    Calendar config
    14 Posts 5 Posters 15.5k Views 4 Watching
    • ? Offline
      A Former User
      Hello all,
      I was following the suggestions for incorporating my Gmail calendars into the Calendar section per this topic. My config file works fine with the default calendar, but as soon as I make the changes, it crashes. I’m not sure if it’s a typo, but is there something I’m missing?
                              module: 'calendar',
                              header: 'Calender',
                              position: 'top_left',
                                                      symbol: 'calendar-check-o ',
                                                      url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
                                                      url: 'htpps://calendar.google.com/calendar/ical/ME%40gmail.com/public/basic.ics'
                                                      url: 'https://calendar.google.com/calendar/ical/WIFE%40gmail.com/public/basic.ics'
      I obviously changed the email addresses, but that’s the line I get from Google for icals. I left the default, except I changed the header to a generic Calendar since it’s not just a US Holiday calendar anymore. Thanks in Advance!
      in_a_daysI 1 Reply Last reply Reply Quote 0
      • in_a_daysI Offline
        in_a_days @Guest
        @JbeesonMagic16
        Looks like you may be missing a close bracket. Try this:
                            module: 'calendar',
                            header: 'Calender',
        What ship would bear me ever back across so wide a Sea?
        ? 1 Reply Last reply Reply Quote 2
        • ? Offline
          A Former User @in_a_days
          So I added the bracket, but still get the ‘please create a config file’, which is what I get when I add something new and inevitably mess something up.
          • mochmanM Offline
            mochman Module Developer
            Try putting your config.js in a website like http://jshint.com/. It should help you find any brackets you might be missing.
            ? 1 Reply Last reply Reply Quote 1
            • ? Offline
              A Former User @mochman
              @mochman How do I know what needs to be changed though? It’s finding a lot of issues, even with the default code that I’ve not changed?
              Ater adding that } , it’s complaining about double quotes instead of singular, unexpected label ‘modules’, and expected an identifier and instead saw ‘}’.
              It doesn’t seem to be geared towards the code for Magic Mirror?
              mochmanM 1 Reply Last reply Reply Quote 0
              • yawnsY Offline
                yawns Moderator
                Please post your entire config
                btw … I don’t know for google calendars, but I replaced https with webcal for my outlook.com calendar.
                • mochmanM Offline
                  mochman Module Developer @Guest
                  @JbeesonMagic16 No, it’s a general javascript problem finder. If you paste your config.js file in it’s entirety into http://jshint.com/. You should see it say “One undefined variable”. If you see
                  Expected '}' to match '{' from line XXX and instead saw ']'
                  You are missing a bracket. Look at line XXX and then follow the code down to see where the missing bracket is.
                    in_a_days
                    The full config file will definitely help. You also have one more small typo here -
                    that should probably be ‘https’ rather than ‘htpps’ but I don’t think this should be breaking your config.
                    • ? Offline
                      @in_a_days Nice catch! I fixed it, but yeah, it wasn’t the source.
                      • ? Offline
                        A Former User
                        /* Magic Mirror Config Sample
                         * MIT Licensed.
                        var config = {
                                port: 8080,
                                ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
                                language: 'en',
                                timeFormat: 12,
                                units: 'imperial',
                                                module: 'alert',
                                                module: "updatenotification",
                                                position: "top_bar"
                                                module: 'clock',
                                                module: 'calendar',
                                                header: 'Calender',
        url: 'https://calendar.google.com/calendar/ical/ME%40gmail.com/public/basic.ics'
                                                module: 'compliments',
                                                position: 'lower_third'
                                                module: 'MMM-WunderGround',
                                                position: 'top_right',
                                                        apikey: 'MYKEY',
                                                        pws: 'pws:KMOOFALL59',
                                                        hourly: '1',
                                                        fctext: '1',
                                                        fcdaycount: "5",
                                                        fcdaystart: "0",
                                                        hourlyinterval: "3",
                                                        hourlycount: "2",
                                                        alerttime: 10000,
                                                        alerttruncatestring: "english:",
                                                roundTmpDecs: 1,
                                                UseCardinals: 0,
                                                layout: "horizontal",
                                                sysstat: 0
                                                module: 'newsfeed',
                                                position: 'bottom_bar',
                                                        feeds: [
        title: "New York Times",
                                                        showSourceTitle: true,
                                                        showPublishDate: true
                        Also modified the API to hide it in the weather section, but it’s there. JShint gave me 4 errors, but I was going off that link from the other question for syntax, so I’m not 100% what needs to be removed or added.
                        Four warnings
                        46 Expected ‘]’ to match ‘[’ from line 15 and instead saw ‘{’.
                        47 Expected ‘}’ to match ‘{’ from line 7 and instead saw ‘module’.
                        47 Missing semicolon.
                        47 Unrecoverable syntax error. (52% scanned).
                          in_a_days @Guest
                          @JbeesonMagic16
                          add a comma here:
                          so it looks like this
                          See if that solves it.
                          • mochmanM Offline
                            @JbeesonMagic16 Yeah, @in_a_days recommendation fixes the problems in the jshint. Hopefully that works for you.
                            • ? Offline
                              Nice, that does get it working again, but no go on the calendars actually showing up. I found a private link to google calendars ical, which makes sense since I’m not sharing my calendar with the public. So I used that link, and they work now. Thanks to all of you for your help!!
                                Mykle1 Project Sponsor Module Developer @Guest
                                @JbeesonMagic16
                                I almost posted the same exact problem but I found this page (thread?) (Whatever), but due to the help you received and your last comment about the private link to google calendars ical, I was able to resolve the issue without asking the question. This place is awesome. :-)
                                Up votes for everyone!
