[Remote-Control] Versions not visible
9 Posts 3 Posters 3.5k Views 3 Watching
    schlachtkreuzer6 @Jopyth
    @Jopyth I have tried updating the module, but nothing changed?! first i tried it with git pull - up to date, and also with the installer… anyway the installer looks great! :D
    if i git fetch and git tag (without s cause “tags” did not work) i´ll see this versions:
    v2.0.0
    v2.0.1
    v2.0.2
    v2.0.3
    v2.0.4
    v2.0.5
    v2.1.0
    but you are talking about version 1.1.2? i don´t get it ^^
    Y 1 Reply Last reply Feb 3, 2017, 12:48 PM Reply Quote 0
    • Y Offline
      yawns Moderator @schlachtkreuzer6
      @schlachtkreuzer6
      v2.0.0 - v2.1.0 are version numbers of MagicMirror, not this specific module.
      Are you sure you are working in ~/MagicMirror/modules/MMM-Remote-Control as written here? https://github.com/Jopyth/MMM-Remote-Control#update
      S 1 Reply Last reply Feb 3, 2017, 12:52 PM Reply Quote 0
        schlachtkreuzer6 @yawns
        and with tags: 0_1486126466527_git tags.PNG
        J 1 Reply Last reply Feb 3, 2017, 2:38 PM Reply Quote 0
        • Y Offline
          yawns Moderator
          weird. If you run ls -la do you see a folder called .git ?
          S 1 Reply Last reply Feb 3, 2017, 5:17 PM Reply Quote 2
            Jopyth Moderator @schlachtkreuzer6
            @schlachtkreuzer6 How did you install the module? It sounds like you may have downloaded a zipped version? Or did you use the installer or git clone https://github.com/Jopyth/MMM-Remote-Control.git? Edit: Also please do @yawns suggestion, if the folder does not exist, something went wrong with cloning/initializing the git repository.
            Helpful sticky: How to troubleshoot
            S 1 Reply Last reply Feb 3, 2017, 5:22 PM Reply Quote 1
              @yawns in the MM directory or module directory? in the module:
              Y 1 Reply Last reply Feb 3, 2017, 5:46 PM Reply Quote 0
                @Jopyth First install, was 2 or 3 months ago, after installing some modules i git clone your module like in the readme. then i saw your post with the update und tried from the MM-remote-controle directory git pull, and it says it´s already up to date. so then i tried the installer with master branch (developer didn´t work) 0_1486142532876_installer.PNG
                • Y Offline
                  @schlachtkreuzer6
                  Right. The .git folder is not there, so git does not recognize this repository.
                  I’d suggest to remove the entire folder and git clone again.
                  S 1 Reply Last reply Feb 3, 2017, 5:56 PM Reply Quote 0
                    @yawns thaaaaaanks for your advice :thumbsup_tone1:
