    Magic Mirror with AI
    64 Posts 14 Posters 80.5k Views 18 Watching
    • akshaybahadur21A Offline
      akshaybahadur21
      I want to thank all the contributors of this forum without whom I could not have created my mirror.
      It has been about three months since I attended this forum finally be able to present you my work.
      I have included some extra modules like Uber, Zomato, Youtube etc.
      The whole setup is ready but I still need a Mirror to mount. As Two-way mirrors are not easily available in my country, therefore, I have made a video on youtube for the demo. Will be uploading the code to git soon.
      Until then a feedback from you guys will be much appreciated.
      Here is the Youtube Link:
      AI powered magic mirror
      Git Repository
      1 Reply Last reply Reply Quote 4
      • cowboysdudeC Offline
        cowboysdude Module Developer
        THAT. IS. AWESOME!
        Looking forward to the code :)
        akshaybahadur21A 1 Reply Last reply Reply Quote 1
        • 1 Offline
          17saiiqb
          WOW, that is incredible! How did you get uber and youtube to work at all? And is the AI based on google assistant? Or Alexa? Or anything at all?
          Anyways I can’t wait for the code
            akshaybahadur21 @17saiiqb
            @17saiiqb This isn’t based on Google Assistant or Alexa. Although we have used google’s text to speech library. Will be posting the code soon.
            • F Offline
              fischi87
              thats really awesome!!! im also interested on your code. i would like to see it soon!!!
              greet job!!
              • cruunnerrC Offline
                cruunnerr
                o.0
                dammit… Congrats man. Very very well done.
                akshaybahadur21A 2 Replies Last reply Reply Quote 0
                • C Offline
                  cyberphox
                  wow…following…and looking forward to code too!! might have to re-do my mirror for this!
                  akshaybahadur21A 1 Reply Last reply Reply Quote 0
                    Would be really nice to see it…but I don’t see it happening… I think this was just a setup.
                    akshaybahadur21A 1 Reply Last reply Reply Quote 2
                      akshaybahadur21 @cowboysdude
                      @cowboysdude Hi thanks for the skepticism. We are used to it. The code and the final video shall be uploaded soon. Check the link for documentation
                      https://github.com/akshaybahadur21/Smart_Mirror
                      cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 2
                        akshaybahadur21 @cruunnerr
                        @cruunnerr @cyberphox - Thanks for the encouragement and support. We won’t let you down.
                          cowboysdude Module Developer @akshaybahadur21
                          @akshaybahadur21 Too many have come through with empty promises of ‘things that are’…so I’m hoping you prove me wrong :)
                          Will users be able to add other modules as is the case now?
                            Mykle1 Project Sponsor Module Developer @akshaybahadur21
                            @akshaybahadur21 said in Magic Mirror with AI:
                            This will run on a Pi?
                              akshaybahadur21 @Mykle1
                              @Mykle1 - It won’t be able to run on a pi with the current configurations. Although we are looking for a less heavy design which can run smoothly on a pi. All the computation is done in the cloud to make it as lightweight as possible. But still I wont recommend it running on pi
                                @cowboysdude - Thanks. Yes, the users can add all the existing modules with this one. And a simple voice command will activate or deactivate them. We have used an existing email module to appear and disappear with voice command.
                                  akshaybahadur21 @cyberphox
                                  @cyberphox - We can redo your mirror for you… :D
                                  cowboysdudeC C 2 Replies Last reply Reply Quote 0
                                    @akshaybahadur21 well that certainly would be very interesting…
                                    • ChrisC Offline
                                      Chris
                                      Hello,
                                      it is true that it is really impressive.
                                      What is the current minimum hardware configuration to make this system work?
                                      Regards,
                                        akshaybahadur21 @Chris
                                        @Chris For now, I am running it on a VM. What I would suggest that you could do the same. Or as my friend @cowboysdude you could use a Mini ITX board if you want to go for full home automation. That is a bit costly ofcourse
                                        • C Offline
                                          cyberphox @akshaybahadur21
                                          @akshaybahadur21 don’t tease me! But I’m interested in what specs i will need to run this. I’m working on a 50" touchscreen mirror right now so might as well as add a new cpu to the mix!
                                            @cyberphox you could use Mini ITX board and go for full home automation. That sounds a lot of fun. Although I haven’t tried that. I think I might.
                                            C 1 Reply Last reply Reply Quote 1
                                            • 1 / 4
