    MMM-NOAA - Another Weather Module
    690 Posts 77 Posters 2.7m Views 70 Watching
      Mykle1 Project Sponsor Module Developer @tbbear
      @tbbear
      I’m still using the 6 but I have no intention of getting the newest version any time soon. I have to buy my grandchildren Christmas presents! :-)
      • tbbearT Offline
        tbbear Module Developer @planet4
        @planet4 The problems are fixed. Please load the aktual version.
        Robert the Bear
          rezocharly
          hi ! Thanks for this great plugin !
          1. There is a way to hide the ALERT block ?
          2. I use the AirVisual API for the air quality index but it’s look incorrect about when I check the data from my city. There is a way to be more accurate?
          Thanks a lot
          • cowboysdudeC Offline
            cowboysdude Module Developer @rezocharly
            @rezocharly said in MMM-NOAA - Another Weather Module:
            Thanks a lot
            Added a config option
            add -> alert:false
            to your config and it will not show alert.
            I don’t know what you mean by ‘look incorrect’ … it uses the lat and lon of your location BUT you can also add lat: your lat and lon: your lon to the config file… see if that improves it :)
              rezocharly @cowboysdude
              thanks a lot @cowboysdude but alert are still displayed with alert: false,
              And with showWind: true, indications about wind are not diplayed.
              yawnsY 1 Reply Last reply Reply Quote 0
              • yawnsY Offline
                yawns Moderator @rezocharly
                @rezocharly
                Could you please show where you added the config options? Maybe it’s in the wrong place and therefore ignored?
                • tbbearT Offline
                  @rezocharly … if there is no wind than it will not be displayed so no wind 0 will appear
                  Robert the Bear
                    rezocharly @yawns
                    @yawns
                    Here you can see my config.js file: ( I’ve try first and last line)
                                        disabled: false,
                                        module: 'MMM-NOAA',
                                        position: 'bottom_left',
                                                alert: false,
                                                apiKey: "XXXXXX",    // https://www.wunderground.com/weather/api  select the middle plan...
                                                useAir: true,             // set to false if you do not want to use Air Quality Index
                                                airKey: "XXXXXX",    // IF you want Air Quality Index
                                                pws: "IAMIENS35",         // go here to find your pws: https://www.wunderground.com/wundermap
                                                showClock: false,         // Hides or shows clock
                                                dformat: false,            // for M/D/YYYY format, false for D/M/YYYY
                                                format: "24",             // 12 or 24 hour format.. will default to 12 hour if none selected.
                                                ampm: true,               // to show AM and PM on Sunrise/Sunset time
                                                showGreet: false,         // deafult is false - to show greeting under clock and above date
                                                name: "charly",           // Your name
                                                showWind: true,
                                                showDate: false,
                                                showForecast: true,        //show bottom 3 day forecast
                                                flash: false,               //Today in forecast flashes halo
                                                showUV: true,              //show UV index
                                                showBar: true,             // show Barometer
                                                showHum: true,             //show Humidity level
                                                position: 'bottom_left'    //whatever you have in above position must also be here
                      rezocharly @tbbear
                      @tbbear I live in a windy area. Today Force 5/6.
                      As you can see with this screenshot the O doesn’t appear. Even if the config.js is well setup to display this information (as you can see on the post above)
                      Capture_d_e_cran_2017_12_14_a_17_46_39
                      tbbearT cowboysdudeC 2 Replies Last reply Reply Quote 0
                      • tbbearT Offline
                        tbbear Module Developer @rezocharly
                        @rezocharly ok, so its another problem.
                        First the lines “ALERT” and the “Warning Level:” are parts of ur language translation file. So add them their and it will show in the correct language. Here my de.json file from translation dir.
                        "***ALERT***":"*** Wetterwarnungen ***",
                        "Warning Level: ":"Warnstufe: ",
                        Second ur wind problem. This module depends on wunderground which is a network of personal wheaterstations. NOT every person who has a PWS has also a wind sensor. Maybe u try to select another
                        StationID which has one. (i had the same problem too)
                        Third with alerts: false i have this in my config.js just before the line position: … and it works.
                        Robert the Bear
                        • 22
                        • 23
                        • 24
                        • 25
                        • 26
                        • 68
                        • 69
                        • 24 / 69
