    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 236.3k Views 38 Watching
    • K Offline
      KirAsh4 Moderator
      Interesting proposition: adding the moon phases to the clock. Adding clock faces is very easy, however integrating one module into the other (a clock into the weather module, or a partial weather query inside the clock module), now you’re working to make a third beast of a module. A possible solution might be to have the clock module listen to broadcasts from the weather module and adjust its face accordingly.
      A possible working method:
      configure the clock to have an analog face (with a default face)
      configure the clock to listen to weather broadcasts
      configure the weather module to broadcast moon phases
      if/when the clock receives such notification (hopefully only once a day), it will change its face to match and timing will be of importance here when the mirror first loads up - what if the weather module broadcasts before the clock is up and running?
      Then there’s the question of, how detailed do you want it to be? Do you want a 28-day moon phase displayed? Or a simplified 8-stages version?
      Something else to keep in mind, having an actual image will increase the payload of the module itself. Right now all of the analog faces are SVG files, which are rather small, and they can be scaled without losing resolution. You can’t easily do that with an actual picture. Either you are including very large images in case someone (like me) decides to have a screen with ONLY the clock on it, taking up the full screen, and still be able to scale it small for the “normal” folks. Personally my vote would be to use plain black and white SVG images. They’ll be small and easily scalable.
      Anyway, that’s my 2 pesos.
        dmcinnes Module Developer
        @paulocarrasco That moon clock looks awesome!
        Hey Everyone! I’ve just released the updated Forecast IO module with forecast and precipitation graph (I’m considering renaming it to MMM-Darksky since forecast.io is no more…)
        https://github.com/dmcinnes/MMM-forecast-io
        Features:
        • The precipitation and forecast can be individually turned on or off.
        • Configure with the “small” class for a more compact look.
        • The precipitation graph only shows when there’s rain.
        Screenshot:
        new and improved
        Let me know what you think!
        • C Offline
          Claymobil
          Hi everyone,
          I installed the mmm-forecast but I can’t figure out why i got the same error than @paulocarrasco …
          Here is my code:
          			module: 'MMM-forecast-io',
          			position: 'top_right',  // This can be any of the regions.
          					apiKey: 'my API key' // Dark Sky API key.
          					 // Only required if geolocation doesn't work:
          						latitude:   47.902964,
          						longitude: 1.9092510000000402
          I tried removing this part and averything else works.
          Do you have any idea ?
          thanks !
          Note from admin: Please use Markdown on code snippets for easier reading!
          • I Offline
            ianperrin @Claymobil
            @Claymobil said in MMM-forecast-io -- Localized up to the minute weather:
            apiKey: ‘my API key’
            You’re possibly missing a comma after the API key, try
            apiKey: ‘my API key’,
            “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
            • C Offline
              Claymobil
              @ianperrin Thanks a lot !
              Works perfectly fine now :-)
                dmcinnes Module Developer @Claymobil
                @Claymobil glad it works! Sorry about that, that missing comma is in the example config. I’ve updated it.
                  darrene
                  Hi @dmcinnes, thank you for sharing an awesome module. It’s fantastic - the first one I installed and I think it must be the only one I haven’t swapped out since :)
                  Is there any chance of having a precipitation/temperature graph like the one from Jangellx’s variant of @MichMich’s MagicMirror1, which could be swapped out for the current precipitation graph?
                  The bulk of the javascript looks to be in the bottom half of this code: GitHub, uses d3 and d3min but it’s completely beyond me how to Frankenstein the code together…
                  It’d give a superb optional look to a lovely module!
                  • P Offline
                    plumcraft
                    @paulocarrasco
                    Have you done your forecast module by any chance ?
                      dmcinnes Module Developer @darrene
                      @darrene glad you like the module! That would be cool to have but I’m working on another project right now so I’m not interested in taking that on. If anyone else wants to take a try at doing it, please be my guest and send a PR!
                      The original module used SVG, but I used HTML5 canvas to avoid external libraries (plus I prefer canvas anyway).
                        shavesophere
                        great module! I’m curious to know how to configure it for “small”… i can’t find any clue in the documentation apart from trying to fiddle around with the .css. thanks!
                          dmcinnes Module Developer @shavesophere
                          @shavesophere thanks! You can add the ‘small’ class to the module’s classes in the config.js.
                            I’ve just pushed an update to the module. Previously if there was a network error the module would get “stuck” and no longer update. This is now fixed!
                            [card:dmcinnes/MMM-forecast-io]
                              shavesophere @dmcinnes
                              @dmcinnes forgive me I’m a noob when it comes to classes in javascript… you you be so kind as to post the code that needs altering?
                                @shavesophere sorry I wasn’t too descriptive!
                                Here’s the example from the repo with the added ‘small’ class, forth line from the top:
                                    classes: 'small',
                                      apiKey: 'abcde12345abcde12345abcde12345ab', // Dark Sky API key.
                                      latitude:   16.77532,
                                      longitude: -3.008265
                                Hope that helps!
                                  @dmcinnes ah i see! much obliged. keep up the good work!
                                    Rian9771
                                    Hello, has something changed to this module? I have clones the repo twice but i still don’t see the graph being displayed. Did ‘git checkout weather-forecast’ as mentioned but still a no go. I can see everything else but the graph. I am on debian, node serveronly, Firefox.
                                      dmcinnes Module Developer @Rian9771
                                      Hi @Rian9771 the rain graph only appears when there’s rain happening in the next hour.
                                      • P Offline
                                        phrazelle
                                        Hello! Thanks for your time with this module!
                                        I would like to customize the weather icons. I am able to change the overall color of the icons with CSS, but taking that a step further, is there a way to alter sections of the icons instead of the icon as a whole?
                                        I.e. wi-day-cloudy with an orange sun poking out from a grey cloud.
                                        I see that the icons are pulled from the erikflowers github repository, but I don’t see where they are pulling from within the module. Based on most of these weather modules using the same iconset, I’m guessing they’re being pulled from that repo directly.
                                        My initial thought was to extract from the module, recolor with Photoshop and then replace the icons in the module. Is that possible? Would I just make a whole new set, store locally and change the path somewhere in the JS?
                                        • strawberry 3.141S Offline
                                          strawberry 3.141 Project Sponsor Module Developer @phrazelle
                                          @phrazelle the css is located in the magicmirror vendor folder
                                          • P Offline
                                            phrazelle @strawberry 3.141
                                            @strawberry-3.141 Thanks for the info!
                                            After looking through there, it looks like the module pulls the icons as a font file. I believe that would mean that CCS customization would be overall to each displayed character. So there would be no way to color segments of each character (like an orange sun poking out from a grey cloud) because the stylization would apply to the character as a whole.
                                            Am I assessing at that correctly?
                                            • 6
                                            • 7
                                            • 2 / 7
