    MMM-MovieInfo
    movietheatre
    27 Posts 11 Posters 23.4k Views 11 Watching
    • strawberry 3.141S
      Module for upcoming movies as requested from @tyho @luvien
      [card:fewieden/MMM-MovieInfo]
      Preview
      T 1 Reply Last reply
      Reply Quote 1
      • T
        tyho @strawberry 3.141
        @strawberry-3.141 This is awesome! i’ll install when i am home.
        Reply Quote 1
        • B
          balthaz
          Hello,
          Can you had language selection in node_helper.js or config.js
          url: ‘https://api.themoviedb.org/3/discover/movie?primary_release_date.gte=’ + start + ‘&primary_release_date.lte=’ + end + ‘&api_key=’ + this.config.api_key + ‘&language=fr-FR’
          Perfect work, thank you
          • strawberry 3.141S
            sorry forgot about your post
            the problem is that the fields which are not provided in the selected language don’t have anymore a fallback to english (like in previous api versions) and therefore will be empty, that’s why I chose to take allways english, so all data is provided.
            But I can add a config option, so everyone can decide for himself
            B 1 Reply Last reply
            • B
              balthaz @strawberry 3.141
              @strawberry-3.141 Thanks
              • strawberry 3.141S
                Changelog
                new config options:
                * hide genre
                * hide rating
                * hide plot
                * use language from config instead of default english, this can have missing data from api
                • B
                  balthaz
                  You are the best
                  • strawberry 3.141S
                    Changelog
                    • Date manipulation fixed with new dependency
                    To update do git pull and npm install
                    Reply Quote 1
                    • N
                      number1dan
                      nice module. I have this starting hidden and then voice command it to show. I’ve also changed the start and end dates for it to show stuff in cinema now and removed the greyscale from the poster. Good job making this module
                      Reply Quote 1
                        shashank @number1dan
                        @number1dan Hi, Module working fine, how to get Indian Movies info
                        strawberry 3.141S 1 Reply Last reply
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @shashank
                          @shashank as far as i can see this is not supported with this provider to choose a country. i guess you need a different api provider
                          • strawberry 3.141S
                            There is a new version which has a lot of new possibilities to discover movies
                            Thanks to @dr4ke616 who made this happen
                            Reply Quote 1
                              SilentJbob1680
                              Hi, I just recently discovered MM2 & have started on putting it together. This is a fresh install of MM2 & the MovieInfo module however the module is not getting the images.
                              This is my config.js
                                  module: 'MMM-MovieInfo',
                                  position: 'bottom_left',
                              		api_key: ""
                              The module shows everything but the image or Poster art. Inspecting the page in Google Chrome results in this appearing:
                              GET https://image.tmdb.org/t/p/w185_and_h278_bestv2/undefined 404 ()
                              Further examination of the movieinfo.js file shows
                              const poster = document.createElement('img');
                                          poster.classList.add('poster');
                                          poster.src = `https://image.tmdb.org/t/p/w185_and_h278_bestv2/${movie.posterPath}`;
                                          wrapper.appendChild(poster);
                              here’s a SS via vnc:
                              How can I fix this issue? I know nothing of javascript or programming unfortunately so baby steps in explaining a fix please :)
                              Y 2 Replies Last reply
                              Reply Quote 1
                              • Y
                                yawns Moderator @SilentJbob1680
                                @SilentJbob1680
                                For some reason they changed the variable containing the path to the image from posterPath to poster_path
                                You could change this
                                to this
                                            poster.src = `https://image.tmdb.org/t/p/w185_and_h278_bestv2/${movie.poster_path}`;
                                for an immediate fix, or you could wait for strawberry to fix it on github and provide a new version. If you fix it on your own you will need to revert the changes before you can update once strawberry provided the update.
                                Reply Quote 1
                                • strawberry 3.141S
                                  should be fixed now. thanks for reporting
                                  Reply Quote 1
                                  • Y
                                    @SilentJbob1680
                                    So, please open a terminal on your raspberry, change into the ~/MagicMirror/modules/MMM-MovieInfo folder and do git pull to retrieve the update
                                    Reply Quote 1
                                    • JacobJ
                                      Jacob
                                      Hello.
                                      I seem to be having issues in setting up the correct config.js. What am I doing wrong? Here is the code I am trying to use.
                                                              discover: {
        "certification_country": "US",
        "certification.lte": "G",
        "sort_by": "popularity.desc"
                                                              updateInterval: '1080000',
                                                              rotateInterval: '180000',
                                                              api_key: ' '
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @Jacob
                                        @Jacob missing comma after discover: {}
                                        JacobJ 1 Reply Last reply
                                        Reply Quote 1
                                        • SnilleS
                                          Snille Module Developer
                                          Hi there! Would there be a possibility to have a config option to set the number of movies to show (as a configurable table)?
                                          Also, I read that they now support TV-Shows as well… It would be cool to get that integrated as well :)
                                          Ex something like this would be cool…
                                            columns: 2,
                                            titles: 6,
                                            type: {
                                              "tv": 1,
                                             "movie": 1,
                                            discover: {
                                              "sort_by": "vote_average.desc"
                                          That would give a table that holds 2 columns with 6 rows altering TV-Shows and Movies, descending by votes… 8)
                                          If you cant find it, make it and share it
                                          MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
                                          • JacobJ
                                            Jacob @strawberry 3.141
                                            @strawberry-3.141 Thanks for the help. However, it still did not seem to fix it. It’s only the MovieInfo module that seems to be causing the mirror to not load. Would it be possible to show me your MovieInfo config?
