    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 114.8k Views 18 Watching
    • T Offline
      thoimi @Jopyth
      @Jopyth I had the same problem.
      Your work-around (installation) worked for me but the sensor does not seem to do anything…
      the test.py script shows me always “1” - also when nothing is moving in the room…
        Jopyth Moderator @thoimi
        @thoimi Check for the correct wiring (PIN-Numbers can be confusing, there is the BCM numbering and the other one), also make sure GND and 5V are conncted correctly, adjust sensitivity to maximum and time to minimum (so it hopefully switch back and forth quickly), try covering up the sensor under a bowl or something and then put your hand in to test.
        When I set up the sensor, I also searched for the error for hours, and at the end my problem was the sensor was plugged into pin 4 (BCM) and not 7 as I thought. Also I think you need to remove the , pull_up_down=GPIO.PUD_DOWN part (PIR example).
        Helpful sticky: How to troubleshoot
        T 1 Reply Last reply Reply Quote 1
        • T Offline
          thoimi @Jopyth
          @Jopyth Thank you for your quick reply! :)
          I tried for hours now… I think it’s connected correctly, because when I’m switching the pin-number in the script the script shows me always “0” - with the correct pin-number it shows me “1”…
          I also put the sensor in a box - always shows me “1”… completely strange… :/
            @thoimi It shows 1 because of the pull up resistor. Try removing that part, check my edited post above.
            Edit: The 1 does not mean it is wired correctly, it just shows 1 because of the pull up resistor.
            • T Offline
              thoimi @Jopyth
              @Jopyth
              thank you for the updated script!
              the new script also shows me “Intruder detected” … i tried many variations of time and sensitivity adjustments…
              I found another script on the internet:
              from gpiozero import MotionSensor
              pir = MotionSensor(4)
              while True:
                  if pir.motion_detected:
                      print("Motion detected!")
              This script shows me also the “Motion detected” all the time…
              Maybe the PIR-Sensor itself is the problem… I will try with another Sensor next week :(
                Makradon
                Thanks for trying to help me.
                I tried what you said. It always says “motion detected”.
                I’m sure the wiring is right… I also use the dht22 sensor and that works perfectly fine. And the way you count the pins is the same… isn’t it?
                I bought a new PIR sensor… but the problem is still there.
                  Jopyth Moderator @Makradon
                  @Makradon Nope, definitely not the same numbering.
                    Makradon @Jopyth
                    @Jopyth said in [MMM-PIR-Sensor] Install failing:
                    Now I’m confused.
                    5V is Pin 2
                    Ground is Pin 6
                    I think that is right when you count like this:
                    http://www.elektronik-kompendium.de/sites/raspberry-pi/fotos/raspberry-pi-15b.jpg
                    And when you don’t change the pin in the config file it says SensorPin 22.
                    So which is the right pin in the pic above to connect the output of the PIR sensor that it works with this module?
                      @Makradon Sensor PIN 22 for the PIR-Sensor module is this one:
                      Edit: Maybe I was confused by the diagram of the DHT22 module. It looked to me like the GPIO and WiringPi numbers are different.
                      johnnyboyJ 1 Reply Last reply Reply Quote 1
                      • P Offline
                        PindaPower
                        In other post they posted this link, maybe it will help??
                        https://diyhacking.com/raspberry-pi-gpio-control/
                        F 1 Reply Last reply Reply Quote 1
                        • F Offline
                          fox @PindaPower
                          @PindaPower said in [MMM-PIR-Sensor] Install failing:
                          Thank you. With that i understood the delay and sensitivy knob.
                          But! When i put sensivity at most right, the monitor goes on automatically ON after a while, even when there is NO movement in the radius… How can i debug this?
                            Mar
                            I’ve tried following the instruction above of removing and reinstalling but I keep getting the below errors. I’m not even sure what they are unfortunately, wondering if anyone is able to help.
                            pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
                            npm WARN engine electron-rebuild@1.5.7: wanted: {"node":">=6.0.0"} (current: {"node":"4.2.1","npm":"2.14.7"})
                            > epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll
                            > node-gyp rebuild
                            make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll/build'
                              CXX(target) Release/obj.target/epoll/src/epoll.o
                              SOLINK_MODULE(target) Release/obj.target/epoll.node
                              COPY Release/epoll.node
                            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll/build'
                            > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
                            > electron-rebuild -e ../../node_modules/electron-prebuilt
                            /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/node_modules/spawn-rx/lib/index.js:139
                                let cmdArgs = ['/C', exe, ...args];
                            SyntaxError: Unexpected token ...
                                at exports.runInThisContext (vm.js:53:16)
                                at Module._compile (module.js:414:25)
                                at Object.Module._extensions..js (module.js:442:10)
                                at Module.load (module.js:356:32)
                                at Function.Module._load (module.js:311:12)
                                at Module.require (module.js:366:17)
                                at require (module.js:385:17)
                                at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/rebuild.js:38:16)
                                at Module._compile (module.js:435:26)
                                at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:24:16)
                            npm ERR! Linux 4.4.38+
                            npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                            npm ERR! node v4.2.1
                            npm ERR! npm  v2.14.7
                            npm ERR! code ELIFECYCLE
                            npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
                            npm ERR! This is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                            npm ERR! not with npm itself.
