    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 88.0k Views 16 Watching
      bminer1
      Also, is there a way to add multiple count downs to the one module or do you duplicate the module with every countdown?
      • brobergB Offline
        broberg Project Sponsor @bminer1
        @bminer1 nice catch, the example was wrong, somehow I missed that!
        (it’s correct in the Configuration list however)
        Multiple instances in the config is the way to go at the moment,
          mydiva
          It is possible to make instead of just days, weeks and days left? Thanks guys
            mydiva
            I did it by myself, thank you anyway for the great module.
            • N Offline
              noelandrews
              Hi all,
              Bringing an old thread back up, just installed and got this module activated. I think I’ve done it correctly as per github but its not working. It just displays the ‘finished’ message the death and despair bit.
              Can anyone tell me what silly obvious thing I’ve done wrong? Config in the pic below
              justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
              • justjim1220J Offline
                justjim1220 Module Developer @noelandrews
                @noelandrews
                try removing the comma at the end of the ‘toWhat’ line
                Jim Hallock - 1995
                  Mykle1 Project Sponsor Module Developer @noelandrews
                  @noelandrews said in MMM-doomsDay - The countdown module,:
                  Your config looks fine. I just installed and ran the module without a problem, duplicating your config entry. Are you sure you saved the config after having made the entry or that you are not working a second config? I’ve done that plenty of times.
                  Here is a screenshot of the module working with your config
                      module: 'MMM-doomsDay',
                      position: 'bottom_center', // This can be any of the regions, best results in center regions
                          doomsDay: "2019-07-22 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                          toWhat: "Leaving for the USA!",
                  If it continues to give you trouble, you could try https://github.com/mykle1/MMM-EventHorizon which does basically the same thing, with a few more options, as well as a working countdown timer.
                  • N Offline
                    noelandrews
                    Thanks guys, very weird. The config is exactly as you have copied straight from github. I’ll give Event Horizon a shot.
                    • zdenekZ Offline
                      zdenek
                      hi all
                      is there way how to countdown to repeating annivesary? smthg like
                              doomsDay: "XXXX-12-24 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                              toWhat: "X-MASS",
                      ? for x-mass (for kids), marriage anniversary, yearly TAX payment…
                      thanks,
                      Zdeněk
                        doubleT Module Developer
                        @zdenek Even though I think it’s possible with a few changes to the code, I don’t think this would fit the scope of this module, which is to manually set a countdown to one specific event (noteven a few, right?) but not for a whole list of calendar dates.
                        Even if the code ignores the year and just always shows the next event, does it make sense to have it display “364 days left” right the next day?
                        Anyway, if you want to do that, I’d suggest adding:
                            doomsDay: "2018-12-24 24:00:00",
                            yearlyEvent: true,
                            toWhat: "X-Mass"
                        The most simple simple change to the code would be to add this at line 48:
                        if (this.config.yearlyEvent && daysLeft < = 0) {
                            var diff = now.getFullYear() - doomsday.getFullYear();
                            // update doomsday:
                            doomsDay.setFullYear(d.getFullYear() + diff);
                            // calculate again:
                            timeparser = Date.parse(doomsDay) - Date.parse(now);
                            daysLeft = Math.floor(timeparser/(1000*60*60*24));
                        (remove the space between “< =” … )
                        I didn’t test this, though, (and I don’t recommend it).
                        zdenekZ 1 Reply Last reply Reply Quote 0
                        • 6
                        • 7
                        • 8
                        • 7 / 8
