    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.1m Views 68 Watching
    • evroomE Offline
      evroom @Egnos
      @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      Are there any errors in config.js?
      This is my config that works.
      I think the only real difference is the omxRestart entry.
        module: "MMM-RTSPStream",
        disabled: false,
        position: "bottom_right",
        header: "MMM-RTSPStream Test",
          autoStart: true,
          omxRestart: 1,
          rotateStreams: false,
          moduleWidth: "352px", // Width in px of the module.
          moduleHeight: "240px", // Height in px of the module.
          localPlayer: 'omxplayer',
          remotePlayer: 'none',
          showSnapWhenPaused: false,
          remoteSnaps: false,
          stream1: {
            url: 'rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov',
            frameRate: "25",
            protocol: "tcp",
            width: "352px", // The width in px of the stream.
            height: "240px", // The height in px of the stream.
      MagicMirror version: 2.35.0
      Test environment:
      MagicMirror version: 2.36.0-develop
      • E Offline
        Egnos @evroom
        @evroom many thanks!
        I don’t know why but now I’m viewing the video in MM.
        I haven’t touched anything!
        • E Offline
          Egnos @evroom
          @evroom I finally understood what the problem is … that is VNC.
          I use VNC to connect with the Raspberry PI and for some reason, using the VNC interface, the player is not displayed!
          If instead I turn on the monitor where the Raspberry PI is physically connected I magically see the streaming … whether I run the command from the terminal or with the MM.
          Can you explain this behavior?
          • evroomE Offline
            evroom
            No, I cannot explain this, but I noticed it too.
            No video over the VNC connection.
            When I google, I see this recommendation:
            Open VNC Server>Options>Troubleshooting. Then make sure "enable experimental direct capture mode is checked.
            You might give it a try.
            Test environment:
            • C Offline
              costascontis
              hello,lil help,what do i have to add in custom.css to align MMM-RTSPStream window with the module below?
              https://imgur.com/XQZNEvg
              • E Offline
                Egnos @evroom
                @evroom now, enabling in VNC options “direct capture mode”, also from VNC I see the stream on omxplayer and on MM.
                Many Thanks! 👍
                • I Offline
                  imdickie
                  I’m going from a working Raspi3 to a Raspi4 and using the exact same working module configuration I cannot get video on omxplayer using this module.
                  I set up a pristine image and loaded everything one at a time, but this one fails. I pulled out all of the modules to make sure there was nothing in them that was causing the issue.
                  Below is my module config and my logs pulled using pm2 logs mm. There is an error, but I don’t know enough about this to determine the cause. Can anyone review the logs and provide some direction?
                  Thanks.
                  		    position: "bottom_bar",
                  		        autoStart: true,
                  		        rotateStreams: true,
                  		        rotateStreamTimeout: 10,
                  		        moduleWidth: 642,
                  		        moduleHeight: 362,
                  		        showSnapWhenPaused: true,
                  		        remoteSnaps: true,
                  		        stream1: {
                  		            url: 'rtsp://xxx:xxx@192.168.1.164:554/Streaming/Channels/102/',
                  		            frameRate: '10',
                  		            snapshotType: 'url',
                  		            snapshotRefresh: 10,
                  		            width: 640,
                  		            height: 360,
                  pi@raspberrypi:~ $ pm2 logs mm --lines 100
                  [TAILING] Tailing last 100 lines for [mm] process (change the value with --lines option)
                  /home/pi/.pm2/logs/mm-error.log last 100 lines:
                  0|mm | [2020-04-08 14:17:49.908] [ERROR] TypeError: Cannot convert undefined or null to object
                  0|mm | at Function.keys ()
                  0|mm | at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
                  0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17
                  0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:606:19
                  0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
                  0|mm | at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                  0|mm | at Parser.emit (events.js:200:13)
                  0|mm | at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
                  0|mm | at doWrite (_stream_writable.js:417:12)
                  0|mm | at writeOrBuffer (_stream_writable.js:401:5)
                  /home/pi/.pm2/logs/mm-out.log last 100 lines:
                  0|mm |
                  0|mm | > magicmirror@2.11.0 start /home/pi/MagicMirror
                  0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                  0|mm |
                  0|mm | [2020-04-08 14:17:48.507] [LOG] Starting MagicMirror: v2.11.0
                  0|mm | [2020-04-08 14:17:48.514] [LOG] Loading config …
                  0|mm | [2020-04-08 14:17:48.519] [LOG] Loading module helpers …
                  0|mm | [2020-04-08 14:17:49.292] [LOG] Initializing new module helper …
                  0|mm | [2020-04-08 14:17:49.293] [LOG] Module helper loaded: MMM-RTSPStream
                  0|mm | [2020-04-08 14:17:49.293] [LOG] All module helpers loaded.
