    Multiple screens fo MM.
    36 Posts 13 Posters 26.6k Views 15 Watching
      Joshrobbs1
      I was wondering if it is possible to install a multiple display MM? My idea is to install a large marge for a double sink vanity much like the frameless back lit one. But instead of having a monitor in the middle I would like to have two monitors. One on each the left & right sides. Being able to keep all of my modules on the the perimeter of the mirror. Is this possible or would you have to have (2) pi’s? One for each monitor?
      tbbearT 1 Reply Last reply Reply Quote 0
      • tbbearT Offline
        tbbear Module Developer @Joshrobbs1
        @Joshrobbs1 hi of course u can use multiple screens, take a look at MMM-HelloLucy
        Robert the Bear
        • N Offline
          ninjabreadman @tbbear
          @tbbear @Mykle1 Do you mean multiple pages of modules? I don’t see how this would help with configuring two monitors. Are you showing different pages on different displays?
          @Joshrobbs1 The Raspberry Pi will not support a second monitor out of the box. It is possible to support a second monitor on the RPi, but it will require additional hardware and a different flavour of Linux: See here You could also look for an old laptop that already supports dual monitors, which may be easier and give your setup much more memory and processing power.
          Even if you run two separate computers, you may decide to have them run off of a single MM server (think RPi3b with MM install, and an RPi0W that connects to it). Have a look at this tread here. Because their index.html codeblock is empty, I think @Alvinger used code (something like) this:
          document.documentBody.setAttribute('data-useragent', navigator.userAgent);
          Anyhow, this solution can be used regardless of whether the monitors are connected to the same computer, if you simply want to avoid running a separate instances of MM on each computer. This way you can decide which modules appear on each of your displays simply by using two different browsers.
          Problem with config or JavaScript? Copy/paste it into JSHint.
          Check out the detailed walkthroughs on install, config, modules, etc.
            Mykle1 Project Sponsor Module Developer @ninjabreadman
            @ninjabreadman said in Multiple screens fo MM.:
            I didn’t say a word. Robert mentioned Hello-Lucy, not me. :-/
            • N Offline
              ninjabreadman @Mykle1
              @Mykle1 I know, but I figured as the author of MMM-Hello-Lucy you might be able to explain how (and if) it could help (because it wasn’t apparent to me). I only meant to mention you so that you got a notification; it definitely wasn’t meant to be accusatory.
              • cowboysdudeC Offline
                cowboysdude Module Developer
                I know about dueling banjos… don’t think that’ll help LOL
                  @ninjabreadman
                  Heh, no worries ninja. :-)
                  Now, as far as the dual monitor setup is concerned, I think it’s asking a little too much from the Pi, which struggles under some ordinary circumstances
                  • tbbearT Offline
                    OOOO sorryyyy i didnt want a fight it was a misunderstanding my English :-(
                    I thought he wants multiple pages on ONE screen
                    my fault
                    sorry…
                    Robert the Bear
                      Joshrobbs1
                      Yes I️ guess what I️ meant wast different modules showing on different screens at the same time. For instance on the left monitor I️ would put time & date, & on a right monitor on the opposite side of the mirror I️ would have my weather etc. keeping all the info on the outer edges of a large 60”w x 36” H mirror. My idea is to run two monitors vertical on each side.
                      Mykle1M N 2 Replies Last reply Reply Quote 0
                        Mykle1 Project Sponsor Module Developer @tbbear
                        @tbbear said in Multiple screens fo MM.:
                        haha, there’s no fight. Everything is cool. Me, you, ninja, we’re all one happy forum family. :-)
                          Mykle1 Project Sponsor Module Developer @Joshrobbs1
                          @Joshrobbs1 said in Multiple screens fo MM.:
                          I like the idea a lot. Please keep us posted. i am curious as to whether you experience any performance issues.
                          • N Offline
                            ninjabreadman @Joshrobbs1
                            @Joshrobbs1 Two monitors on each side, or one each/two total? You could run two completely separate mirror instances, or one instance (i.e. server) and hide the modules (via CSS) you don’t want displayed on each one.
                            I suggest using a Raspberry Pi Zero W to power one display, run a browser and connect to the other instance/server (or run an MM instance on the RPi Zero W). The server could be on a more powerful Raspberry Pi (3b) or some old laptop hardware. You would want to run the simpler, static modules (weather, time, calendar) on the RPi Zero W and the more demanding, processor-intensive modules (voice, video feeds, complex rendering) on the server.
                            I don’t know how MM feels about running two instances on the same machine – you’d need to set different ports, scripts, etc, but I imagine it’s possible with some reconfiguration to avoid collisions.
                            • H Offline
                              hogedir @ninjabreadman
                              @ninjabreadman Hi,
                              Now we have a rpi4B with 2 screens available, and i want to display on 2 screens the magic mirror.
                              is it possible with the version 2.20 ?
                              kayakbabeK S 2 Replies Last reply Reply Quote 0
                              • kayakbabeK Offline
                                kayakbabe @hogedir
                                @hogedir With a raspberry 4 you can have two displays. I’m thinking they can be set up as an extended desktop . Then it’s no big deal with the default magic mirror.
                                Top_left and top_right would end up being left and right…
                                I haven’t tried this with MM. But I have used my pi with two screens. But in my mind it ought to work with MM.
                                Just don’t use the middle_center or any position that would span across both monitors.
                                • H Offline
                                  hogedir @kayakbabe
                                  @kayakbabe I think we need two electron display, so it’s not quite easy. it’s not just top_left and top_right. I need 2 MMM, 1 magic mirror per screen.
                                    sdetweil @hogedir
                                    @hogedir electron (and other browsers) runs maximized, which is only one screen…
                                    you can DRAG the edge to make the window larger, but cannot maximize over two screens…
                                    you can run separate instances of MM on each display…
                                    • BKeyportB Offline
                                      BKeyport Module Developer @hogedir
                                      @hogedir I had two running off one display, just two different Magicmirror installs. I forgot how it works though, was using them as a temporary menu display.
                                      Something about calling different config files if I recall right.
                                      S K 2 Replies Last reply Reply Quote 0
                                        sdetweil @BKeyport
                                        @BKeyport MM_CONFIG environment variable
                                        allows the different configs off the same directory tree
                                        • K Offline
                                          karam @BKeyport
                                          @BKeyport this answer inspired me to test it, so I have a solution:
                                          1. create two different folders.
                                          2. configure each install as you like.
                                          3. edit each electron file in each folder “js/electron.js”
                                          4. change the default resolution and position based on your screens.
                                            here is my config:
                                          let electronOptionsDefaults = {
                                                          width: 1280,
                                                          height: 1024,
                                                          x: 1366,
                                                          y: 0,
                                          NOTE: there are many better methods (electron-multi-monitor for example) but this is the easiest that I could find
                                            sdetweil @karam
                                            @karam u can set the electronOptions in config.js, you don’t need to edit the source file
                                            then you can do it with one folder,
                                            and two config files
                                            MM_CONFIG=config1.js
                                            for one
                                            and
                                            MM_CONFIG=config2.js
                                            for the other
                                            all modules for both are installed in modules folder, only ones referenced in config file are used
                                            installers/mm.sh is the script used by my pm2 setup routine
                                            copy that to mm2.sh
                                            and then add the export MM_CONFIG=
                                            to each
                                            then copy the pm2_magicmirror.json
                                            and change the title and the mm.sh filename
                                            then pm2 start installers/??? (whatever name u copied the json file to for the second mm)
                                            pm2 save
                                            then on reboot you will get both
                                            C S 2 Replies Last reply Reply Quote 1
