    Two way mirror netherlands
    15 Posts 9 Posters 9.3k Views 9 Watching
    • K Offline
      kingofsnake
      Hello all,
      Very inspired by this project.
      I want to buy a good two way -real glass- mirror, any advice on a good supplier? I see different suppliers but i want good transparrancy, some only have 1 percent. Thanks.
      J W 2 Replies Last reply Reply Quote 0
        j.e.f.f Project Sponsor Module Developer @kingofsnake
        @kingofsnake Where do you live? I’m in Canada and I needed to go to a glass supplier to get mine. As my mirror is large (460mm X 1500mm ) it was expensive, as I couldn’t find one that manufactured it locally. It needed to be imported, then cut to size.
        If your mirror is small, then you can likely use this cost-effective option:
        https://smartmirrors.ca/products/two-way-acrylic-mirror-thin
        If you live in the US, then you have some options available:
        https://www.twowaymirrors.com/
        https://www.tapplastics.com/product/plastics/cut_to_size_plastic/two_way_mirrored_acrylic/558
        Hopefully other people can comment on other parts of the world.
        As far as transparency is concerned, you want about 15-20% light transmission, unless your mirror is going to be in a dark room, in which case you can get away with lower. If your mirror will be in direct sunlight, then you might need more light transmission.
        • K Offline
          kingofsnake
          thanks for your reply, but i live in the Netherlands. Looking into Pilkington mirroview right now but few suppliers, and the ones that can supply are on holliday for a month ;-(. But i will keep searching.
            @kingofsnake I just noticed that the topic subject says Netherlands! Next time I’ll do a better job reading.
            • K Offline
              kingofsnake @j.e.f.f
              @j.e.f.f np
              • W Offline
                WebSpider @kingofsnake
                @kingofsnake as a beginning builder in NL i am interested too. Maybe we could team up if the goods need to come from abroad.
                  Arjen
                  I live also in NL and I am also looking for a good supplier for the mirror.
                    ranger33 @Arjen
                    @Arjen @WebSpider I believe Two way mirrors does actually ship internationally, at least that’s what their website says! Best of luck!
                      malibu
                      Also from the Netherlands. I’ve got no idea where to buy a two way mirror. Some people said: https://www.pyrasied.nl/product/doorkijkspiegel/ But I don’t think that’s the right place.
                      ? C 2 Replies Last reply Reply Quote 0
                      • ? Offline
                        A Former User @malibu
                        @malibu you can order from Germany. There are a few shops. I think shipping will be supported.
                          malibu
                          Where can I buy them? And for what price?
                          ? 2 Replies Last reply Reply Quote 0
                          • ? Offline
                            @malibu
                            You can see here.
                            https://github.com/HannahMitt/HomeMirror/wiki/Places-to-buy-a-two-way-mirror
                            • ? Offline
                              @malibu And mine is
                              http://www.glas-per-klick.de/spiegel-antikspiegel/spionspiegel.html
                              not bad.
                              • G Offline
                                Goldjunge_Chriz
                                I have already sent mirrors to the Netherlands several times and will continue to serve the Netherlands in the future ;) If you are interested, please look in this thread: https://forum.magicmirror.builders/topic/4816/two-way-community-order-for-europe-open-until-11-november-2017
                                Best regards
                                Chriz
                                • C Offline
                                  charliwest @malibu
                                  @malibu Why do you say you don’t think its right, have you heard bad things?
