    Small 'Picture frame' MagicMirror (first attempt)
    15 inchpicture framemagicmirrothin
    13 Posts 6 Posters 14.4k Views 6 Watching
    • Robert_KR
      Robert_K
      Scrolling down on Pintrest a Magic Mirror got my interest. After a small conversation at home we decided to first make a small one. When we like it, we could build a bigger one later on.
      So a old 15.6” laptop would provide me with a small ‘picture frame size’ screen. A Raspberry Pi (3) was found on a national trading website (www.marktplaats.nl). Only the electronic parts remained, so Ebay/BangGood/Aliexpress served me well.
      The RPI was in first so I could start programming right away. I have an electrical background, so programming wasn’t the easiest thing to do. Then again I must say there is a lot documented, which was a huge help. After a friend showed me to use PuTTY and WinSCP it all went a lot easier.
      I wanted to make a small and clean mirror with a frame made out of wood, yet thin. I made most of my furniture at home, so wood would fit in quite easy. Also I wanted to have no cables other than the power cable.
      Parts used:
      • Rasperry Pi3 – Model B
      • 230V -> 12V – 3A AC-DC converter
      • 12V -> 5V – 5A DC-DC converter
      • HC-SR510 PIR-Sensor
      • 15cm HDMI cable
      • HDMI – LCD Controller board
      • 3mm thick two-way mirror acrylic
      Build Process:
      Programming
      Made a wooden frame. 120cm x 31cm x 5cm - beam is 2cm thick
      It does shimmer like crazy
      I had to change the PIR sensor to make it fit in the 5cm high, 2cm thick frame. Soldered the sensor off and put some wires in between
      Finished product: “the mirror”. Quit small. Not quite sure if we let it ‘sit’ there or we will hang it.
      Finished product: “the magic”. Doesn’t shimmer that much, but that’s due to the mobile phone pic by night and low light.
      Finished product: “the brains”. Made an acrylic top plate. Doesn’t do anything more than looking nice.
      Best Regards,
      Robert
      Mykle1M 2 Replies Last reply
      Reply Quote 4
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Robert_K
        @Robert_K
        Very nice work! And the neatest I’ve ever seen. :-)
        Reply Quote 1
        • Mykle1M
          @Robert_K said in Small ‘Picture frame’ MagicMirror (first attempt):
          The acrylic top plate does look nice, giving it a professional, finished look. One suggestion, and this is just one old man’s opinion. Keep an eye on the temperature, now that you’ve closed the back of the frame.
          Robert_KR 1 Reply Last reply
          Reply Quote 2
          • michael24hM
            michael24h
            Nice work, I did something very similar. Using apple first gen iPad screen :-)
            MY CLOCK
            MY 10" inch MagicMirror
            0_1519688876538_magicmirror front.jpg 0_1519688885110_Game Boy Color.jpeg 0_1519688891927_Gunship screenshot.jpeg
            Reply Quote 1
            • emloweE
              emlowe Module Developer
              I like what you did with the power, nice and clean. FYI, a number of the LCD driver boards have 5v outputs and I’ve successfully powered an rpi3 from the output from the board itself.
              (http://www.panelook.com/upload/201511/MNT686762A_12516-Specification_A2_(1)_201511187301.pdf)
              Supplies 5v on the CN3 pins (probably headless on the board, but 5v is there)
              This guy says it’s good up to 1.5 amps (https://www.raspberrypi.org/forums/viewtopic.php?t=67312)
              I wired it to a USB cable rather than directly to the GPIO
              -Earle
              • michael24hM
                michael24h
                The Raspberry Pi 3 is powered by a +5.1V and 2.5A
                small lcd screen takes about 3.3v.
                Reply Quote 1
                • Robert_KR
                  Robert_K @Mykle1
                  @Mykle1 said in Small ‘Picture frame’ MagicMirror (first attempt):
                  I’ve been thinking about that too. So I started with a closed plate, monitored the temperature and was thinking about making ventilator holes. Then again the temperature isn’t raising above 40degC. So I think it will be okay. I’ll keep it in mind with a hot summer day, thanks!
                  Regards Robert
                  michael24hM 1 Reply Last reply
                  • E
                    E3V3A
                    Wow, beautiful inside!
                    How did you make the cables stay so nicely squared? With hot-glue?
                    “Everything I do (here) is for free – altruism is the way!”
                    MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
                    Robert_KR michael24hM 2 Replies Last reply
                    • Robert_KR
                      Robert_K @E3V3A
                      @E3V3A said in Small ‘Picture frame’ MagicMirror (first attempt):
                      Yes, hot glue indeed.
                      Regards Robert
                      • michael24hM
                        michael24h @Robert_K
                        @Robert_K
                        leave back of mirror open.that will help
                        • michael24hM
                          michael24h @E3V3A
                          @E3V3A
                          In my mm-clock, all 3d printed. No hot glue.
                          • LupearnL
                            Lupearn
                            For me when I started to decorate my house it was very important to have original and matching picture frames.
                            LupearnL 1 Reply Last reply
                            • LupearnL
                              Lupearn @Lupearn
                              @lupearn hmm
                              • Robert_KR Robert_K referenced this topic on
