    Mirror Not Working
    16 Posts 4 Posters 7.3k Views 3 Watching
      aayush447
      Hello Everyone, I am working to make my own MagicMirror, But When I Install the software and after creating the Config File, When I Type "npm start’ It Doesn’t show anything, just a black screen. Can anyone help me to fix this ?
        Mykle1 Project Sponsor Module Developer @aayush447
        @aayush447
        Can you post your terminal output?
          aayush447
          I Can’t It won’t let me do anything, just a black screen and mouse pointer. I can’t navigate to terminal or any other window
            @aayush447
            When in black screen, press Alt, or Ctrl. You should get a menu bar at the top where you can quit MM. Then you can see your terminal
              aayush447
              Here’s the terminal output 0_1508845491480_Screen Shot 2017-10-24 at 5.14.06 PM.png
                @aayush447
                Don’t know why you installed MM on your desktop.
                Also, did you install MM using sudo? That it not necessary or recommended.
                You can try running npm start in the MM directory, without sudo
                  I’m off to work. I will check back here later
                    aayush447
                    I installed the MM Directory on desktop then After navigating there I typed this “npm start” After that nothing happened
                    • axellejamousA Offline
                      axellejamous
                      When you’re in the MagicMirror directory try going into the vendor file (cd vendor) and typing “npm install”. I had the same symptoms when I installed mine so it could be the same issue.
                      axellejamousA 1 Reply Last reply Reply Quote 0
                        axellejamous @axellejamous
                        @axellejamous said in Mirror Not Working:
                        Never mind. I realise I was running it with node serveronly and that works perfectly with 0 errors. However if I run it with npm start it’s still black.
