    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 218.4k Views 38 Watching
    • pyrosmileyP Offline
      pyrosmiley @mongo116
      @mongo116 sadly I don’t see that those were ever added in and it wasn’t me that did it. I have no idea what I’m doing but sometime soon I’ll see if I can figure it out? I also tried for that awhile back using CSS but didn’t get very far. If you get it let me know, and I’ll do the same!
      • morozgrafixM Offline
        morozgrafix Moderator
        I’ve added some of those on my local branch a long time ago. Feel free to pick from there https://github.com/morozgrafix/MMM-forecast-io/commit/972201f64d432c3c0863a7d76364e7f8af1bb817 and https://github.com/morozgrafix/MMM-forecast-io/commit/13ff8b78c86dc0905e46c11702d7173571517e79
        My fork is fairly old and hasn’t been synced in a while, though.
        It looks like this:
          pyrosmiley
          Very nice! I’ll definitely pull from that then
            rak
            Hi guys,
            I like the concept of the bars for the min/max temperature very much. I wanted the look of the hourly temperature graph a bit more more modern and slick.
            I sat down today and did some code magic. I am surprised how it went. The magicmirror is the first javescript project. So bear with me.
            This is how it looks now.
            I created a fork which I will clean up a bit in the next weeks. Today I am glad it works at all ,-)?
            Enjoy.
            Ralf
            G twosquirrelsT 2 Replies Last reply Reply Quote 3
            • G Offline
              grantc66 @rak
              @rak There seems to be a small error in the script creating the graph:
              // Init chart.js
              this.chart = new Chart(ctx, {
                type: 'line',
                data: data,
                options: options
              Throws an uncaught reference error. Unfortunately I know absolutely nothing about js, can you let me know how to fix it.
              Ta
                rak
                You had the plugin before?
                Have you done this after switching to my fork? It should install chart.js as a dependency.
                npm install
                I hope this solves your problem. Let me know.
                • idoodlerI Offline
                  idoodler Module Developer @paulocarrasco
                  @paulocarrasco Thats an easy one:) You are missing an , after 'my api key'.
                  Here is the correct config:
                        module: 'MMM-forecast-io',
                        position: 'top_right',  // This can be any of the regions.
                          apiKey: 'my api key', // Dark Sky API key.
                          // Only required if geolocation doesn't work:
                          latitude:   37.1468,
                          longitude: -8.5846
                  • G Offline
                    grantc66 @rak
                    @rak Had the original working OK, tried to npm install chart.js in the MM root :(
                    the npm install in the MMM-foecast.io directory fixed it. :)
                    looks great, good work.
                    thanks
                      barnosch
                      @rak
                      Nice work. i just installed it and adjusted for fitting my mirror.
                      Is it possible to shrink the height from the graph?
                      or is it calculated from the width (400px) to keep its aspect ratio?
                        rak
                        Should be easy do adapt. I can check if the height is currently fixed or exposed in the config.js.
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 9 / 13
