    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 22.7k Views 5 Watching
    • evroomE Offline
      evroom @Jose1701
      @Jose1701
      First of all, where I write
      /home/admin/
      please use
      (tilde sign)
      And can you please send me:
      cd ~/MagicMirror/modules/MMM-Hoymiles-Wifi
      git branch
      git remote -v
      Every time you get that port in use error, run the long command to see what programs are using the port.
      And of course do not use HoymilesWifi.sh when it is also active under pm2.
      I am starting to wonder if the module works at all.
      I finally got a picture, but it showed an error in it.
      MagicMirror version: 2.37.0
      • evroomE Offline
        evroom @Jose1701
        @Jose1701
        You also might try this module:
        https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
        I may give it a try myself.
          Jose1701 @evroom
          @evroom
          * master
          origin  https://github.com/schris88/MMM-Hoymiles-Wifi (fetch)
          origin  https://github.com/schris88/MMM-Hoymiles-Wifi (push)
          I used the ~ symbol.
            Jose1701 @evroom
            @evroom
            Well I tried that but I’m to silly to install it.
            florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ pip3 install hoymiles-wifi
            error: externally-managed-environment
            × This environment is externally managed
            ╰─> To install Python packages system-wide, try apt install
                python3-xyz, where xyz is the package you are trying to
                install.
                If you wish to install a non-Debian-packaged Python package,
                create a virtual environment using python3 -m venv path/to/venv.
                Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                sure you have python3-full installed.
                For more information visit http://rptl.io/venv
            note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
            hint: See PEP 668 for the detailed specification.
            florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ sudo apt install python3 hoymiles-wifi
            Error: Unable to locate package hoymiles-wifi
            evroomE 1 Reply Last reply Reply Quote 0
            • evroomE Offline
              evroom @Jose1701
              @Jose1701
              You installed that already, so no need to install it again.
              Probably using:
              python -m pip install -r requirements.txt --break-system-packages
              The schris88 requirements.txt contains the hoymiles-wifi package.
                Jose1701 @evroom
                @evroom
                By unsing this, I get the following error:
                Defaulting to user installation because normal site-packages is not writeable
                ERROR: Could not open requirements file: [Errno 2] No such file or directory: 'requirements.txt'
                • evroomE Offline
                  evroom @Jose1701
                  @Jose1701
                  If you want to repeat it under the new module name, then you will need to copy the requirements.txt file from the previous module.
                  But again, since you already did this, no need to repeat.
                    Jose1701 @evroom
                    @evroom
                    Okay. But in the end I can’t get it to work. Don’t know whats wrong …
                    Does this has to do with that:
                    florian@raspberrypi:~ $ pm2 restart MagicMirror
                    Use --update-env to update environment variables
                    [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                    [PM2] [MagicMirror](0) ✓
                    │ id │ name            │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                    │ 1  │ HoymilesWifi    │ default     │ 2.33.0  │ fork    │ 3691100  │ 0      │ 367… │ stopped   │ 0%       │ 0b       │ florian  │ disabled │
                    │ 0  │ MagicMirror     │ default     │ 2.33.0  │ fork    │ 3691094  │ 0s     │ 3    │ online    │ 0%       │ 3.0mb    │ florian  │ enabled  │
                    • evroomE Offline
                      evroom @Jose1701
                      @Jose1701
                      Yeah, stopped is not good.
                      I will need to get it working myself before I can give more useful information on what to check.
                      Will keep you posted.
                      • evroomE Offline
                        evroom @evroom
                        @Jose1701
                        Remove the old module from the config:
                        $ vi ~/MagicMirror/config/config.js
                        Remove the "MMM-Hoymiles-Wifi" config, or set:
                            module: "MMM-Hoymiles-Wifi"
                            disabled: true,
                        Delete HoymilesWifi from pm2:
                        $ pm2 stop HoymilesWifi
                        $ pm2 delete HoymilesWifi
                        $ pm2 save
                        If desired, completely remove the old module:
                        $ cd ~/MagicMirror/modules/
                        $ rm -rf MMM-Hoymiles-Wifi
                        Install MMM-HoymilesPVMonitor:
                        $ git clone https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git
                        $ cd MMM-HoymilesPVMonitor
                        $ git branch
                        * main
                        $ git remote -v
                        origin	https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git (fetch)
                        origin	https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git (push)
                        $ which hoymiles-wifi
                        /home/admin/.local/bin/hoymiles-wifi
                        $ echo $PATH
                        /home/admin/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                            module: "MMM-HoymilesPVMonitor",
                            disabled: false,
                            header: "PV Monitor",
                              dtuIp: "192.168.178.50",        // IP address of your Hoymiles DTU
                              maxPower: 800,                  // Maximum system power in watts
                              updateInterval: 5 * 60 * 1000   // Update interval in milliseconds (default: 5 minutes)
                        $ grep 'dtuIp' ~/MagicMirror/config/config.js
                        $ ls -als public/history_daily.json
                        4 -rw-r--r-- 1 admin admin 115 Nov  6 08:47 public/history_daily.json
                        $ cat public/history_daily.json
                            "timestamp": "2025-11-06 08:47",
                            "power": 40,
                            "energy_daily": 0.03,
                            "energy_total": 0.8
                        $ pm2 flush
                        $ pm2 status MagicMirror
                        │ 0  │ MagicMirror    │ default     │ 2.33.0  │ fork    │ 26202    │ 4m     │ 3    │ online    │ 0%       │ 2.1mb    │ admin    │ enabled  │
                        $ pm2 logs MagicMirror --lines 100
