    MMM-MyCommute
    286 Posts 80 Posters 682.3k Views 77 Watching
      Blackmirror
      This module is great, but it was nicer, to take starttime and endtime for the different destinations.
      So, I will go to work in the morning, soIneed this only between 5.00 and 6.00 o’clock and if I will go to the salsa party I need this only in the evening.
        j.e.f.f Project Sponsor Module Developer @joela85
        @joela85 I just did a quick test on my laptop by changing the clock to mover forward a day at a time, and I had the module disappear and reappear consistently. I’ve set my config to startTime: '06:00' and endTime: '09:00' and I’ll let it run overnight to see if I can recreate your issue.
        I also like the Mon-Fri idea, as well as the individual time windows per destination. Will work on them over the next few days.
          j.e.f.f Project Sponsor Module Developer @Blackmirror
          @Blackmirror I ran a test overnight and my module came back on when it should have. But I did realize there is a fundamental problem with how I’ve architected the data pull. Are you using two instances of this module? If so I’m thinking that may be causing problems and possibly yours. I’m going to write an update soon, and I’ll have you try again.
          • joela85J Offline
            joela85
            I just went back into my config and noticed on one of the times I used a semicolon instead of the colon. I must have looked at that 20 times and not noticed it. Maybe just needed some fresh eyes on it. Hopefully that will sort it. I only have one instance of this module.
              @joela85 ha! I should have thought to ask for your config. In any case, I’ve pushed an update that fixes the support for multiple instances of the module.
              Of note is that you now configure the header in the standard way instead using the “headerText” and “showHeader” configurations. I thought I needed to do it this way when showing and hiding, but it turned out not be the case. So if your config looked like this before:
                    module: 'MMM-MyCommute',
                    position: 'top_left',
                    classes: 'default everyone',
                      showHeader: true,
                      headerText: 'Traffic',
              change it to this:
                    header: 'Traffic',
              If you don’t want a header, then just omit it.
              Will be working on configs for limiting to Mon-Fri and windowing for individual destinations next.
              bheplerB 1 Reply Last reply Reply Quote 1
                MMM-MyCommute has been updated with some new configuration options
                • You can now specify hideDays with a list of days during which the module is hidden. You specify an array of numbers, 0=Sunday, 6=Saturday. To hide it on weekends, for example, specify hideDays: [0,6].
                • startTime, endTime, and hideDays parameters are now available as options for each individual destination. It should be noted that these parameters are superseded by the same ones specified in the main config. That means that if the main config parameters cause the module to be hidden as a whole, none of the destinations will be listed, regardless of their window settings.
                Thanks for all your suggestions! This has evolved into a very robust module and I’ve learned quite a bit in the process.
                Enjoy!
                -Jeff
                B 1 Reply Last reply Reply Quote 5
                • bheplerB Offline
                  bhepler Module Developer @j.e.f.f
                  @j.e.f.f said in MMM-MyCommute:
                  Aha. Very nice. If you get the chance, please update the README with this information. It changed on me and I couldn’t figure it out for a while.
                    Blackmirror @j.e.f.f
                    @j.e.f.f Nice, I will test it at the weekend.
                      alberttwong
                      Why isn’t this in the master list of modules at https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules
                        j.e.f.f Project Sponsor Module Developer @alberttwong
                        @alberttwong There are many MANY modules that aren’t in that list… just browse the Modules section of this forum and you’ll find lots.
                        I’m assuming the “master” list needs to be maintained by the author of MagicMirror, while any of us can post to the forum.
                        Does anyone know if the “master” list is even maintained anymore, and how we get it updated with the missing modules?
                        • yawnsY Offline
                          yawns Moderator
                          Just open the list, click on edit and add your modules to the list.
                          Amazing work with the commute module! Oh, I added the module developer badge to your profile
                            j.e.f.f Project Sponsor Module Developer @yawns
                            @yawns Thanks! I’ll add my modules to the list.
                            • lucallmonL Offline
                              lucallmon
                              @j.e.f.f - loving the module. However, I’m trying to add a single trip with multiple stops and multiple methods of transportation. Here’s the situation:
                              I live in MD; I want to drive from my home to the nearest DC metro station, get on the metro to my work in downtown DC.
