    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 308.5k Views 42 Watching
    • JalibuJ Offline
      Jalibu Module Developer
      The serverside prerendering works in theory. The recording is just 2-4 Megabytes and the playback on the frontend consumes nearly no additional computing resources.
      The little problem is that prerendering is kind of ultra heavy :-D
      My Raspi 3 takes more than a minute for that (with only a few additional modules running) and takes >60MB memory for that.
      For those of you having problems due to limited resources with live rendering, the prerendering won’t be the answer I guess :-/
      • FoziF Offline
        Fozi Project Sponsor
        I FOUND THE “CULPRIT”!!
        Yesterday I tinkered around with a module I tried some time ago (MMM-TextClock) and deactivate MMM-google-routes, as I knew the didn’t play well together. In that context I enabled MMM-RAIN-MAP again, just to see if that would have any effect if MMM-google-routes was disabled.
        And Bingo!
        Since yesterday evening I had no crash or freeze on my MM. Also the memory consumption appears normal and the processor load is between 5%-20% on average (RPi 3b+)
        I’ll keep MMM-google-routes disabled for now, as I gives me no real added value at the moment.
        And to be clear, it is is a beautiful module and I love it, but I have no current use case for it. I ran it from the very beginning of my MM build without any issues and it is an eye catcher, too. But in favour of MMM-TextClock and MMM-RAIN-MAP we’ll have a pause ;-)
        Thanks to all of you and @Jalibu for helping me!
          requiemmg
          Hi @jalibu,
          I really like this module, but I fear that the memory issue still persists.
          Just cloned the repo, the module runs fine for some minutes or up to one hour, then the Raspi freezes. I am running on a 1GB 3B+ with 4 pages.
          Anything you can do about it?
          rubenixR JalibuJ 2 Replies Last reply Reply Quote 0
          • rubenixR Offline
            rubenix @requiemmg
            @requiemmg since I updated the pi to a Pi 4 4GB have no issues at all…came from a pi3 1GB too
            • JalibuJ Offline
              Jalibu Module Developer @requiemmg
              @requiemmg
              yepp, as @rubenix mentioned, 1GB memory is unfortunately too little :-/
              On my Raspi 4, 4GB it just works perfectly fine.
              I already tried to optimize the rendering to get it working with limited resources, but without success ¯\(ツ)/¯
              rubenixR 1 Reply Last reply Reply Quote 0
              • rubenixR Offline
                rubenix @Jalibu
                @Jalibu & @requiemmg was tempted to go for the 8GB one, but I can confirm 4Gb is more than enought; go for it and use the pi3 for another project :love-you_gesture_light_skin_tone:
                  sdetweil @rubenix
                  @rubenix u can make the swap space bigger too, helps in some environments
                  • rubenixR Offline
                    rubenix @sdetweil
                    @sdetweil i agree with that and sure it helps; but a pi 4 4Gb goes so smoth!!
                    pi3 1gb its ok for a simple magic mirror; for a complex one with transitions / animations it needs more gauge!
                    • earnestrichardsE Offline
                      earnestrichards
                      Great module. It’s running fantastically on my PI4.
                        requiemmg
                        Okay, for now I will not switch to a 4gb version. So I need to remember this one for “later”. Thanks.
                          bhepler Module Developer
                          I just tried this out. Thank you for the excellent module! Exactly what I was looking for.
                          Now if I could just get a dark theme going. I’m cool with the rain being in color, but it would be nice if I could figure out how to get the roads & state borders to only be outlines.
                            bdream
                            @Jalibu Just tried it out and it works fantastic wit OSM. Great job! :clapping_hands_medium-light_skin_tone: Many thanks
                            cheers, bdream
                            • karsten13K Offline
                              karsten13 @bhepler
                              @bhepler
                              or
                              JalibuJ 1 Reply Last reply Reply Quote 2
                              • JalibuJ Offline
                                Jalibu Module Developer @karsten13
                                @karsten13 thanks for your contribution. I saw your PR and will merge it soon.
                                • ViDiBiV Offline
                                  ViDiBi
                                  Hi @Jalibu!
                                  This module is really amazing! Thank you so much!
                                  Maybe you can help me with one issue: The map doesn’t center correctly on my Mirror… Have I done something wrong:
                                              module: "MMM-RAIN-MAP",
                                              position: "bottom_right",
                                                  animationSpeed: 600,
                                                  displayClockSymbol: false,
                                                  displayTime: true,
                                                  extraDelayLastFrame: 1000,
                                                  height: "420px",
                                                  lat: 50.31,
                                                  lon: 11.91,
                                                  map: "OSM",
                                                  markers: [
                                                      { lat: 50.31, lng: 11.91, color: "red" },
                                                  onlyOnRain: false,
                                                  opacity: 0.65,
                                                  timeFormat: 24,
                                                  updateIntervalInSeconds: 300,
                                                  width: "420px",
                                                  zoom: 9,
                                                  zoomOutEach: 1,
                                                  zoomOutLevel: 3,
                                  Bild 1
                                  Bild 2
                                  Thank you very much :-)
                                  Victor
                                    karsten13
                                    @ViDiBi said in MMM-RAIN-MAP:
                                    lon: 11.91
                                    I think you have a typo in your config, lon: 11.91 should be lng: 11.91
                                    ViDiBiV 1 Reply Last reply Reply Quote 1
                                    • ViDiBiV Offline
                                      ViDiBi @karsten13
                                      @karsten13 said in MMM-RAIN-MAP:
                                      lon: 11.91
                                      That definitely was too easy!!! Thanks! I copied it from another module and didn’t see it :-)
                                        @karsten13 - Dude, that was exactly what I was looking for. Thank you.
                                          singhharry12
                                          I think I’m too stupid to get an API key. Are there any instructions in German or can someone help me?
                                          ViDiBiV 1 Reply Last reply Reply Quote 0
                                          • ViDiBiV Offline
                                            ViDiBi @singhharry12
                                            @singhharry12 said in MMM-RAIN-MAP:
                                            Hi @singhharry12!
                                            Für dieses Modul brauchst du keinen API Key, es sei denn du möchtest unbedingt GoogleMaps nutzen. Ich würde dir aber alleine wegen der Kosten empfehlen OpenStreetMaps zu nutzen. Das hier ist meine Config:
                                                            displayTime: true,
                                                            height: "420px",
                                                            lat: 50.31,
                                                            lng: 11.91,
                                                            map: "OSM",
                                                            markers: [
                                                            onlyOnRain: false,
                                                            opacity: 0.65,
                                                            timeFormat: 24,
                                                            width: "420px",
                                                            zoom: 9,
                                                            zoomOutEach: 1,
                                                            zoomOutLevel: 3,
                                            Solltest du aber unbedingt die Google Maps Karte nutzen wollen, musst du dir einen API Key bei Google erstellen und dieser kostet bei Zugriffen etwas… Wenn du das unbedingt willst, sag Bescheid und ich mache dir eine Anleitung auf deutsch :-)
                                            BG
                                            Victor
                                            • 9
                                            • 10
                                            • 3 / 10
