    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 87.6k Views 16 Watching
      Mykle1 Project Sponsor Module Developer @pjkoeleman
      @pjkoeleman said in MMM-doomsDay - The countdown module,:
      With time set to 23:59 the module is changing at 0:44. The question is were is the offset off 45 minutes comming from ?
      I’m not trying to answer for broberg. It’s his module, but I use this module and I’ve had great success with it. It’s possible that the module is changing at 0:44 if you have the default updateInterval: 60 * 60 * 1000, . If you started the mirror at 44 minutes past any hour, then it wouldn’t update until the next 44 minute mark. If this is your case, then your module updated at 23:44 and not again until 0:44. The logical solution would be to set the updateInterval: to a smaller value or launch the module exactly on the hour, if that’s even possible. I don’t know if the module is set to always update at 24:00. If it’s not, then I would humbly request that it be added to the module.
      pjkoelemanP 1 Reply Last reply Reply Quote 1
      • pjkoelemanP Offline
        pjkoeleman @Mykle1
        @Mykle1 You are right, changed it to 10 minutes. now have to wait what happens.
          Ok, let me know how it goes. I’m never awake at midnight so I only see the module in the mornings, and it’s been correct all along for me.
          pjkoelemanP 1 Reply Last reply Reply Quote 0
            pjkoeleman @Mykle1
            @Mykle1 Now it was changing at 00:06 hour so this module works ok with the right config settings.
              Good! I like this module. I’ve been using for a month now for all sorts of reminders. It’s a pretty nifty little module!
                bberg115
                @broberg, thanks for the hard work :) I needed a “days up” counter for the lady friend. I modified the MMM-doomsDay.js so that it shows the number of days that we’ve been dating. I plan on changing the days to “X years, X days” sometime this week but wanted to say thanks!
                edit: nice tag/username
                brobergB 1 Reply Last reply Reply Quote 1
                • brobergB Offline
                  broberg Project Sponsor @bberg115
                  @bberg115 Nice :D (easy to remember the anniversary then haha ;) )
                  My username is my lastname, so it’s easy to remember hahaha
                    bminer1
                    Having an issue with the “toWhat” sticking.
                    I can not get it to change from “Leaving for Paris!”. See my code below:
                    module: ‘MMM-doomsDay’,
                    position: ‘bottom_right’, // This can be any of the regions, best results in center regions
                    doomsDay: “2017-05-07 24:00:00”, // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                    ToWhat: ‘Joeys Wedding in TN!’,
                    updateInterval: 1 * 3600000,
                    singular: ‘more day!’, // what it should say when it’s only one day left, default is Day Left
                    plural: ‘more days’, // what it should say when it’s more days left, default is Days Left
                    // See ‘Configuration options’ for more information.
                    0_1490728574011_upload-95d70689-8dbe-4ab1-b9f6-447b6720a84c
                    • brobergB Offline
                      broberg Project Sponsor @bminer1
                      @bminer1
                      It’s case sensitive
                      toWhat not ToWhat
                        bminer1
                        Thanks! It worked but that was copied and pasted from GitHub. May want to make the change.
                        0_1490728928244_upload-91d7f2b1-ed96-4c2d-b3e8-04cca60299c2
                        • 6
                        • 7
                        • 8
                        • 6 / 8