                              This uses driving first, then subway. The module sets a global ‘origin’ with multiple potential destinations. Essentially, how I see it, I need to change origins for each stop, thus, creating multiple module instances.
                              Is there a way to create multiple stops with differing origins?
                                j.e.f.f Project Sponsor Module Developer @lucallmon
                                @lucallmon the Google API supports waypoints, but I think all stops on the route need to be the same mode of transportation. I’m not even sure you can do what you want just using regular google maps.
                                I think using multiple instances is your only option here…
                                • brandongomezB Offline
                                  brandongomez
                                  Hi all. New to the forum and the world of magic mirror. It’s awesome! Came across this module and have been trying to implement but think I’m getting stuck on the API key.
                                  When I go to Google, I have web and web service. I am assuming this is web and not web service. Then when I choose web, I get more options; Maps JavaScript API, Maps Embed API, Street View, Static Maps, Places API JavaScript Library. I believe it’s Maps JavaScript API. Can anyone confirm that?
                                  The module is not coming up on my board so I think my API might be wrong? Any help is appreciated. Thanks!
                                  Update: I re-installed the module and it now loads but just shows the locations with a red “Error” next to each of them. My code is posted below if that helps. It also isn’t showing the “Traffic” header which is odd.
                                  Another Update: Working now! I found the log files and it was the API. Got that fixed and now it’s working. Only thing that isn’t working is the title. For some reason the header doesn’t show. Any ideas?
                                                          position: 'top_right',
        showHeader: true,
        apikey: 'xxxxxxxxx',
        origin: '.........',
        startTime: '00:00',
        endTime: '23:59',
        hideDays: [0,6],
        destinations: [
        destination: '..........',
        label: 'Emerson Parkside Academy',
        mode: 'driving',
        color: '#82E5AA'
        destination: 'Yosemite, CA',
        label: 'Yosemite',
        mode: 'driving',
        color: '#82E5AA'
        destination: '1313 Disneyland Dr, Anaheim, CA 92802',
        label: 'Disneyland',
        mode: 'driving',
        color: '#82E5AA'
                                    j.e.f.f Project Sponsor Module Developer @brandongomez
                                    @brandongomez The header is not configured that way anymore. Use the standard way, like so:
                                        header: 'Traffic',      //-------- here
                                    otherwise, glad to hear you got it working.
                                    -Jeff
                                    brandongomezB L 2 Replies Last reply Reply Quote 0
                                      brandongomez @j.e.f.f
                                      @j.e.f.f Awesome, thanks for the quick reply and help!
                                      • L Offline
                                        Looking @j.e.f.f
                                        Question. I have posted the above config in my config.js file but MM does not showing anything additional regarding TRAFFIC.
                                        J L 2 Replies Last reply Reply Quote 0
                                          j.e.f.f Project Sponsor Module Developer @Looking
                                          @Looking not sure I’m following… can you post your confit here? Hide your API key.
                                          • L Offline
                                            Looking @Looking
                                            Here is what I pasted… I am sure it is something real goofy. I did get an API KEY from Google. Maybe there was addition code I needed to put else where. This is my first time project with MM. Really cool.
                                            CODE:
                                            module: ‘MMM-MyCommute’,
                                            header: ‘Trafic’,
                                            position: ‘top_right’,
                                            showHeader: true,
                                            //------ headerText: ‘Traffic’,
                                            apikey: ‘PUT IN GOOGLE API’,
                                            origin: ‘PUT MY ADDRESS. 123 ST, TOWN, ST ZIPCODE’,
                                            startTime: ‘00:00’,
                                            endTime: ‘23:59’,
                                            hideDays: [0,6],
                                            destinations: [
                                            destination: ‘PUT IN WORK ADDRESS’,
                                            label: ‘Emerson Parkside Academy’,
                                            mode: ‘driving’,
                                            color: ‘#82E5AA’
                                            Your help would be greatly appreciated. Thank you!
                                            • 14
                                            • 15
                                            • 3 / 15
