    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 13.2k Views 5 Watching
      schris88 @evroom
      @evroom Hi there, maybe you can confirm, if the inverter has multiple inputs there seems to be an array of pv_data objects in the json (as seen in the test.json you pushed)
      so the meter should combine all pv data power to have the total, right.
      But we dont need to do that by hand because the combined value should be in dtu_power already, you can get rid of all the try except.
      I just didnt change it in the beginning because for inverters with only one input it makes no difference because its pv_data power and dtu_power is always the same value.
      evroomE 2 Replies Last reply Reply Quote 0
      • evroomE Offline
        evroom @schris88
        @schris88
        First of all, those are details I need to have a look at now that the basis is there.
        Perhaps there are other values and queries that make sense and that I can use. Like dtu_power and dtu_daily_energy.
        Also saving some data to not have counters showing 0 when the invertor is inactive needs to be implemented.
        During testing I found out that the pv_data for port 1 and 2 were different sometimes and that is why I needed to add those checks.
        And they can never hurt. Better to be safe than sorry.
        Furthermore, when you have only 1 panel connected, it is needed anyway.
        MagicMirror version: 2.36.0
        • evroomE Offline
          evroom @schris88
          @schris88
          Just FYI, I declare(d) more parameters than really necessary and actually used, in order to allow for more counters to display.
          For example a gauge for each panel; more details on the energy production of each panel; etc.
          I will make a remark about this in the code.
            schris88 @evroom
            @evroom That sounds good, but we should loop through the pv_data objects and display each as a graph. In the end, there could be a config setting like detailed: true to activate the display of all pv_data objects as individual graphs. If set to false, we could display a single graph with the total power.
            There are Hoymiles inverters with 6 inputs, and adding 6 × 6 to 8 variables can quickly add up. This might not be an issue for us, but it’s worth considering if the module should be as generic as possible.
            Sorry I´m a IT-Consultant who, sometimes it breaks through :D
              schris88 @schris88
              @schris88 Recently worked on it a bit and added a second branch with local mongodb to save and display max power, Im planning to use the db entries to display a history chart
                Jose1701
                Hallo,
                ich bin reltiv neu hier und versuche gerade das modul zu installieren.
                Ich habe soweit alles nach Anleitung gemacht, aber wenn ich ./HoymilesWifi.sh starte kommt immer folgende Meldung:
                 * Serving Flask app 'hoymiles_data'
                 * Debug mode: off
                Address already in use
                Port 5000 is in use by another program. Either identify and stop that program, or start the server with a different port.
                Was mache ich falsch? Der port ist angeblich durch pthon belegt …
                Danke und Grüße
                Florian
                evroomE 1 Reply Last reply Reply Quote 0
                • evroomE Offline
                  evroom @Jose1701
                  @Jose1701
                  Try this to find out what is using port 5000:
                  sudo netstat -apln | grep -w 5000
                  And did you update the bash program?
                  https://github.com/schris88/MMM-Hoymiles-Wifi?tab=readme-ov-file#enter-dtu-ip-address-of-dtu
                    Jose1701 @evroom
                    @evroom
                    Thanks for the quick answer.
                    I inserted the IP of the dtu.
                    Portscan is:
                    tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      64879/python
                    tcp        0      0 127.0.0.1:33698         127.0.0.1:5000          TIME_WAIT   -
                    tcp        0      0 127.0.0.1:5000          127.0.0.1:56374         TIME_WAIT   -
                    tcp        0      0 127.0.0.1:60100         127.0.0.1:5000          ESTABLISHED 71440/exe
                    tcp        0      0 127.0.0.1:5000          127.0.0.1:60100         ESTABLISHED 64879/python
                    tcp        0      0 127.0.0.1:52508         127.0.0.1:5000          TIME_WAIT   -
                    tcp        0      0 127.0.0.1:50296         127.0.0.1:5000          TIME_WAIT   -
                    • evroomE Offline
                      evroom @Jose1701
                      @Jose1701
                      This command should give more information on the PID found:
                      ps -Flww -p
                      E.g.
                      ps -Flww -p 64879
                      Perhaps there are easier ways, but this should do.
                        Jose1701 @evroom
                        @evroom
                        Seems that this is hoymiles …?
                        F S UID          PID    PPID  C PRI  NI ADDR SZ WCHAN    RSS PSR STIME TTY          TIME CMD
                        0 S florian    64879   64878  1  80   0 - 59630 do_sys 137520  1 16:11 ?        00:05:02 python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
                        • evroomE Offline
                          evroom @Jose1701
                          @Jose1701
                          Yes, so an instance is already running.
                          You added it to pm2 too?
                          pm2 status
                          If yes, then you do not need to run it manually.
