    Cant figure out how to install a module in the config.js
    19 Posts 5 Posters 12.8k Views 4 Watching
    • E Offline
      Edswald
      Hello im a student making the magic mirror project on my raspberry pi. I have installed the 3rd party modules in the modules directory but when when i try to add the module to the config.js and run the program it tells me theirs a error in my configuration file. do i add modules under the default modules or do i put then under the line that says “dont edit this text below”. i have tried adding the module both ways and it stil tells me somethings wrong with my config.js. i have also tried to install different modules and add them to the config.js with no luck. I think im doing something wrong but i cant figure out what. And i have followed the install instruction step by step.
      • W Offline
        wizz
        @Edswald Post your config.js and with the installed module you got problem with so we can see that and see whats wrong. also all modules have to be under the default modules and not under the line that says “dont edit this text below”
          Mykle1 Project Sponsor Module Developer @Edswald
          @Edswald
          Here is an example of how to add a module to your config.js file. In this case, I am adding MMM-EARTH between the “clock” module and the “MMM-Cocktails” module. Notice how the clock module entry ends with },. The MMM-EARTH module begins with { and then ends with },. You will find the entry in the README for each module.
          			module: 'clock',
          			position: 'top_left'
              			module: "MMM-EARTH",
              			position: "bottom_center",
          			useHeader: false,
          			header: "NASA's EPIC Camera",
                  		rotateInterval: 15000,
                  		MaxWidth: "75%",
                 			MaxHeight: "75%"
              			module: "MMM-Cocktails",
              			position: "bottom_left", // Small footprint - Fits anywhere.
                  		maxWidth: "400px",
                  		header: ""
          • romainR Offline
            romain
            in the config file you should have a modules: [ line. In fact, there should be almost at the end of the file an ]
            This mean modules is an array. ([ value1, value2, etc... ] is an array.
            Every value of the array is a dictionnary (a list of keys associates with a value) . it should look like this
                       key: value,
                       next_key: value,
                       etc..
            Two key/value pair should be separated by a , and two dictionary should be separated by a ,
            as an example
                       key: value,
                       next_key: value,
                       etc..
                       key: value,
                       next_key: value,
                       etc..
            the , is very important because without it, it does’nt understand it changed value and you end up with an error because it doesn’t understand why you put a { or a : in the middle of an unfinished value
            What you should know is this : a [ is always closed by a ], if you having one without the other few characters later somethings is wrong. a { is always closed by a }, if you having one without the other few characters later somethings is wrong.
            two element in the same array should be separeted by ,. same thing with two element in a dictionnary.
            If you have a config issue it probably mean you forgot one of the following , { } [ ] : somewhere.
            Since you probably just copy past the config in the readme, my best bet is that you either forgot the first { or the last }, . Or maybe the configuration didn’t put a , at all at the end in their example because it suppose you add it at the end of the array. In that case
            The last element of the array might not have a , because it’s the last element. So if you add an alement after it, you have tu put it yourself.
            Hopefully that was clear enough
            • E Offline
              Edswald
              ok so here how my config file looks like i blacked out my twitter info but i think its right i dont know and thanks for everyone how is helping me with this your awesome!!!0_1493046075374_17bf40e2880333d8695ffe5511d2d047.png
              romainR 1 Reply Last reply Reply Quote 0
              • romainR Offline
                romain @Edswald
                @Edswald you didn’t put the module info at the right place and you missing
                        paths: {
                                modules: "modules",
                                vendor: "vendor"
                just before the do not edit the line bellow.
                Your file should look like this at the end
                                        module: "newsfeed",
                                        position: "bottom_bar",
                                                feeds: [
        title: "New York Times",
                                                showSourceTitle: true,
                                                showPublishDate: true
                			module: 'twitControl',
                			position: 'top_left',
                				maxNumTweets: 5,
                				streamType: 'followings',
                				api_keys: {
                					consumer_key: 'YOUR CONSUMER KEY',
                					consumer_secret: 'YOUR CONSUMER SECRET',
                					access_token_key: 'YOUR ACCESS TOKEN KEY',
                					access_token_secret: 'YOUR ACCESS TOKEN SECRET'
                        paths: {
                                modules: "modules",
                                vendor: "vendor"
                • E Offline
                  Edswald
                  ok so is this correct or am i suppose to put somthing in where it says modules and vendor. Its till not running 0_1493057568851_2017-04-24-120637_1280x1024_scrot.png
                  • brobergB Offline
                    broberg Project Sponsor @Edswald
                    @Edswald 0_1493058241706_1493057570459-2017-04-24-120637_1280x1024_scrot.jpg
                    And for future reference, past the contents of the config in text format on the forum, it will be easier to see all of the config file then.
