    Module calendar - whole day event
    19 Posts 5 Posters 5.6k Views 5 Watching
    • W Offline
      wilco.kuijt
      Hello all,
      The calendar module is working fine for me, I am displaying a simple row of 7 events underneath eachother.
      If there is a “whole day event”, there is no time displayed. I would like to change this to “whole day”.
      I think I need to change this into “modules/default/calendar/calendar.js”, but before I do this, anyone a suggestion for a different approach?
      And, when I update the MagicMirror, are changes made in the calendar.js overwritten?
      Best regards,
      Wilco
        sdetweil @wilco.kuijt
        @wilco-kuijt yes if u change the default shipped code it will block updates. you would have to apply your changes again .
        whole day events do have a time, as it’s ALL DAY. every hour…
          MMRIZE @wilco.kuijt
          @wilco-kuijt
          What you want is this?
          After I read your post, I built a small killing-time project this Saturday morning.
          https://github.com/MMRIZE/MMM-ModuleMonkeyPatch
          With this on-flight patch, it works. (exception Rules be needed for different timeFormat, anyway, this is just a monkeypatching)
          This is monkey-patcher, so you don’t have to worry updating/upgrading original module.
          W htilburgsH 2 Replies Last reply Reply Quote 0
          • W Offline
            wilco.kuijt @MMRIZE
            @MMRIZE Yes, this is the way I would like to see it!
            Unfortunately (😉) on holiday right now, so I am not able to implement it.
            Best regards and thanks for helping me out!
            Wilco
            • htilburgsH Offline
              htilburgs @MMRIZE
              @MMRIZE how do you get different icons in front of the calendar items?
              Is this a default feature? Btw which calendar module are u using?
              (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                MMRIZE @htilburgs
                @htilburgs
                Basically, default calendar module can hold icons (symbol) and even multiple, and all CX3* support multi-icons also.
                But in this case, that is just an emoji included in the event title. :D (If what you mented is the flag symbol)
                htilburgsH 1 Reply Last reply Reply Quote 0
                  Babene1 Project Sponsor
                  @MMRIZE I like your calendar view, how does it work with the date and under it the individual calendar entries?
                    htilburgs @MMRIZE
                    @MMRIZE what I ment are the truck, recycling and other symbols in front of each row.
                    Never seen this before.
                      MMRIZE @htilburgs
                      @htilburgs
                      Add “symbol” to each calendar in your calendar config.
                      https://docs.magicmirror.builders/modules/calendar.html#configuration-options
                      The icon symbol derives from “font-awesome”.
                        MMRIZE @Babene1
                        @Babene1
                        Use timeFormat: “dateheaders”, in your calendar config.
                          htilburgs @MMRIZE
                          @MMRIZE Thanks, I’m currently using MMM-MyCalendar but I’m going to give it a try this evening.
                            htilburgs @htilburgs
                            @MMRIZE I’ve succesfully configured the calendar, but I’m looking how to add different icons to calendar items.
                            Example: checkered-flag to F1 time, calendar to appointment, etc.
                            I’ve looked in the manual, but I think I miss it. Do you have an example?
                              MMRIZE @htilburgs
                              @htilburgs
                              			header: "US Holidays",
                              						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
        symbol: "car", // <==this.
                              You can find other symbols in font-awesome.
                              https://fontawesome.com/
                                htilburgs @MMRIZE
                                @MMRIZE Oke, so if I understand correct, you add a symbol to a calendar and not to a calendar line?
                                  MMRIZE @htilburgs
                                  @htilburgs I edited original post (my bad, typed on iPhone)
                                    htilburgs @MMRIZE
                                    @MMRIZE So now my F1 Calendar looks like this.
                                    Do you know if it’s possible to get the date and time underneed an item instead of behind?
                                      MMRIZE @htilburgs
                                      @htilburgs
                                      By default, NO. It is coded as table so you cannot adjust it by only CSS without source modification.
                                      You might have 3 options.
                                      • modifying original source. But you will have some annoying issues on next update.
                                      • Use other module equivalent which has that chance, But only module I know is my “MMM-CalendarExt3Agenda”, and you might need somewhat tweaks on CSS.
                                      • Or you can use “MMM-ModuleMonkeyPatch”(the original subject of this thread!!!) to patch source without worrying update issue.
                                        htilburgs @MMRIZE
                                        @MMRIZE
                                        Oke, thanks for the quick reply. I leave it as is at the moment. It looks great. I’m going to give it a look on an other moment.
                                          Babene1 Project Sponsor @MMRIZE
                                          @MMRIZE Thank you very much, I have overlooked it. You make my day :-)