                        0|MagicMir | [2025-11-06 08:47:43.474] [INFO]  [MMM-HoymilesPVMonitor.js:17:9] MMM-HoymilesPVMonitor started with DTU-IP: 192.168.178.50
                        0|MagicMir | [2025-11-06 08:47:49.226] [LOG]   [MMM-HoymilesPVMonitor] Running Python script: python3 /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/dtu_data.py --ip 192.168.178.50 --max 800 --out /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/public/history_daily.json
                        0|MagicMir | [2025-11-06 08:47:51.682] [LOG]   [MMM-HoymilesPVMonitor] Python script output: [WARNING] Could not load history: Expecting value: line 2 column 1 (char 1)
                        0|MagicMir | [2025-11-06 08:47] [INFO] Live DTU data appended: {'timestamp': '2025-11-06 08:47', 'power': 40, 'energy_daily': 0.03, 'energy_total': 0.8}
                        0|MagicMir | [2025-11-06 08:52:42.141] [LOG]   [MMM-HoymilesPVMonitor] Running Python script: python3 /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/dtu_data.py --ip 192.168.178.50 --max 800 --out /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/public/history_daily.json
                        0|MagicMir | [2025-11-06 08:52:43.287] [LOG]   [MMM-HoymilesPVMonitor] Python script output: [2025-11-06 08:52] [INFO] Live DTU data appended: {'timestamp': '2025-11-06 08:52', 'power': 41, 'energy_daily': 0.03, 'energy_total': 0.8}
                            "power": 40,
                            "energy_total": 0.8
                            "timestamp": "2025-11-06 08:52",
                            "power": 41,
                            "energy_total": 0.8
                        Tested on:
                        $ cat /proc/device-tree/model; echo
                        Raspberry Pi 3 Model B Plus Rev 1.3
                        $ vcgencmd get_config total_mem
                        total_mem=1024
                        $ grep version ~/MagicMirror/package.json
                        	"version": "2.33.0",
                          Jose1701 @evroom
                          @evroom
                          Great job! It could work for me. Unfortunately it’s dark outside but I can see the gauge on my mirror.
                          I don’t even dare to ask, but do you have a hint how about resizing it? I tried it with width and height but it won’t work.
                              disabled: false,
                              width: "100px",
                              height: "105px",
                                dtuIp: "192.168.178.150",        // IP address of your Hoymiles DTU
                          Many thanks and kind regards
                          Florian
                          S evroomE 2 Replies Last reply Reply Quote 0
                            sdetweil @Jose1701
                            @Jose1701 said in MMM-Hoymiles-Wifi:
                            width: "100px",
                            height: "105px",
                            those are outside the config:{} section, that means they are for the MM runtime…
                            but we don’t process width/height
                            if you want to do this you need to learn to use css(cascading style sheet) to customize the html presentation
                            ALL updated css goes in css/custom.css
                            a css entry in custom.css is
                            selector_clause {
                               styles to apply to elements selected by the selector clause
                            we add the modulename as a class to the web content so that one can ‘select’ only for that module
                            key selector clause elements
                            starts with . means element has classname=xxx
                            starts with # means element has id=xxxx
                            does not start with either, means html element name, div, span, p, h1, img…
                              Jose1701 @sdetweil
                              Alright, I will try to get some info in the internet. Never done sth with css.
                                sdetweil @Jose1701
                                @Jose1701 I understand , the browser provides a developer environment with different capabilities
                                logger
                                code execution
                                and elements viewer, css tester env
                                see the second link in my signature below for a starter course on the elements tab.
                                • evroomE Offline
                                  evroom @Jose1701
                                  @Jose1701
                                  No, sorry, no idea.
                                  What Sam says, but that needs knowledge.
                                  But I opened an issue/request, so let’s see if it will be granted:
                                  https://github.com/CuddlyCow/MMM-HoymilesPVMonitor/issues
                                    Jose1701 @evroom
                                    @evroom
                                    ok. Thank you for your patience and help.
                                      sdetweil @Jose1701
                                      @Jose1701 also. Sometimes the author documents it on the readme, sometimes the author provides their own css you can override w custom.css entries
                                      Sometimes it’s all grunt work….
                                        Jose1701
                                        I spent a bit of time an got the following to work by using help of a friend.
                                        I wrote the following in the css:
                                        /* custom.css */
                                        /* Passt die Gesamtbreite des gesamten Moduls an */
                                        .MMM-HoymilesPVMonitor {
                                            /* Beispiel: Setzt die maximale Breite des gesamten Moduls auf 200 Pixel */
                                            max-width: 200px;
                                            /* Stellt sicher, dass das Modul zentriert bleibt, falls es kleiner als die Spalte ist */
                                            margin-left: auto;
                                            margin-right: auto;
                                          Passt den inneren Container an, der das Canvas-Diagramm enthält.
                                          Dies überschreibt die 95% Breite, die im JS definiert wurde.
                                        .MMM-HoymilesPVMonitor div:first-child {
                                              Setzt die Breite des Containers auf 100% der oben definierten max-width (z.B. 200px).
                                              Sie können hier auch absolute Werte (z.B. 180px) verwenden,
                                              aber 100% ist am flexibelsten.
                                            width: 100% !important;
                                        Now it is smaller, nevertheless I can’t get it much more smaller because the gauge will disappear then.
                                        (It’s not displayed correctly in the screenshot, but it is on my mirror.)
                                        • 3 / 3
