    work in progress
    18 Posts 7 Posters 13.4k Views 6 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @cornusandu
      @cornusandu if you just turn off the electricity is not that good for the hardware in terms durability, but if you create a shut down routine e.g. 5min before, than it should be fine.
        cornusandu @Mykle1
        @Mykle1 He is running at a stable 65 Celsius
          cornusandu @cornusandu
          I mounted back the fan. Now is down to 38.5 Celsius
            Mykle1 Project Sponsor Module Developer @cornusandu
            @cornusandu said in work in progress:
            I rest my case. :-)
            Excellent!
            • E Offline
              enettekoven @cornusandu
              @cornusandu Pretty slick looking MagicMirror! What monitor did you use?
                cornusandu @enettekoven
                @enettekoven It is a very old 19 inch 3d monitor, My wife decided that she want a curved monitor and this one was just sitting in the garage
                • N Offline
                  noelandrews
                  Very cool! How have you done the full length mirror? Is that film over glass?
                    doubleT Module Developer @cornusandu
                    the raspberry will be running continuous until it will die i guess.
                    Any advice on raspberry power? Should I cut electricity 12 hours a night with a smart plug? Or run it 24/7? Which is better for longer life?
                    As everyone else said, leave it running, don’t cut the power without shutting the RasPi down safely first. Two advices I would give you:
                    1. When everything is set up and running, and everytime you add a new feature/module, make an image of your sd card as backup!
                    2. Think about a UPS, Uninterruptible Power Supply. There are some add ons that combine a batterie that provides power for a few minutes and a circuit that will detect the power outage and initiate a safe shutdown. And when the power goes back on, it will go back to normal.
                    I learned both the hard way, but I’m still not done finding/setting up a good UPS solution.
                      cornusandu @noelandrews
                      @noelandrews it is polycarbonate two way mirror. A but expensive but it looks really good. Size 120 cm. 60 cm.
                        cornusandu @doubleT
                        @doubleT thank you. UPS, I will have to shop around for something small and strong enough
