    MMM-Tools : System stat monitoring and commanding (ATB Supported)
    38 Posts 7 Posters 20.7k Views 6 Watching
    • KimzerK Offline
      Kimzer
      Im not sure what the issue is, simply wont display anything.
      Using a Pi2 model b.
      • ? Offline
        A Former User @Kimzer
        @Kimzer test npm start dev, and see which error messages are thrown in your terminal console, and chromium dev console.
        and report issue on my github, I’ll look and try to fix. :)
          Mykle1 Project Sponsor Module Developer @Guest
          @Sean said in MMM-Tools : System stat monitoring and commanding (ATB Supported):
          His problem might be the same as mine. My mirror is running MM 2.1.0 so your check stopped the module from loading.
          Any chance you can add a PC option or move the check to MM version 2.1.0? I’m not really working with Pi’s anymore. A Windows PC dev machine, a Windows PC laptop and a laptop running uBuntu.
          Nice work Sean!
          ? 2 Replies Last reply Reply Quote 0
          • ? Offline
            A Former User @Mykle1
            @Mykle1 okay. You can just remove required version in module js file.
            I cant be sure my module has any dependency to recent MM version. That code was just… habit? :)
            I think it could be alright without version. But I cannot test this night. Yup, here is midnight, after sleep, I’ll do that.
            • ? Offline
              @Mykle1 maybe genuine Ububtu and Debian, I can add, but not sure. Windows… hmmm my last windows work was 15years ago. ;) I’m oldschooled.
              • cowboysdudeC Offline
                cowboysdude Module Developer @Guest
                You aren’t missing anything LOL
                  I commented out the version check but it still didn’t display on my Pi3B mirror. No errors, terminal or console
                  • K Offline
                    krisalexroberts
                    Worked fine on my mirror on a Pi3B. Just had to remove some of the final commas from the config
                    • ? Offline
                      A Former User @krisalexroberts
                      @krisalexroberts Thanks! I typed this example not by copy, so i did mistakes. I fixed it.
                      • KimzerK Offline
                        Kimzer
                        Same here. Redownloaded. Used the new settings. No bueno. Doesnt display
                        • 2 / 4
