    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 47.9k Views 10 Watching
    • C Offline
      Cyberwrights
      v6.12.3
      Not working
      btw that command if anyone else needs to look it up is just
      $ node -v
      MMM-GoogleAssistant
      MMM-Hue
      MMM-MyCommute
      MMM-Formula1
      MMM-SystemStats
      MMM-moon-phases
      C 1 Reply Last reply Reply Quote 1
      • C Offline
        Charley Module Developer
        I am on v6.12.3
        And not working when I update npm install
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
        • C Offline
          Cyberwrights @chef
          @chef said in So ... to update MagicMirror I would ... ??:
          Perhaps try stopping all instances of electron and node.
          Stop pm2
          Then try the install again.
          Reboot the Pi.
          Tried this, same result. Blank mirror although pm2 reports it is online.
          MMM-GoogleAssistant
          MMM-Hue
          MMM-MyCommute
          MMM-Formula1
          MMM-SystemStats
          MMM-moon-phases
          • C Offline
            chef
            Working on node version 6.13.1
            I think I can see where this is going… The blank screen is the mirror running, but there could be an issue with loading the page data? …
            • C Offline
              chef @Cyberwrights
              @Cyberwrights said in So ... to update MagicMirror I would ... ??:
              v6.12.3
              Not working
              $ node -v
              @Cyberwrights thanks for that … I just used ‘dpkg -l | grep ii | less’, and that took forever to find node … lol
              • MichMichM Offline
                MichMich
                My first thought there is an issue with electron. Looking into it.
                • MichMichM Offline
                  MichMich
                  Could someone try the following in the MagicMirror folder:
                  npm install electron@1.4.15
                  If this works, please state your Node version as well. (node -v)
                  • H Offline
                    Harry @MichMich
                    @MichMich said in So ... to update MagicMirror I would ... ??:
                    pi@ham-raspi:~/MagicMirror $ npm install electron@1.4.15
                    electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                    node install.js
                    • @types/node@8.10.1 node_modules/@types/node
                      magicmirror@2.3.0 /home/pi/MagicMirror
                      └── electron@1.4.15 invalid
                    Node v6.12.3
                    • MichMichM Offline
                      MichMich
                      Uhhmm… thats odd. It’s just a command to downgrade electron.
                      • MichMichM Offline
                        MichMich
                        It seems to fix the issue for others. Not sure why you are unable to downgrade electron.
                        https://github.com/MichMich/MagicMirror/issues/1243
                        Could you reboot and try again @harry?
                        H C 2 Replies Last reply Reply Quote 1
                        • H Offline
                          Harry @MichMich
                          Yep. Reboot helped.
                          Rebooted, stopped MagicMirror and then the downgrade worked.
                          MagicMirror is up and running again!
                          Thanks a lot!
                          • C Offline
                            chef @MichMich
                            @MichMich well-done.
                              Montanaro
                              Solution in this thread https://github.com/MichMich/MagicMirror/issues/1243
                              in MagicMirror Folder
                              • E Offline
                                E3V3A @NoNameRo
                                @NoNameRo
                                You guys should probaly do pm2 stop mm; pm2 kill to make sure it’s not running in the background.
                                Also, AFAIK, I think if you do git reset --hard you’d loose all your old config settings and other changes you’ve made?
                                "Everything I do (here) is for free – altruism is the way!"
                                MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
                                MichMichM 1 Reply Last reply Reply Quote 1
                                • MichMichM Offline
                                  MichMich @E3V3A
                                  @E3V3A The Config & Modules folder are not part of the Git repro. All other changes are overwritten.
                                  • MichMichM Offline
                                    MichMich
                                    I’ve released an update: https://github.com/MichMich/MagicMirror/releases/tag/v2.3.1
                                    • E Offline
                                      E3V3A
                                      Just to say it…
                                      It seem that many people having problems, are running something out dated.
                                      Either: nodejs, npm, or pm2.
                                      Because of the incredible dependency chain involved for node packages, I can only assume that using a newer versions of one package, will also require a newer version of the package depending on it, and possibly vice versa. Of course when things are working, it all beautiful, but it seem very easy that it doesn’t.
                                      • C Offline
                                        Just updated the new repo.
                                        It’s alive again.
                                        Thanks great job
                                        • C Offline
                                          chef @MichMich
                                          @MichMich Thanks very much for the easter gift!
                                            Richard238
                                            Installed MM2.3.1, still got black screen
                                            Installed earlier version electron, still got black screen.
                                            Shutdown and restarted.
                                            Now nothing on :8080 either :(
                                            MichMichM S 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
