work in progress
Great job!
@cowboysdude thank you. It is quite a ride .
@cornusandu It is a fun ride though :)
@cowboysdude Ohhh yeahhh :) a lot of head scratching and a bit of swearing. I reinstalled about 20 times . But finally got it working smoothly.
@cowboysdude Super cool community. Any advice on raspberry power? Should I cut electricity 12 hours a night with a smart plug? Or run it 24/7? Which is better for longer life?
@cornusandu said in work in progress:
In my opinion, I would leave it running. As long as you keep the temp of the Pi somewhere in the neighborhood of 40°C. Personally, I prefer that to 365 unnecessary boots a year.
@cornusandu I leave mine running all the time… have had no issues after a year so far :)
@cornusandu if you just turn off the electricity is not that good for the hardware in terms durability, but if you create a shut down routine e.g. 5min before, than it should be fine.
@Mykle1 He is running at a stable 65 Celsius
I mounted back the fan. Now is down to 38.5 Celsius
I rest my case. :-)
Excellent!
@cornusandu Pretty slick looking MagicMirror! What monitor did you use?
@enettekoven It is a very old 19 inch 3d monitor, My wife decided that she want a curved monitor and this one was just sitting in the garage
Very cool! How have you done the full length mirror? Is that film over glass?
the raspberry will be running continuous until it will die i guess.
As everyone else said, leave it running, don’t cut the power without shutting the RasPi down safely first. Two advices I would give you:
- When everything is set up and running, and everytime you add a new feature/module, make an image of your sd card as backup!
- Think about a UPS, Uninterruptible Power Supply. There are some add ons that combine a batterie that provides power for a few minutes and a circuit that will detect the power outage and initiate a safe shutdown. And when the power goes back on, it will go back to normal.
I learned both the hard way, but I’m still not done finding/setting up a good UPS solution.
@noelandrews it is polycarbonate two way mirror. A but expensive but it looks really good. Size 120 cm. 60 cm.
@doubleT thank you. UPS, I will have to shop around for something small and strong enough