                  0|mm | [2020-04-08 14:17:49.399] [LOG] Starting server on port 8080 …
                  0|mm | [2020-04-08 14:17:49.421] [LOG] Server started …
                  0|mm | [2020-04-08 14:17:49.422] [LOG] Connecting socket for: MMM-RTSPStream
                  0|mm | [2020-04-08 14:17:49.423] [LOG] PM2: Stopping all OMXPlayer Streams…
                  0|mm | [2020-04-08 14:17:49.424] [LOG] Sockets connected & modules started …
                  0|mm | [2020-04-08 14:17:49.531] [LOG] Launching application.
                  0|mm | [2020-04-08 14:17:49.908] [LOG] Whoops! There was an uncaught exception…
                  0|mm | [2020-04-08 14:17:49.916] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  0|mm | [2020-04-08 14:17:49.916] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  0|mm | [2020-04-08 14:17:53.508] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 282,1501,922,1861 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx:xxx@192.168.1.164:554/Streaming/Channels/102/
                  0|mm | [2020-04-08 14:17:53.527] [LOG] Starting PM2 for omx_stream1
                  0|mm | [2020-04-08 14:17:53.698] [LOG] PM2 started for omx_stream1
                  • I Offline
                    imdickie
                    Getting closer. Hoping to get some help based on the new info below.
                    I was able to get a video stream, but…
                    It only works in the middle_center position and the video orientation is rotated 90 deg.
                    I tried using the rotateDegree switch, and it does rotate it, but the video frame stays in the portriat oreintation.
                    Video Oreintation
                    I am using the below config file.
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "Family Calendar",
                    				colored: "true",
                    						symbol: "calendar-check-o ",
                    						color: "#34a95f",
                    						url: "https://calendar.google.com/calendar/ical/xxx/basic.ics"
                    						color: "#b1002c",
                    		  module: "MMM-DarkSkyForecast",
                    		  header: "Weather",
                    		  classes: "default everyone",
                    		  disabled: false,
                    		    apikey: "xxx",
                    		    latitude: "33.481613",
                    		    longitude: "-117.061959",
                    		    iconset: "5c",
                    		    concise: false,
                        		    forecastLayout: "table",
                    		    units: "us"
                    		module: 'MMM-RTSPStream',
                    		position: 'middle_center',
                    		    autoStart: true,
                    		    moduleWidth: 642,
                    		    moduleHeight: 362,
                    		    stream1: {
                    			url: 'rtsp://xxx:xxx@192.168.x.xxx:554/Streaming/Channels/102/',
                    			snapshotUrl: '',
                    			snapshotRefresh: 10, // Seconds
                    			frameRate: "30",
                    			width: 640,
                    		        height: 360,
                    			port: 9999,
                    			module: "compliments",
                    			position: "bottom_center"
                    			module: "newsfeed",
                    			position: "bottom_center",
                    				feeds: [
                    						title: "New York Times",
                    				showSourceTitle: true,
                    				showPublishDate: true
                    	            module: 'MMM-GoogleMapsTraffic',
                    	            position: 'bottom_center',
                    	                key: 'xxx',
                    	                lat: xxx,
                    	                lng: -xxx,
                    	                height: '360px',
                    	                width: '360px',
                    	                styledMapType: "",
                    	                disableDefaultUI: true,
                    	                backgroundColor: 'hsla(0, 0%, 0%, 0)',
                    • evroomE Offline
                      evroom
                      @imdickie said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                      In
                      /home/pi/MagicMirror/css/custom.css
                      add
                      .MMM-RTSPStream .innerWrapper {
                        border-style: none;
                      to remove the frame altogether.
