text after “failed”.
                                  M S 2 Replies Last reply Reply Quote 0
                                    MMRPi1 @bhepler
                                    @bhepler fatal: unable to access: gnutls_handshake() failed: Close notify
                                      sdetweil
                                      the build process above doesn’t work. too old
                                        sdetweil @bhepler
                                        @bhepler but he can git clone from windows on the same local network.
                                        almost like an install failure or an sd card starting to fail.
                                        • bheplerB Offline
                                          @sdetweil - Yeah, this is all kinds of weird. He’s using what appears to be a consumer grade network router. He shouldn’t have to mess with proxy settings as he should just be behind the NAT functions. And even if he was, it should also affect his Windows installation.
                                          Let’s try to reinstall git one more time, if you please:
                                          sudo apt remove git --purge
                                          sudo apt install git
                                            sdetweil @bhepler
                                            @bhepler I don’t think its a git problem… I think its a library problem
                                            • 6
                                            • 4 / 6
