    New Raspberry Pi Zero W
    13 Posts 7 Posters 12.7k Views 6 Watching
    • strawberry 3.141S
      There is a new Pi Zero with wlan and bluetooth
      https://www.raspberrypi.org/blog/raspberry-pi-zero-w-joins-family/
      Mykle1M jproehlJ 2 Replies Last reply
      Reply Quote 1
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @strawberry 3.141
        @strawberry-3.141 That’s hot!
        • cowboysdudeC
          cowboysdude Module Developer
          Thanks!! Got one on backorder :) Going to use it for this:
          http://www.hestiapi.com/home
            SoleLo
            Damn, I was just about to buy a regular 3 …I’ll wait…
            Reply Quote 1
            • jproehlJ
              jproehl @strawberry 3.141
              @strawberry-3.141 Can the newly released RPI Zero W be used in place of an Rpi 3? I tried to swap my microSD card from an RPi 3 into a Pi Zero v1.3 and got an error on trying to start the Magic Mirror saying that the Pi Zero does use an acceptable version of some software.
              Has anyone ported the Magic Mirror source code so that it does work on an RPi Zero? If so, is that code available? If not, how difficult would it be to port it for the RPi Zero W??
              cowboysdudeC 1 Reply Last reply
              • cowboysdudeC
                cowboysdude Module Developer @jproehl
                @jproehl There’s a forum here that another person got it to run on a Pi Zero I believe…
                https://forum.magicmirror.builders/topic/1711/pi-zero-mm
                https://forum.magicmirror.builders/topic/800/code-for-running-mm-on-pi-zero
                https://forum.magicmirror.builders/topic/98/pi-zero/11
                jproehlJ 1 Reply Last reply
                • jproehlJ
                  jproehl @cowboysdude
                  @cowboysdude Great! Thanks, I’ll check it out. I’m trying to make a very compact mirror and the Pi Zero would assist the design, especially with the new wireless version of the Pi Zero just released.
                  strawberry 3.141S 1 Reply Last reply
                  Reply Quote 1
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @jproehl
                    @jproehl keep in mind that it has way less power than a rpi 3, some modules could “freeze” your mirror
                    Reply Quote 1
                    • jproehlJ
                      @strawberry-3.141 Good point, thanks for the reminder. Maybe I’ll just stick with the RPi 3. The frame I’m making for my mirror will be two layers of 3/4" maple (I had some left over flooring material), since I’ve heard the RPi 3 can run a bit hotter than the other RPi models, would it be a good idea to leave off the top board on the back row (next to the wall) to allow for the heat to exit from behind the mirror?
                      • M
                        McSorley
                        Bought one to swap out my raspberry pi 3 for another project. Starting from scratch, the curl script command doesnt work. What is the best way to get node.js installed from Pixel?
                        • cowboysdudeC
                          cowboysdude Module Developer @McSorley
                          @McSorley check here ->
                          http://raspberrypi.stackexchange.com/questions/48303/install-nodejs-for-all-raspberry-pi
                          and here
                          https://blog.miniarray.com/installing-node-js-on-a-raspberry-pi-zero-21a1522db2bb
                          M 1 Reply Last reply
                          • M
                            McSorley @cowboysdude
                            @cowboysdude Thanks for that, managed to get it installed.
                            Currently trying to get docker running, their guide on their site isn’t as simple as installing these modules xD
                            Reply Quote 1
                            • M
                              maddy2610
                              I have bought Rasberry pi from http://www.w11stop.com/manufacturer-raspberrypi and it has USB (and ethernet) which is not working… i am confuse i can’t understand that is my software is too old or there is a SD card issue NOOBS issue…
                              i have stucked in this… please can anyone can help me out from this…!!!
