    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 240.2k Views 28 Watching
    • Y
      yawns Moderator
      Your config looks a bit misconfigured. Please remove these lines.
      If this is still not working, then please paste your entire config.
      B 1 Reply Last reply
      • B
        blinky1989dk @yawns
        @yawns is dot work. so i had try to send config fil to you on pb
        • Y
          yawns Moderator
          /* Magic Mirror Config Sample
          By Michael Teeuw http://michaelteeuw.nl
          MIT Licensed.
          var config = {
          zoom: 0.6,
          port: 8080,
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
          language: "da",
          timeFormat: 24,
          units: "metric",
          		module: "alert",
          		module: "clock",
          		position: "top_left"
          		module: 'MMM-WunderGround',
          		position: 'top_right',
          			apikey: 'xxxxxxxxxxxxxxxxxxxxxx', // private; don't share!
          			pws: 'pws:IVEJLE2', //culemborg
          			hourly: '1',
          			fctext: '1',
          			fcdaycount: "5",
          			fcdaystart: "0",
          			hourlyinterval: "3",
          			hourlycount: "2",
          			alerttime: 10000,
          			alerttruncatestring: "english:",
          			roundTmpDecs: 1,
          			UseCardinals: 0,
          			layout: "vertical",
          			iconset: "novaco",
          			sysstat: 0
          		module: "MMM-xiaomi",
          		position: "bottom_left",
          		header: "Temperature / Humidity", // This is optional
          			gatewayIP: "192.168.10.170",
          			gatewayToken: "xxxxxxxxxxxxxxxxxxx",
          			showwindow: true,
          			showVentilation: false,
          			minTemperature: true,
          			maxHumidity: true,
          			showlights: true,
          			rooms: [
          			{ name: "test", sortOrder: 30, devices: ["158d0001b911b9"] },
          Please try again. I don’t know which text editor you used, but it is very important to only use these around strings:
          Do not use
          B 2 Replies Last reply
            shgmongohh @mirko3000
            @mirko3000
            Yes, i solved the problem with the token.
            to my css:
            I add
            .xm-xiaomi .small {
              font-size: 24px;
            to get a bigger fonts.
            I try to change the default colours e.g.
            .xm-legend-temp {
              position: absolute;
              height: 100%;
              width: 3px;
              background-color: #FF1493;
              left: 9%;
              z-index: 0;
            And I want to have bigger figueres for temperature and humidity
            .xm-room-temp-humid {
               margin: 10px;
            • B
              blinky1989dk @yawns
              @yawns okay THX. I Will try
              • B
                blinky1989dk @yawns
                This post is deleted!
                • J
                  joseska
                  Hi… We have an error with door sensor. Not show icons on MM. I think that the config is ok
                  			module: 'MMM-xiaomi',
                  			position: 'bottom_left',
                  			header: 'Temperatura / Humedad',
                  				gatewayIP: '192.168.1.103',
                  				gatewayToken: 'xxxxxxxxxxxx872e8bc25e415a7005a2',
                  				showWindow: true,
                  				showVentilation: true,
                  				showLights: false,
                  				audioNotifications: true,
                  				rooms: [
                  					{ name: 'Salon', sortOrder: 10, devices: ['158d0001f531bf', '158d00020258f4'] }
                  any idea???
                  Thanks…
                  M 1 Reply Last reply
                  • M
                    mirko3000 @joseska
                    Hmm your config seems to be fine, make sure the IDs are ok, else it should work. Be aware that the icon only shows open window/doors, so if the door is closed you won’t see an icon.
                    I suppose the temperature sensor is working fine?
                    J 1 Reply Last reply
                    • J
                      joseska @mirko3000
                      @mirko3000 Now Work… I don´t know why…
                      simply copy again the id (the same) and change showVentilation: false (don´t have outdoor sensor) and work…
                      sorry and thanks…
                        Smotx
                        HI,
                        Anyone know why MMM Xiaomi need aplay ?
                        Error: Cannot find module 'node-aplay'
                            at Module._resolveFilename (module.js:543:15)
                            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                            at Function.Module._load (module.js:473:25)
                            at Module.require (module.js:586:17)
                            at require (internal/module.js:11:18)
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-xiaomi/node_helper.js:11:20)
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-xiaomi/node_helper.js:140:3)
                            at Module._compile (module.js:642:30)
                            at Object.Module._extensions..js (module.js:653:10)
                            at Module.load (module.js:561:32)
                          Smotx @mirko3000
                          @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                          I just recieved my order of another 6 window sensors yesterday :) But I really think they will shut this down soon, guess they (gearbest) are not paying any taxes at all…
                          Working on the new version, this is what I have in mind:
                          How to have this screen ?