                      Or find a way using css to rotate the frame.
                      I tried the positions top_left, top_right, bottom_left and bottom_right.
                      All work.
                      It can be that your other modules are pushing it down.
                      Try to have the module positioned a bit earlier in your config.
                      Test environment:
                      • PointPubMediaP Offline
                        PointPubMedia
                        @shbatm Do you think it could be possible to run this on another plateform, like pine64 with armbian where omxplayer is not available?
                        The npm install part is not working as omxplayer is not available…
                        • K Offline
                          KumarTRD
                          Has anyone had success getting this module to work with Lorex security cameras? The is the only module preventing my magic mirror being “complete”
                          • BKeyportB Offline
                            BKeyport Module Developer
                            1st, have you tried the URL string at https://www.ispyconnect.com/man.aspx?n=Lorex ?
                            2nd, have you verified that the video player you want is able to run the video stream?
                            • C Offline
                              costascontis
                              i am using vlc as local player to play my stream locally just fine.When i try to access MM from my pc (chrome) using http://mmip:8080 ,my stream is not starting at all.Using ffmpeg for remote player and i also test my stream using ffplay and it works just fine at my rpi3b.What is wrong ???
                              • BKeyportB Offline
                                BKeyport Module Developer @costascontis
                                @costascontis Try a different local player. In testing of the last version I used, VLC had an invalid command line. I honestly have abandoned the module totally in favor of an external approach for the camera.
                                • C Offline
                                  costascontis @BKeyport
                                  @BKeyport i dont have any problem with vlc as local player ,my issue is with remote player,ffmpeg.I am trying to see the feed from windows pc with chrome.Every other module is working fine ,the live feed is starting but i only see black,no camera image.
                                  • BKeyportB Offline
                                    @costascontis oh, sorry, I misunderstood.
                                    • Z Offline
                                      zzricezz
                                      I’m assuming if i just have 1 stream, it will most likely cause a burn-in issue? any good idea? like transition between a black backgroup ever minute or so for couple of seconds?
                                      Thanks,
                                      • BKeyportB Offline
                                        BKeyport Module Developer @zzricezz
                                        @zzricezz burn in is mostly a non-issue in modern screens, however, I severely doubt a stream isn’t gonna do anything like that, unless you’re streaming a closet… there’s enough movement on most streams that even things that are locked into place move around (due to encoding bugs, etc)
                                          dwburger
                                          I’ve got this module working with my Wyze camera, but the connection drops and the image freezes after a few minutes. Is there a way to automatically reconnect to the camera from within the module? I can do it by stopping and starting MM2 using PM2, but I’d rather not have to do that every few minutes. Thanks for any help or guidance!
                                          BKeyportB twosquirrelsT 2 Replies Last reply Reply Quote 0
                                          • evroomE Offline
                                            evroom
                                            You can try adding this line to the config:
                                            omxRestart: 1,
                                            Automatically restart the OMX Stream every X hours.
                                            Default: 24 (hours).
                                            Btw. Assuming you use omxplayer. Do not have experience with other players.
                                            But getting rid of the root cause of connection dropping and image freezing after a few minutes seems better time invested.
                                            Test environment:
                                            evroomE D 2 Replies Last reply Reply Quote 0
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 30
                                            • 31
                                            • 25 / 31
