    MMM-FRITZ-Box-Callmonitor
    99 Posts 27 Posters 128.0k Views 26 Watching
    • O Offline
      ostfilinchen
      Hi all,
      i create an user and Password on the Fritz.box-Interface with these Settings:0_1474191737271_fritzbox_raspi.PNG
      The config-file Looks like this: 0_1474191877945_fritzbox_config.PNG
      If i get an Call, i see always the number, not the Name of the Caller. In the readme of this module it’s descriped this part:
      —>>> The latter will also load recently missed calls, which happened before you started your mirror.
      This is also not working for me.
      Has anyone else this Problems?
      Regards, Daniel
        Jopyth Moderator
        The user needs rights to read and write FRITZ!Box Settings (FRITZ!Box Einstellungen). Otherwise it seems to be right. Can you activate this and try again?
        On a side note: loadSpecificPhonebook is currently not used in the code, so you may remove it. It just loads all available phonebooks from the FRITZ!Box.
        Please post again if you encounter any problems.
        Helpful sticky: How to troubleshoot
        O 1 Reply Last reply Reply Quote 1
        • O Offline
          ostfilinchen @Jopyth
          @Jopyth: that doesn’t work. The mirror Shows me the Number, not the Name of the caller.
            Jopyth Moderator @ostfilinchen
            @ostfilinchen Can you add showContactsStatus: true, in the config, and see if it successfully loads your contacts? Either a small warning sign should appear after you restart your mirror, or a number showing how many contacts are loaded.
            If the contacts load correctly, please look at the format your numbers are in the phonebook, e.g. are they like +12 (345) 678901 or 0012345678901… (do not post the real number)? I have experienced some problems with certain formatting as well, however have not had time to fix it in the code, instead I replaced my numbers in the FRITZ!Box, and always used the format 0123 4567891.
            If there is a warning sign, please have a look at the logs (if you start it with pm2 you can do pm2 logs --lines 100 mm) and search for an error related to the Callmonitor.
            • O Offline
              @Jopyth if i Set the Contact Status to true, nothing happens. There’s no Icon and the logs displays no error.
                @ostfilinchen You might have on older version can you try to use git pull and see if it updates (note: you must do this inside the MMM-FRITZ-Box-Callmonitor folder. Also you can check the date of your version with git show, it should show this:
                commit 9a35b1a74811a2e7c31edb35d59bab010dd5f991
                Merge: 08633e0 bfee1e5
                Author: Paul-Vincent Roll <paviro@me.com>
                Date:   Fri Sep 23 11:26:47 2016 +0200
                • O Offline
                  ostfilinchen
                  this output i have also…
                  must i activate the vcard-option to show how many contacts loaded?
                    @ostfilinchen Please check your config again. Is your password empty (i.e. the empty string password: "")? That would not work, but otherwise it should. I did a clean install and this config works for me:
                    	module: 'MMM-FRITZ-Box-Callmonitor',
                    	position: 'bottom_right',
                    	header: "Recent calls",
                    		username: "EXAMPLE_USER",
                    		password: "EXAMPLE_PASSWORD",
                    Result:
                    0_1475355100926_Screenshot from 2016-10-01 22:50:16.png
                    If I type a wrong password, it shows an error:
                    	password: "WRONG_EXAMPLE_PASSWORD",
                    0_1475355180491_Screenshot from 2016-10-01 22:52:25.png
                    If you can not see either of these results, and you say your version is up-to-date, then I am little bit out of guesses. Maybe you can try complete removing the module, and downloading it again?
                    garblefluxG 1 Reply Last reply Reply Quote 0
                    • O Offline
                      ostfilinchen
                      i have an fresh Installation and i don’t get this Output. If i set vcard to true, then it Shows me the little book with spinning arrows. The Password and user is set.
                        @ostfilinchen Please check if your option is German passwort (does not work) or password (English).
                        • O Offline
                          @Jopyth it’s password
                          J 2 Replies Last reply Reply Quote 0
                            @ostfilinchen Damn. Because I saw this in your first post. :( This was my last hope.
                            Edit: Can you post the output of git status one more time? Just to make sure everything is fine with your module.
                              @ostfilinchen In this case what we can try is some do-it-yourself debugging, i.e. add a line above line 56 of your node_helper.js
                              console.log(this.config.password); // should show your password as entered in config
                              console.log(this.config.password !== ""); // should show true
                              Also change line 197:
                              console.log("Reading " + files.length + " files from python script" ); // should probably show Reading 5 files from python script
                              This should add the corresponding output to your server output pm2 logs --lines 100 mm.
                              • O Offline
                                ostfilinchen
                                oh man. I’m so stupid… i wrote really passwort instead of password…
                                now it work’s. Thanks for your great help @Jopyth!!!
                                • K Offline
                                  kwaeksler
                                  hi :-)
                                  i also have a problem with my phonebook. When i get a phone call it shows only the number of the caller, not a name.
                                  i get a small warning sign and an “unknown error”
                                  my config looks like:
                                          position: 'top_right',
                                          header: "Anrufliste",
                                  			username: "************",
                                  			password: "*************************",
                                  			reloadContactsInterval: 1,
                                  			deviceFilter: ["Wohnzimmer"]
                                  Could you help me? :-)
                                  Thanks in advanced,
                                  Kwaeksler
                                  edit: FRITZ!Box User Settings:
                                  • O Offline
                                    ostfilinchen @kwaeksler
                                    @kwaeksler Do u have a other IP Address for the fritzbox? Do you have activate the callmonitor with #965 from a connected Phone (Not the fon-app)?
                                    • T Offline
                                      thk
                                      Is there a way to show internal calls?
                                      For external calls it´s working fine.
                                      But I couldn´t get it to work for internal calls from a locally connected SIP phone…
                                      • K Offline
                                        kwaeksler @ostfilinchen
                                        @ostfilinchen said in MMM-FRITZ-Box-Callmonitor:
                                        IP Adress for the box is 192.168.178.1 and yes i activated the callmonitor with my Siemens phone.
                                        • O Offline
                                          ostfilinchen
                                          The Best way to find errors is to Start the mirror with npm start dev directly on the pi. On the right side you find Infos about the error.
                                          • K Offline
                                            Mhm… i dont get any warnings or errors in the console
                                            • 1 / 5