                          If no, then kill the (p)pid.
                          sudo kill -9 [ppid]
                            Jose1701 @evroom
                            @evroom
                            Well, I’ve done that now. At the moment it is night so I can’t see any output.
                            Will see if it works tomorrow …
                            Thank you. I will post if it runs then.
                            J evroomE 2 Replies Last reply Reply Quote 0
                              Jose1701 @Jose1701
                              Can’t get it to work.
                              I don’t know what I’m doing wrong…
                              Now, Portscan ist about that:
                              tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      1139/python
                              tcp        0      0 127.0.0.1:5000          127.0.0.1:37002         ESTABLISHED 1139/python
                              tcp        0      0 127.0.0.1:57592         127.0.0.1:5000          TIME_WAIT   -
                              tcp        0      0 127.0.0.1:37002         127.0.0.1:5000          ESTABLISHED 6097/exe
                              • evroomE Offline
                                evroom @Jose1701
                                @Jose1701
                                First I would disable the module:
                                $ vi ~/MagicMirror/config/config.js
                                    module: "MMM-Hoymiles-Wifi",
                                    disabled: true,
                                $ pm2 restart MagicMirror
                                I build this command to try to get more info on port 5000:
                                $ for pid in `lsof -i :5000 | grep -v 'PID' | awk '{print $2}' | sort -u`; do echo $pid; ps -Flww -p  $pid; done
                                Hopefully the Forum tool does not change it.
                                Furthermore please verify and supply the following data:
                                $ cd /home/admin/MagicMirror/modules/MMM-Hoymiles-Wifi
                                Check path:
                                $ which hoymiles-wifi
                                $ echo $PATH
                                Check if the path is in the PATH.
                                If not, do (using the path from ‘which’):
                                $ export PATH=$PATH:/home/admin/.local/bin
                                Check config.js:
                                $ grep ':5000' ~/MagicMirror/config/config.js
                                Expected is:
                                { src: 'http://127.0.0.1:5000' },
                                Check HoymilesWifi.sh:
                                $ grep 'dtu_ip_address' HoymilesWifi.sh
                                Expected is your DTU IP address, for example:
                                python hoymiles_data.py --dtu_ip_address 192.168.178.50 --max 800
                                Test run (hoymiles-wifi):
                                $ hoymiles-wifi --host 192.168.178.50  identify-inverters
                                Expected is a response.
                                Test run (HoymilesWifi.sh)
                                $ ./HoymilesWifi.sh
                                Expected is:
                                * Debug mode: off
                                INFO:werkzeug:WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
                                * Running on http://127.0.0.1:5000
                                INFO:werkzeug:Press CTRL+C to quit
                                If you wait a bit some more output is shown.
                                If it works, then I would suggest to stop the ./HoymilesWifi.sh command and do:
                                $ pm2 start HoymilesWifi.sh
                                $ pm2 save
                                $ pm2 status HoymilesWifi
                                $ pm2 logs HoymilesWifi --lines 10
                                If everything is okay, the enable the module again:
                                    disabled: false,
                                evroomE J 3 Replies Last reply Reply Quote 0
                                • evroomE Offline
                                  evroom @evroom
                                  To be honest, for me the MM does not display anything.
                                  Although it is dark, I still expected the graphic with 0 or so.
                                  Or I have to wait a bit longer.
                                  I used
                                  https://github.com/schris88/MMM-Hoymiles-Wifi/
                                  and all the above is correct and running.
                                  A year ago I made a fork and made some changes, of which I think are present in the schris88 version as well.
                                  https://github.com/evroom/MMM-Hoymiles-Wifi/
                                  I will give this one a try when I have time.
                                  PS: it seems that when the microinverter is off-line, you will not see anything. Need to wait for it to be active again.
                                    Jose1701 @evroom
                                    @evroom said in MMM-Hoymiles-Wifi:
                                    $ grep ‘dtu_ip_address’ HoymilesWifi.sh
                                    Until that line everything is ok. After that it says:
                                    grep: HoymilesWifi.sh: No such file or directory
                                      Jose1701 @evroom
                                      This works:
                                      Identify-inverters Response:
                                      {'1412a015f1e3': 'HMS-800W/1000W-2T'}
                                      After that: ./HoymilesWifi.sh
                                       * Debug mode: off
                                        sdetweil @Jose1701
                                        @Jose1701 typo
                                         grep 'dtu_ip_address' Hoymiles-Wifi.sh
                                          Jose1701 @sdetweil
                                          Im getting this:
                                          S evroomE 2 Replies Last reply Reply Quote 0
                                            sdetweil @Jose1701
                                            @Jose1701 he just wanted to see the IP address the module was connecting to , which is hard coded in that line
                                            • 2 / 3
