    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    256 Posts 55 Posters 623.1k Views 57 Watching
    • karsten13K Offline
      karsten13 @karsten13
      so now i catched the situation where the alerts are in english and in german:
      the data is coming directly from openweathermap, here the json-part:
        j.e.f.f Project Sponsor Module Developer @dkhorse74
        @dkhorse74 that’s the main header for the module. Change it like this:
            module: "MMM-OpenWeatherForecast",
            header: "Forecast",  <— here
              apikey: "a1b2c3d4e5f6g7h8j9k0", //only string here
              latitude: 51.490230,            //number works here
              longitude: "-0.258810"          //so does a string
          j.e.f.f Project Sponsor Module Developer @shiryu1031
          @shiryu1031 you can’t do that independently on the main units setting. OpenWeather returns mph for imperial, and m/s for standard and metric.
            j.e.f.f Project Sponsor Module Developer @swvalenti
            @swvalenti yes you can. The weather alerts are part of the summary section. OpenWeather returns such a short summary that I didn’t think it necessary to make two separate configure. Two ways to turn off the alerts:
            • set summary : false
            • if you want the summary but not the alerts, you can hide them in your custom css as follows:
            .MMM-OpenWeatherForecast .weather-alert {
              display: none;
            I think I’ll look at a way to truncate weather alerts so they don’t take up so much space.
            swvalentiS 1 Reply Last reply Reply Quote 1
              j.e.f.f Project Sponsor Module Developer @karsten13
              @karsten13 I don’t think there is much I can do here. I’ve coded this module to explicitly pass through a language parameter, either whatever is set in your main MM config, or whatever you explicitly set in the module’s config. It seems that OpenWeather doesn’t translate the weather alert, but merely passes them on as-is from whatever source it gets them from. Which is why sometimes you’re getting only English, and other times you’re getting multiple translations.
              • swvalentiS Offline
                swvalenti Project Sponsor @j.e.f.f
                @j-e-f-f said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                  display: none;
                Awesome thanks @j-e-f-f !
                  dkhorse74 @j.e.f.f
                  @j-e-f-f
                  Thanks Jeff!!
                    shiryu1031 @j.e.f.f
                    @j-e-f-f I see, thank you for your help. I thought it can be done because the example picture on Github is in km/h, but for myself, I am only seeing m/s as you mentioned. I guess it can not be change from m/s to km/h?
                      karsten13 @j.e.f.f
                      @j-e-f-f
                      yes, I’m aware of this. Sent a mail to openweathermap.org and will let you know if I ever get a response …
                      • O Offline
                        OberfragGER @karsten13
                        Did anyone have an idea how to chage the timeformat from sundown?
                        Now its displayed: 6:20… i want to have 18:20
                        I already changed the rest.
                        • 6
                        • 25
                        • 26
                        • 4 / 26
