    Change Modules name
    Scheduled Pinned Locked Moved Forum
    7 Posts 5 Posters 4.9k Views 6 Watching
    • P Offline
      pepemujica
      Hi everyone! I hope you’re finding very well!
      I have a doubt… is it possible to change the modules original name? For example change iFrame for News1
      Kind regards
      • Y Offline
        yawns Moderator @pepemujica
        @pepemujica
        Sure. Change the name of the folder, the name of the module.js and the module name inside the module.js file
        • P Offline
          pepemujica @yawns
          @yawns great, and can I copy the folder, so I have the original module with it’s original name, and the copy with the custom name?
          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @pepemujica
            @pepemujica
            Yes, just make the changes that @yawns stated above
            • cowboysdudeC Offline
              cowboysdude Module Developer @pepemujica
              @pepemujica No.
              If you have [for example] MMM-This and you want MMM-That you have to change the folder name first to MMM-That…
              Now…inside that folder change MMM-This.js to MMM-That.js
              THEN open MMM-That.js and at the top it will have this line ---->
              Module.register(“MMM-This”, {
              That has to be changed to:
              Module.register(“MMM-That”, {
              Save the file…
              NOW some issues you may encounter… IF in MMM-That there is a line like this —>
              getStyles: function() {
              return [“MMM-This.css”];
              That could potentially also need to be changed… IF you change it there you must go into the directory and rename MMM-This.css to MMM-That.css
              IF you do that then you need to open MMM-That.css and inside there will be this ->>>
              .MMM-This .photo {
              width:125px;
              height:125px;
              They ALL have to be changed to MMM-That as well.
              Then you have renamed it …
                shbatm Module Developer
                On the Raspberry Pi, a shortcut to renaming all of the instances of ‘MMM-This’ inside the files is to use the following​ command. Don’t forget to navigate to the new module’s directory!
                find . -type f | xargs sed -i 's/MMM-This/MMM-That/g'
                You still need to rename the actual files.
                  Or, for those not comfortable (yet) with the terminal, just about any text editor (including the Pi’s) can do a “Find and Replace”.
