    MMM-CalendarExt3
    688 Posts 82 Posters 2.8m Views 86 Watching
      MMRIZE @Studio472
      @Studio472
      I think it could be possible with preProcessor, but I’m not in front of my computer, so cannot show example at this moment.
        MMRIZE @Studio472
        @Studio472
        Config:
        eventTransformer: (event) => {
          if (event.calendarName === 'MLB') { // I assume you assigned 'MLB' as a calendar name.
            event.endDate = event.startDate + 1000 // I think 1000ms is safer than 1 hour
          return event
        Before:
        After:
        • F Offline
          Fjerdrumsmoen
          Hi
          Need some help here.
          Trying to get this module to work, but only the “header” of the month is showing. No events is listing, and no dates are showing. In the GoogleCalender module I can see the events, so I know that the GoogleCalender is working.
          Do someone know what is wrong? My config file is like this:
          			module: 'MMM-GoogleCalendar',
          			header: "Familie Kalender",
          						color: "red",
          						broadcastPastEvents: true, // <= IMPORTANT to see past events
          						calendarID: "GOOGLE ID_ deleted from the code"
          						// add another calendar HERE if needed
          			 module: "MMM-CalendarExt3",
          			 position: "bottom_center",
          			 title: "Familie kalenderen",
          				mode: "month",
          				instanceId: "basicCalendar",
          				locale: 'de-DE',
          				maxEventLines: 5,
          				firstDayOfWeek: 1,
          				calendarSet: ['FK']
          S M 3 Replies Last reply Reply Quote 0
            sdetweil @Fjerdrumsmoen
            @Fjerdrumsmoen calendarExt3 gets its data from the default calendar module…
            so you have to configure it, and just comment out the position: setting…
              @Fjerdrumsmoen said in MMM-CalendarExt3:
              module: ‘MMM-GoogleCalendar’,
              no, use
              module: "calendar"
              • F Offline
                Fjerdrumsmoen
                Hmm. All empty when I use the calendar module, also. Tested with the US holidays, and everything stays blank. (Without the heading)
                Any other tips?
                  @Fjerdrumsmoen 1st
                  w default cal module, does the calendar display?
                  (before u comment out position)
                  did u try the default ext3 config?
                  I used the default ext3 config from doc, with the holidays
                  commented out calendarSet, and locale…
                    position: "bottom_bar",
                    title: "",
                      mode: "month",
                     // locale: 'de-DE',
                      maxEventLines: 5,
                      firstDayOfWeek: 1,
                      //calendarSet: ['us_holiday', 'abfall', 'mytest'],
                  got
                    MMRIZE @Fjerdrumsmoen
                    @Fjerdrumsmoen
                    For google calendar you need some additional config. See the readme.md more.
                    • F Offline
                      Fjerdrumsmoen
                      Thanks. Now it shows :-)
                      But not with Google account.
                      Should i put in this code in the config.js?
                      preProcessor: (e) => {
                        e.startDate = new Date(e.start?.date || e.start?.dateTime).valueOf()
                        e.endDate = new Date(e.end?.date || e.end?.dateTime).valueOf()
                        e.title = e.summary
                        e.fullDayEvent = (e.start?.date) ? true : false
                        return e
                        @Fjerdrumsmoen just use the Google url instead of the holidays… does it show in default calendar?
                        no… fix that
                        • 25
                        • 26
                        • 27
                        • 28
                        • 29
                        • 68
                        • 69
                        • 27 / 69
