    work in progress
    18 Posts 7 Posters 12.4k Views 6 Watching
    • C Offline
      cornusandu @cornusandu
      I mounted back the fan. Now is down to 38.5 Celsius
        Mykle1 Project Sponsor Module Developer @cornusandu
        @cornusandu said in work in progress:
        I rest my case. :-)
        Excellent!
        • E Offline
          enettekoven @cornusandu
          @cornusandu Pretty slick looking MagicMirror! What monitor did you use?
          • C Offline
            cornusandu @enettekoven
            @enettekoven It is a very old 19 inch 3d monitor, My wife decided that she want a curved monitor and this one was just sitting in the garage
            • N Offline
              noelandrews
              Very cool! How have you done the full length mirror? Is that film over glass?
                doubleT Module Developer @cornusandu
                the raspberry will be running continuous until it will die i guess.
                Any advice on raspberry power? Should I cut electricity 12 hours a night with a smart plug? Or run it 24/7? Which is better for longer life?
                As everyone else said, leave it running, don’t cut the power without shutting the RasPi down safely first. Two advices I would give you:
                1. When everything is set up and running, and everytime you add a new feature/module, make an image of your sd card as backup!
                2. Think about a UPS, Uninterruptible Power Supply. There are some add ons that combine a batterie that provides power for a few minutes and a circuit that will detect the power outage and initiate a safe shutdown. And when the power goes back on, it will go back to normal.
                I learned both the hard way, but I’m still not done finding/setting up a good UPS solution.
                • C Offline
                  cornusandu @noelandrews
                  @noelandrews it is polycarbonate two way mirror. A but expensive but it looks really good. Size 120 cm. 60 cm.
                  • C Offline
                    cornusandu @doubleT
                    @doubleT thank you. UPS, I will have to shop around for something small and strong enough
