    White screen after MMM-Remote-Control update
    9 Posts 6 Posters 6.7k Views 6 Watching
    • H Offline
      Hein-Jan
      I have run the update on the MMM-Remote-Control module, and now get a white screen when starting MagicMirror.
      If I // the lines on the MMM-Remote-Control module in the config.js the Mirror shows up normally. I have deleted and reinstalled the MMM-Remote-Control module but the problem remains.
      Any advice? I do like the functionality of the Remote Control module.
      strawberry 3.141S J 2 Replies Last reply Reply Quote 0
        roramirez Core Contributors
        Is missing body-parser lib required by MMM-Remote-Control
        Go the module directory and run npm install
        cd /home/pi/MagicMirror/modules/MMM-Remote-Control/
        npm install
        Easy module development with MagicMirror Module Template
        E T 2 Replies Last reply Reply Quote 2
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Hein-Jan
          @Hein-Jan any errors in the logs that you can provide?
          • T Offline
            toonazd
            Having the same problem… Any suggestions?
            • T Offline
              toonazd @strawberry 3.141
              pi@raspberrypi:~/MagicMirror $ node serveronly
              Starting MagicMirror: v2.1.0
              Loading config …
              Loading module helpers …
              Initializing new module helper …
              No helper found for module: calendar_monthly.
              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘body-parser’
              Whoops! There was an uncaught exception…
              { Error: Cannot find module ‘body-parser’
              at Function.Module._resolveFilename (module.js:469:15)
              at Function.Module._load (module.js:417:25)
              at Module.require (module.js:497:17)
              at require (internal/module.js:20:19)
              at Object. (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:15:20)
              at Module._compile (module.js:570:32)
              at Object.Module._extensions…js (module.js:579:10)
              at Module.load (module.js:487:32)
              at tryModuleLoad (module.js:446:12)
              at Function.Module._load (module.js:438:3) code: ‘MODULE_NOT_FOUND’ }
              pi@raspberrypi:~/MagicMirror $ git pull
                npm install
                • E Offline
                  elmerito25 @roramirez
                  @roramirez Experience the same issue and was fixed by following your instructions! Thanks a bunch!
                  • T Offline
                    toonazd @roramirez
                    Thanks, all good now
                    • H Offline
                      Hein-Jan
                      @roramirez.
                      Thanks, you have hit the nail on the head. I did run the git pull command, I have run the reinstall (the script did not work so I ran the manual method, but I did not run the npm install.
                      Sorry, I am new at this.
                      I did search the forum but could not find a solution.
                      So, thank for pointing out my mistake and helping me rectify it.
                      @ others: thanks for sharing your problems and logs so the problem could be solved.
                      Case closed from my perspective.
                        Jopyth Moderator @Hein-Jan
                        @Hein-Jan Sorry about this, forgot to mention, that the new version introduces dependencies which must be installed.
                        @roramirez answer should work for anyone having the same problem (thanks!).
                        Helpful sticky: How to troubleshoot
