    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 220.9k Views 38 Watching
    • morozgrafixM Offline
      morozgrafix Moderator @lavolp3
      @lavolp3 I haven’t pulled from master repo in a while and not sure if my changes are compatible at this point. I’m happy to clean it up, test it and submit a PR. Just let me know.
      • lavolp3L Offline
        lavolp3 Module Developer @morozgrafix
        @morozgrafix Guess I’ll use the weekend to steal from all of you and build my perfect module. And learn stuff!
        Might also send a few PRs then because I’m new to git and it really satisfies me :-D
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        morozgrafixM 1 Reply Last reply Reply Quote 0
          @lavolp3 One thing that I would suggest is to group your changes into relevant and smaller size chunks and submit separate PRs for those, instead of one massive PR. It’s easier for reviewers and for you in case you need to make changes based on comments. Cheers.
            @lavolp3 said in MMM-forecast-io -- Localized up to the minute weather:
            Guys, going through the thread, I see that a lot of good ideas were implemented in forks but not sent as PRs. I think it would be a good idea to have some of these included into the original. dmcinnes/MMM-forecast-io, since this is the one referenced in the original MagicMirror.
            @dmcinnes what do you think?
            Do you want this rep to be bloated up or do you want it to be kept mostly as it is and leave major changes to forks?
            I would expect at least to have some of @morozgrafix very good ideas implemented as optional (sunset, precipitation probability).
            Also @rak 's ideas look very very promising but I admit might be a bit much as changes for the master.
            I just submitted a PR for displaying Sunrise and Sunset times. https://github.com/dmcinnes/MMM-forecast-io/pull/22
            I will try to find some time to improve wind forecast and get another PR submitted sometime this weekend.
            I also just submitted a PR for wind speed and direction https://github.com/dmcinnes/MMM-forecast-io/pull/23
            Precipitation probability forecast is also submitted as a PR: https://github.com/dmcinnes/MMM-forecast-io/pull/24
            I also sneaked another PR that allows easy adjustments to forecast table look and feel: https://github.com/dmcinnes/MMM-forecast-io/pull/25
            • 1 Offline
              12wsx
              what is the problem with my module? the problem is on monitor connected to raspberry pi Zero (using midori browser) where MagicMirror is installed.
              My config:
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	address: "::", // Address to listen on, can be:
              	port: 8080,
              	ipWhitelist: [], // Set [] to allow all IP addresses
              	language: "pl",
              	timeFormat: 24,
              	units: "metric",
              			module: "alert",
              			module: "clock",
              			position: "top_left"
              						symbol: "calendar-check-o ",
              						url: "https://calendar.google.com/xxxxxxxx"
              			module: "MMM-Solartemp",
              			position: "bottom_left",
              			header: "Solartemp",
              				baseURL: "http://xxxxxxxxxx",
              				key: "xxxxxxxxx",
              				group: "xxxxxx",
                  			module: 'MMM-Remote-Control'
                  			// uncomment the following line to show the URL of the remote control on the mirror
                  			// , position: 'bottom_left'
                  			// you can hide this module afterwards from the remote control itself
              				module: 'MMM-forecast-io',
                  				position: 'top_right',  // This can be any of the regions.
                    				apiKey: 'xxxxxxx', // Dark Sky API key.
                    				maxDaysForecast: 5,
              				forecastTableFontSize: 'small',
              				// Only required if geolocation doesn't work:
                    				latitude:  xx.xxxx,
                    				longitude: xx.xxxx
              alt text
              idoodlerI 1 Reply Last reply Reply Quote 0
              • idoodlerI Offline
                idoodler Module Developer @12wsx
                @12wsx Are you using some custom CSS?
                • 1 Offline
                  12wsx
                  no i don’t use custom css. But one thing- when I connect to magic mirror from my
                  computer (win7 /firefox) everything is ok.
                  • idoodlerI Offline
                    @12wsx Did you try using Chromium as a browser? Midori may have a hard time rendering the page.
                    • H Offline
                      henryluyu
                      Hi this is this module in my config.js.
                      I simply put the “MMM-forecast-io-master” folder in /modules/default, I have also put my actual api key, latitude and longtitude values also in MMM-forecast-io.js. But no weather is showing, other modules working fine. Can anyone help please?
                                                 apiKey: 'MYAPIKEY',
                                                 latitude:   53.4839,
                                                 longitude:  -2.2446
                        Mykle1 Project Sponsor Module Developer @henryluyu
                        @henryluyu said in MMM-forecast-io -- Localized up to the minute weather:
                        1. Folder name should just be MMM-forecast-io
                        2. Goes in modules folder, not the default folder
                        That is not recommended. Putting those in your config.js will suffice.
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 11 / 13