                          E 1 Reply Last reply
                            Smotx @mirko3000
                              Smotx
                              it seems that these window sensors are not compatible.
                              Xiaomi Aqara Window Door Sensor
                              I added them to the config module and no return on MM.
                              When i launch
                              miio discover
                              it found
                              Device ID: 158d0001ab1f9c
                              Model info: lumi.magnet.aq2
                              but when i launch npm start, MMM-xiaomi say
                              Found device with ID 158d0001ab1f9c of type generic
                              and no
                              Found device with ID 158d0001ab1f9c of type magnet
                                Smotx
                                Thanks to owner of module : @mirko3000 for update to see this sensor !
                                Now that’s work
                                • V
                                  VagelisAn
                                  Dear @mirko3000 i have follow your instraction and i install the MMM-Xiaomi, i install and the miio to get the access token but the scan of miio is not find the getaway accesstoken
                                  pi@raspberrypi:~ $ miio discover
                                   INFO  Discovering devices. Press Ctrl+C to stop.
                                  Device ID: 631XXXXX
                                  Model info: Unknown
                                  Address: XXX.XXX.X.XXX
                                  Token: ???
                                  Support: Unknown
                                  I use the MI application and get the ip and accessToken and the id from temperature sensor.
                                  The name is lumi.158xxxxxxxxxxx
                                  this is the code of config
                                  		header: 'Temperature / Humidity',  // This is optional
                                  			gatewayIP: 'IP getaway from MI home',
                                  			gatewayToken: 'accese getaway from MI home',
                                  			showWindow: true,
                                  			showLights: false,
                                  			rooms:  [
                                  					sortOrder: 10,
                                  					devices : ['lumi.158xxxxxxxxxxx']
                                  I execute and i have this error in terminal andthe xiaomi modules say connecting to xiaommi getaway.
                                  { Error: Call to device timed out
                                      at retry (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/devi             ce.js:225:18)
                                      at _ensureToken.catch.err (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modu             les/miio/lib/device.js:238:8)
                                      at <anonymous> code: 'timeout' }
                                  Sorry if my English is bad
                                  • G
                                    gh057
                                    Has anyone tried to get the module to work with a Gateway AND a Yeelight bed lamp ??
                                    I mean i have the module working with my gateway (manually added the token, and then the sensors appeard in miio discovery) but i havent managed to get it to work with the yeelight lamp (that also acts as a bluetooth gateway for my other sensors).
                                    When i reseted the lamp, and connected to its wifi, i discovered it with miio and extracted the token, but later when i registered the lamp with the mi app, and connected my pi to my wifi, while the lamp is pingable by the pi, now miio doesn’t discover it!!
                                    But, besides that, even if i manage to discover the lamp again with miio, i’m not aware if its even possible to add a second gateway to the module.
                                    Does anyone know??
                                    • G
                                      gauka12345
                                      HI there i have got same problem the gateway was turned off
                                      then i have tried to reconnect all the temperature sensors and tokens shows with ??? question marks… can some one help please!
                                      • G
                                        gauka12345
                                        pi@raspberrypi:~/miio $ miio discover
                                        Device ID: 72558327
                                        Model info: lumi.gateway.v3
                                        Address: 192.168.0.9
                                        Token: ???
                                        Support: At least generic
                                          Smotx
                                          hi,
                                          Same problem here too
                                          I have changed my router, so i have change wifi of Xiaomi hub
                                          On magicmirror config i have set new ip 192.168.2.xxx (before 192.168.1.xxx).
                                          But always nothing on MagicMirror after reboot.
                                          perhaps token has changed with new router… So, on the rasp i launch command ```
                                          miio discover
                                          ` $ sudo miio discover
                                          Device ID: 567xxxx54
                                          Model info: Unknown
                                          Address: 192.168.2.xxx
                                          Token: ???
                                          Support: Unknown
                                          Anybody know why ? :(.
                                          garblefluxG 1 Reply Last reply
                                          • G
                                            gauka12345
                                            Hi
                                            You can get token by installing older version of mi home app on you mobile
                                            https://www.apkmirror.com/apk/xiaomi-inc/mihome/mihome-5-0-19-release/mihome-5-0-19-android-apk-download/
                                            Then you will need to follow this tutorial to obtain the token
                                            https://www.youtube.com/watch?v=Q4QV8tMI8H4
                                            however so far i have swap the tokens but with no luck. i think the device need to be discovered by MIiio.
                                            • 6
                                            • 7
                                            • 8
                                            • 6 / 8