                    • E Offline
                      Edswald @broberg
                      @broberg is this right me an my team mate are here trying to see if we missed anything. Its still not running.0_1493061502651_2017-04-24-131726_1280x1024_scrot.png
                      • brobergB Offline
                        @Edswald post it as text. can’t help you with only a screenshot
                        • E Offline
                          Edswald @broberg
                          @broberg ok here you go
                          /* Magic Mirror Config Sample
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
                          	language: "en",
                          	timeFormat: 24,
                          	units: "metric",
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_left"
                          			header: "US Holidays",
                          						symbol: "calendar-check-o ",
                          						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                          			module: "compliments",
                          			position: "lower_third"
                          			module: "currentweather",
                          				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                          				appid: "YOUR_OPENWEATHER_API_KEY"
                          			module: "weatherforecast",
                          			header: "Weather Forecast",
                          				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                          			module: "newsfeed",
                          				feeds: [
                          				maxNumTweets: 5,
                          				api_keys: {
                          • brobergB Offline
                            You are using the wrong quotations,
                            you are using ’ when you should use '
                            and “ when you should use "
                            so first of change
                            ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
                            to
                            and
                            module: ‘twitControl’,
                            position: ‘top_left’,
                            maxNumTweets: 5,
                            streamType: ‘followings’,
                            api_keys: {
                            consumer_key: ‘ ’,
                            consumer_secret: ‘ ’,
                            access_token_key: ‘ ’,
                            access_token_secret: ‘ ’
                            to
                            module: "twitControl",
                            maxNumTweets: 5,
                            api_keys: {
                            consumer_key: ' ' ,
                            consumer_secret: ' ',
                            access_token_key: ' ' ,
                            access_token_secret: ' '
                            And do edit your post above to remove your personal keys!
                            E 1 Reply Last reply Reply Quote 1
                            • E Offline
                              Edswald @broberg
                              @broberg Thank you very much it worked finally :)
                              brobergB 1 Reply Last reply Reply Quote 1
                              • brobergB Offline
                                @Edswald Glad to hear it!
                                • E Offline
                                  Edswald @broberg
                                  @broberg umm can you help me again now im trying to install another twitter module with no luck :(
                                  • E Offline
                                    Edswald
                                    • By Michael Teeuw http://michaelteeuw.nl
                                    • MIT Licensed.
                                    var config = {
                                    port: 8080,
                                    language: "en",
                                    timeFormat: 24,
                                    units: "metric",
                                    		module: "alert",
                                    		position: "top_bar"
                                    		module: "clock",
                                    		module: "newsfeed",
                                    			feeds: [
                                    maxNumTweets: 5,
                                    api_keys: {
                                    consumer_key: ‘fill’,
                                    consumer_secret: ‘fill’,
                                    access_token_key: ‘fill’,
                                    access_token_secret: ‘fill’
                                    module: ‘MMM-TwitterTrendsByPlace’,
                                    position: ‘bottom_left’,
                                    // visit the url below for the twitter keys/tokens
                                    // https://dev.twitter.com/oauth/overview/application-owner-access-tokens
                                    access_token_secret: ‘fill’,
                                    // set the display name/title for the place
                                    placeName: ‘New York, NY’,
                                    // set the woeid for the place, see documentation for more
                                    // http://woeid.rosselliot.co.nz/lookup/
                                    placeWoeid: ‘2459115’,
                                    if (typeof module !== “undefined”) {module.exports = config;}
                                    • E Offline
                                      Edswald
                                      • brobergB Offline
                                        @Edswald you have to place the modules within the brackets
                                        If you go back to the picture where I marked that you should move two brackets you will see which ones I mean.
                                        And when you post your config files delete your sensitiv data (like api-keyes)
                                        • E Offline
                                          Edswald @broberg
                                          @broberg Ahhh i see what you mean thank you again :)
