    Looking for Beta-testers!
    Scheduled Pinned Locked Moved MagicMirror
    56 Posts 17 Posters 61.9k Views 18 Watching
    • G Offline
      gismo2006
      @Jopyth some time ago my mirror suddenly didn’t work whit pm2. From one day to the other. I changed nothing and it works fine before. I didn’t know what happens. But then I found a little order in the display when I prompt pm2 start mm… I didn’ t rember the order but I know pm2 worked some second displayed something and then everything works fine again. …
      Maybe you found something , too
      Greets gismo
      • MichMichM Offline
        MichMich
        Guys, I’ve just made a modification that hides a region if all modules in a region are hidden. This should prevent unwanted margins when a region (like the top_bar) only contains hidden modules. This allows my to move the updatenotification module to the topbar.
        Due to the nature of the change, this could cause some serious issues if it contains any missed bugs. It would be great if you guys gan pull the latest version and let me know if everything keeps working. If you’re having issues with some modules not showing up, please let me know.
        More info about this change can be found here: https://github.com/MichMich/MagicMirror/commit/e4197012f65778f815cd73a6c7fab1a30ef3b92f
        Thanks!
        • E Offline
          ESOB @MichMich
          @MichMich I am on the latest develop and it throws an error and just gives me a black screen:
          > magicmirror@2.1.1 start /home/pi/MagicMirror
          > sh run-start.sh
          Starting MagicMirror: v2.1.1
          Loading config ...
          App threw an error during load
          TypeError: Path must be a string. Received undefined
              at assertPath (path.js:7:11)
              at Object.resolve (path.js:1148:7)
              at loadConfig (/home/pi/MagicMirror/js/app.js:53:29)
              at App.start (/home/pi/MagicMirror/js/app.js:180:3)
              at Object. (/home/pi/MagicMirror/js/electron.js:102:6)
              at Module._compile (module.js:556:32)
              at Object.Module._extensions..js (module.js:565:10)
              at Module.load (module.js:473:32)
              at tryModuleLoad (module.js:432:12)
              at Function.Module._load (module.js:424:3)
          Launching application.
          When I jump back to Master branch it loads fine:
          //your code> magicmirror@2.1.0 start /home/pi/MagicMirror
          > electron js/electron.js
          Starting MagicMirror: v2.1.0
          Loading config ...
          Loading module helpers ...
          All module helpers loaded.
          Starting server op port 8080 ...
          Server started ...
          Connecting socket for: MMM-Remote-Control
          Starting node helper for: MMM-Remote-Control
          Connecting socket for: MMM-Traffic
          MMM-Traffic helper started ...
          Connecting socket for: MMM-WunderGround
          MMM-WunderGround helper started ...
          Connecting socket for: MMM-NFL
          Starting module: MMM-NFL
          Starting module: newsfeed
          ERROR! Could not find main module js
          • SnilleS Offline
            Snille Module Developer
            Hi there, got the same problem… It’s time for bed anyway. :)
            If you cant find it, make it and share it!
            Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
              roramirez Core Contributors
              So… that is my mistake. I pushed fix the wrong validation :(
              https://github.com/MichMich/MagicMirror/pull/658
              Easy module development with MagicMirror Module Template
              • MichMichM Offline
                MichMich
                I’ve just merged the fix!👍
                • SnilleS Offline
                  Working. :)
                  • X Offline
                    XxX_Cobra_XxX
                    @MichMich I have the same problem as ESOB:
                    I am now also on the latest develop and it throws an error and just gives me a black screen:
                    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'rrule-alt'
                        at Module._resolveFilename (module.js:455:15)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                        at Function.Module._load (module.js:403:25)
                        at Module.require (module.js:483:17)
                        at require (internal/module.js:20:19)
                        at Object. (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:20:13)
                    { Error: Cannot find module 'rrule-alt'
                        at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }
                    When I go back to Master branch it loads normally.
                    Please help me
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @XxX_Cobra_XxX
                      @XxX_Cobra_XxX did you install the dependencies? they have changed for the develop branch
                      X 1 Reply Last reply Reply Quote 0
                      • X Offline
                        XxX_Cobra_XxX @strawberry 3.141
                        @strawberry-3.141 I have installed the dependencies now with ‘npm install’ and it works! ;-)
                        Thank you very much
                        • 6
                        • 4 / 6
