    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 220.9k Views 38 Watching
    • F Offline
      Fifin404
      Hi, is possible add “C” in all temperatures? Like 21 °C
      and for wind add “km/h” like 8 km/h
      • C Offline
        code999
        Hey all, anyone know how to get rid of the round bar in between the temps? 0_1574871951039_511494cd-8516-4507-93f2-b773a560930b-image.png
        Thanks in advance.
        morozgrafixM 1 Reply Last reply Reply Quote 0
        • morozgrafixM Offline
          morozgrafix Moderator @code999
          @code999 you can comment out this line forecastBar.appendChild(bar); but it will look kind of bad. Those bars are sort of a default look that you get from darksky/forecast UI.
          • C Offline
            code999 @morozgrafix
            @morozgrafix what file do I edit? I can not find that line to comment it out. Thanks.
            morozgrafixM lavolp3L 2 Replies Last reply Reply Quote 0
              @code999 it’s line 397 in MMM-fotecast-io.js https://github.com/dmcinnes/MMM-forecast-io/blob/77075e1c9011336f044d35f1c964fc93789a4201/MMM-forecast-io.js#L397
              • lavolp3L Offline
                lavolp3 Module Developer @code999
                @code999 it’s in the MMM-forecast-io.js file.
                You can either try to comment out (//) or delete line 397
                (only the bar)
                or line 402
                forecastBarWrapper.appendChild(forecastBar);
                (with temps)
                But why are you trying to delete it? It really doesn’t make sense to me and will look kind of ugly I guess.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                C 1 Reply Last reply Reply Quote 1
                • C Offline
                  code999 @lavolp3
                  @lavolp3 @morozgrafix Thank you both. I like an even look and the bar IMO is unless. when there is a large difference in temp it looks ridiculous. I might add something between numbers to give it some space and cleaner look. I did it mainly for space. I have it on the right side with my calendar taking up most of the screen. Anyway thanks again.
                  • C Offline
                    code999 @Fifin404
                    @Fifin404 I would like this also. Did you get it to show?
                    F lavolp3L 2 Replies Last reply Reply Quote 0
                    • F Offline
                      Fifin404 @code999
                      @code999 NO, I use another module
                      • lavolp3L Offline
                        @code999 @Fifin404
                        You can add the “C” by putting this into your custom.css
                        .MMM-forecast-io .bright:after {
                          content: "C";
                        That adds a “C” after the content of every element with the class “bright”. Luckily the temperature seems to be the only one.
                        For the km/h, you would need to change the code of the main .js file, because wind is apparently calculated in m/s and you have to add the conversion factor 3.6 to convert to km/h.
                        It’s possible of course but you should then consider forking the whole module and/or create a PR for that.
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 12 / 13
