    work in progress
    18 Posts 7 Posters 13.7k Views 6 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @cornusandu
      @cornusandu said in work in progress:
      Should I cut electricity 12 hours a night with a smart plug? Or run it 24/7? Which is better for longer life?
      In my opinion, I would leave it running. As long as you keep the temp of the Pi somewhere in the neighborhood of 40°C. Personally, I prefer that to 365 unnecessary boots a year.
      C 1 Reply Last reply
      • cowboysdudeC
        cowboysdude Module Developer @cornusandu
        @cornusandu I leave mine running all the time… have had no issues after a year so far :)
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @cornusandu
          @cornusandu if you just turn off the electricity is not that good for the hardware in terms durability, but if you create a shut down routine e.g. 5min before, than it should be fine.
            cornusandu @Mykle1
            @Mykle1 He is running at a stable 65 Celsius
              cornusandu @cornusandu
              I mounted back the fan. Now is down to 38.5 Celsius
              Mykle1M 1 Reply Last reply
              • Mykle1M
                I rest my case. :-)
                Excellent!
                • E
                  enettekoven @cornusandu
                  @cornusandu Pretty slick looking MagicMirror! What monitor did you use?
                    cornusandu @enettekoven
                    @enettekoven It is a very old 19 inch 3d monitor, My wife decided that she want a curved monitor and this one was just sitting in the garage
                    • N
                      noelandrews
                      Very cool! How have you done the full length mirror? Is that film over glass?
                        doubleT Module Developer @cornusandu
                        the raspberry will be running continuous until it will die i guess.
                        Any advice on raspberry power? Should I cut electricity 12 hours a night with a smart plug? Or run it 24/7? Which is better for longer life?
                        As everyone else said, leave it running, don’t cut the power without shutting the RasPi down safely first. Two advices I would give you:
                        1. When everything is set up and running, and everytime you add a new feature/module, make an image of your sd card as backup!
                        2. Think about a UPS, Uninterruptible Power Supply. There are some add ons that combine a batterie that provides power for a few minutes and a circuit that will detect the power outage and initiate a safe shutdown. And when the power goes back on, it will go back to normal.
                        I learned both the hard way, but I’m still not done finding/setting up a good UPS solution.
                          cornusandu @noelandrews
                          @noelandrews it is polycarbonate two way mirror. A but expensive but it looks really good. Size 120 cm. 60 cm.
                            cornusandu @doubleT
                            @doubleT thank you. UPS, I will have to shop around for something small and strong enough
