MMM-NOAA - Another Weather Module
  • Project Sponsor Module Developer
    UPDATE V.2.1
    ALL weather conditions are no longer in the translation file and are automatic in the language that’s supported in the module!!
    See the README on Github
    Download:
    @cowboysdude
    Dayam!
    Exquisite!
  • Module Developer
    @cowboysdude Looking great! 🙂 I have a suggestion… Change the “Humidity” text to an image of a droplet (https://thenounproject.com/term/raindrop/381297/) to save space. 🙂 Or from font awesome: http://fontawesome.io/icon/tint/
    @Snille Well I’ll give it a shot… I don’t usually have good luck with images that’s why I use words LOL
  • Hi!
    Im stuck on the “Gather Wather Stuff” Message. Or “Samlar väderinformation” since im running a Swedish pi.
    First of thanks for sharing the module, it looks badass.
    Ive been diagnosing alot without any luck but this is what ive done to confirm my config:
    Ive been checking my api-key and pws with another module from RedNax67 called MMM_Wunderground.
    And i can get that one to work.
    I also encounter this message on re-installing the module (can’t remember if it was there on the initial install).
    npm WARN mmm-noaa@1.0.0 No repository field.
    This is my module config:
        disabled: false,
        module: 'MMM-NOAA',
        position: 'top_right',
            apiKey: "Y507ba7785XXXXXXX",          // https://www.wunderground.com/weather/api  select the middle plan...
        useAir: false,             //set to false if you do not want to use Air Quality Index
        airKey: "Y507ba7785XXXXXXX",  //IF you want Air Quality Index
    		pws: "IUHAMMAR4",       // go here to find your pws: https://www.wunderground.com/wundermap
                    lat: "59.609900",        // need this for sunrise/sunset  if left blank none will show  -- find them here: http://www.latlong.net/
    		lon: "16.544809",       // need this for sunrise/sunset  if left blank none will show
    		showClock: true,            //Hides or shows clock
    		dformat: false,             //for M/D/YYYY format, false for D/M/YYYY
    		showClock: true,
    		format: "24",             // 12 or 24 hour format.. will default to 12 hour if none selected.
    		ampm: false,                 //to show AM and PM on Sunrise/Sunset time
    		showGreet: false,          //deafult is false - to show greeting under clock and above date
                        name: "",                  // Your name
    		showWind: false,
                        showDate: false,
    Do you have any other ideas what i can try to get it running?
  • uncomment the “air stuff” for the moment
     /*    if (this.config.useAir != false || aquis != undefined) {
                var aqius = this.air.aqius;
                var aqi = document.createElement("div");
                aqi.classList.add("xsmall", "bright");
                if (aqius < 51) {
                    aqi.innerHTML = this.translate("Air Quality Index: ") + "" + aqius + "";
                } else if (aqius > 50 && aqius < 101) {
                } else if (aqius > 100 && aqius < 151) {
                } else if (aqius > 150 && aqius < 201) {
                } else {
                wrapper.appendChild(aqi);
    @cowboysdude needs to check it, since the “aquis” variabel is undefined it quits. Had the same error and i needed some time to find the cause
    edit: while i am reading i guess it is just a typo in the first line. should be “aqius” instead of “aquis” 😉
    edit2: yes. thats it. just change
    the line
    to
    if (this.config.useAir != false || aqius != undefined) {
    and you are good to go again.
    Sadly i have no idea how to push the fix to the git repository
  • @barnosch
    It did work like a charm, thanks alot dude!
    Also thanks to @Mykle1 for chatting with me and updating me on the social status of @cowboysdude hehe.
    For a first time post, i must say you guys have impressed me of how welcoming a Forum can be. It’s rare from my experience.
    @barnosch said in MMM-NOAA - Another Weather Module:
    Nice catch you guys.
    Nice remedy @barnosch
    If you go to the modules repo https://github.com/cowboysdude/MMM-NOAA
    and click on the file you want to fix, then click on the “pencil” icon to the right, github will fork the repo for you. There you can make the edit and submit a pull request which will go to cowboysdude
    @Nystro0m said in MMM-NOAA - Another Weather Module:
    I just finishing texting with @cowboysdude. I told him, “Don’t rush home from work. Someone else fixed your $h1t”.
  • cool. thats easy.
    Thanks for the explanation. Fix added 😉
