    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 860.6k Views 59 Watching
      jagdambasoft @jagdambasoft
      @jagdambasoft as above i post an error
      Now in package.json change a line under scripts
          "start": "./run-start.sh",
      to
          "start": "run-start.sh",
        aab142
        I’m using Windows 10 and got the previous message as well. Changing to “run-start.sh” just opens the file with my text editor. I’m missing something.
          roccodicarlo
          I am getting errors when executing NPM install
          $ npm install
          npm ERR! code EPROTO
          npm ERR! errno EPROTO
          npm ERR! request to https://registry.npmjs.org/feedme failed, reason: write EPROTO 15828:error:14094419:SSL routines:ssl3_read_bytes:tlsv1 alert access denied:c:\ws\deps\openssl\openssl\ssl\record\rec_layer_s3.c:1544:SSL alert number 49
          npm ERR!
          npm ERR! C:\Users\dicarlro\AppData\Roaming\npm-cache_logs\2020-03-11T19_20_19_606Z-debug.log
          Does this require Adminstrator login…I am not logged in as administrator
            sdetweil @jagdambasoft
            @jagdambasoft try the results of the post just before yours
              sdetweil @aab142
              @aab142 windows … ugh… the script needs access to bash but doesn’t understand ./
              so remove the ./
                dwburger
                I’ve started this installation process from 3 years ago on an old Acer laptop running Windows 10. It’s installing MM2 right now. Just wondering…have the walkthrough steps/commands changed in the intervening 3 years in any way that I need to know? I scanned the 85 posts and didn’t see any, but I could have missed it/them. Thanks! And, I’m really glad this topic is still alive!
                  sdetweil @aab142
                  @aab142 u need to change the startstring to
                  "start":"node_modules/.bin/electron js/electron.js"
                    dwburger @sdetweil
                    @sdetweil Perfect timing…thanks! I was trying “npm start” and “npm serveronly” with no luck. I’ll give it a go.
                      dwburger
                      Just for clarity, I enter (without starting/ending quotes), npm “start”:“node_modules/.bin/electron js/electron.js”???
                        sdetweil @dwburger
                        @dwburger you have to change the “start”: line in package.json to the text I provided
                          dwburger
                          OK…I’ll work on that.
                            sdetweil @dwburger
                            @dwburger then npm start will work…
                            npm ???, executes the script next to ??? in package.json
                            D Mykle1M 2 Replies Last reply Reply Quote 0
                              dwburger @sdetweil
                              @sdetweil Yep, it works…thanks!
                                Sam, is there something that I need to change in the original post that is causing problems?
                                D S 2 Replies Last reply Reply Quote 0
                                  dwburger @Mykle1
                                  @Mykle1 May I butt in here. I was the one who started the question. I had to change the “start:” string in the package.json file to:
                                  As Sam instructed. Once I did that, the “npm start” command got my MM2 running.
                                  Thanks, BTW, for creating the walkthrough. I’m thrilled to have MM2 running on my old Acer laptop!
                                  Mykle1M blake_northrupB 2 Replies Last reply Reply Quote 2
                                    Mykle1 Project Sponsor Module Developer @dwburger
                                    @dwburger
                                    Oh, I thought perhaps something in the tutorial was wrong. I did not know that MM changed in a way that caused the tutorial to fail. :-(
                                    You’re welcome. When I wrote this I was thrilled as well and have since moved to strictly laptop boards, However, I moved from Windows to ubuntu and I’ve never been happier. MM loves linux (ubuntu) and runs beautifully under it, without jumping through any hoops for Windows. It also uses far less resources than Windows. Consider it. You won’t be sorry.
                                    And here it is.
                                    https://forum.magicmirror.builders/topic/6994/mm-and-ubuntu-made-for-each-other
                                      dwburger @Mykle1
                                      @Mykle1 I will definitely take a look at Ubuntu. I got here since 1 of my 2 MM2 running with RPi isn’t stable enough and I’ve run out of things to try. I also have an old MacMini that I’m going to try. Thanks for the encouragement!
                                        @dwburger
                                        Dude, you’ll have so much fun doing it. I guarantee it! (Well, almost). But I did. And your MacMini? I’ve done Mac boards with ubuntu and MM, as well.
                                        Here. Take a look.
                                        https://forum.magicmirror.builders/topic/6376/macmirror
                                          dwburger @Mykle1
                                          @Mykle1 Nice!
                                            @dwburger
                                            Did you watch the video? Not bad for a useless, early gen, white iMac
                                            • 6
                                            • 7
                                            • 16
                                            • 17
                                            • 5 / 17