                            npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                            npm ERR! You can get their info via:
                            npm ERR!     npm owner ls Magic-Mirror-Module-PIR-Sensor
                            npm ERR!     /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                            edit: I have tried modifying the package.json file in the FAQ but the install exits within a minute, vs a really long time leaving the original. Seems like it gets farther through the install the first time. Though I’ve noticed i do have the electron folder and not an electron-prebuilt. The following is the error I get when i remove the -prebuilt.
                                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/rebuild.js:38:16)
                                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:24:16)
                            npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron`
                            npm ERR!
                            npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron'.
                            After doing the npm rebuild suggested above I get this error (with original/modified package.json)
                            npm ERR!
                              Jopyth Moderator @Mar
                              @Mar said in [MMM-PIR-Sensor] Install failing:
                              This is an old node version. Please update your node and npm. (If you need help check the answers to this SO question.)
                              M 1 Reply Last reply Reply Quote 2
                              • F Offline
                                fox
                                @Jopyth thank you very much for all your efforts for this community.
                                Even its in your spare time it should be honored !
                                  Mar @Jopyth
                                  @Jopyth Hi, thanks for taking the time to respond to this. Sorry I was away for work and didnt have too much time to test this out.
                                  So i managed to, using your link, to update node. But there was issues even getting there, I had to use an older version of node to update npm…but anyways here is the output showing I’ve updated to the latest version.
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm -v
                                  4.0.5
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ node -v
                                  v7.4.0
                                  But now I’m getting this issue. Again thanks @Jopyth for responding so quickly last time.
                                  npm WARN prefer global node-gyp@3.5.0 should be installed with -g
                                  > epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                                  > node-gyp rebuild
                                  make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                                  make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                                  An unhandled error occurred inside electron-rebuild
                                  Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                                  Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                                      at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                                      at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                                      at Generator.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                                      at Generator.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                                      at Generator.tryCatcher (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/util.js:16:23)
                                      at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:97:49)
                                      at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:201:15
                                      at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                                      at Module._compile (module.js:571:32)
                                      at Object.Module._extensions..js (module.js:580:10)
                                      at Module.load (module.js:488:32)
                                      at tryModuleLoad (module.js:447:12)
                                      at Function.Module._load (module.js:439:3)
                                      at Module.runMain (module.js:605:10)
                                      at run (bootstrap_node.js:420:7)
                                      at startup (bootstrap_node.js:139:9)
                                  npm ERR! node v7.4.0
                                  npm ERR! npm  v4.0.5
                                  npm ERR! Exit status 255
                                  npm ERR!
                                  npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                                  npm ERR!     npm bugs Magic-Mirror-Module-PIR-Sensor
                                  npm ERR! Or if that isn't available, you can get their info via:
                                    @Mar Please change your package.json file as displayed here and execute npm install again. @paviro has not yet responded to my PR, but hopefully this will get merged in sooner or later.
                                    M 3 Replies Last reply Reply Quote 1
                                      Mar @Jopyth
                                      @Jopyth It finally worked!!! :lifter_tone2: thanks so much. Ive spent days on this :(
                                      Tried this last link you provided previously before posting but nothing was working, your support around getting node updated (and npm) was all that needed to happen first.
                                      Thanks again!
                                        Mar @Jopyth
                                        @Jopyth Though looks like its failing on the config file now, Do you see any issues with the following?
        module: 'MMM-PIR-Sensor',
        sensorPin: 17,
                                        i seem to get an error and MM doesnt load when this is in the config file. I can even have disabled:true and it loads, otherwise I’ll get a blank webpage.
                                          Mar @Jopyth
                                          @Jopyth
                                          using PM2 Im able to get the logs when starting, and even though it installed with your instructions i now get this error in the logs.
                                          0|mm       | Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                          0|mm       | was compiled against a different Node.js version using
                                          0|mm       | NODE_MODULE_VERSION 50. This version of Node.js requires
                                          0|mm       | NODE_MODULE_VERSION 51. Please try re-compiling or re-installing
                                          0|mm       | the module (for instance, using `npm rebuild` or`npm install`).
                                          0|mm       |     at Object.Module._extensions..node (module.js:598:18)
                                          0|mm       |     at Module.load (module.js:488:32)
                                          0|mm       |     at tryModuleLoad (module.js:447:12)
                                          0|mm       |     at Function.Module._load (module.js:439:3)
                                          0|mm       |     at Module.require (module.js:498:17)
                                          0|mm       |     at require (internal/module.js:20:19)
                                          0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                                          0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:1:99)
                                          0|mm       |     at Module._compile (module.js:571:32)
                                          0|mm       |     at Object.Module._extensions..js (module.js:580:10)
                                          0|mm       | unclutter: someone created a sub-window to my sub-window! giving up
                                            Mar @Mar
                                            @Mar for anyone else who is getting this an npm rebuild fixes it. from here https://github.com/atom/apm/issues/635
                                            • 2 / 4
