    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 247.8k Views 33 Watching
      Mykle1 Project Sponsor Module Developer @slametps
      @slametps Yes, at first the same thing happened to me.
      This might seem obvious but did you change your config.js to ipAddress instead of macAddress?
      slametpsS 1 Reply Last reply Reply Quote 0
      • slametpsS Offline
        slametps @Mykle1
        @Mykle1
        @Mykle1 said in MMM-NetworkScanner:
        I add new entries with ipAddress, but did not recognized. All displayed MAC (with showUnknown: true) already defined as entries with macAddress, but it said as Unknown devices.
        regards,
        Slamet PS
        • I Offline
          ianperrin
          Hi all
          The updates last week seem to have introduced a few issues - sorry folks!
          I’ve quashed one bug with MAC Address scans which you can git pull from the repo to see if that helps, but there still appear to be a few others which need resolving.
          I am looking at it but please bear with me ;)
          “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
          Mykle1M P 2 Replies Last reply Reply Quote 2
            Mykle1 Project Sponsor Module Developer @ianperrin
            @ianperrin said in MMM-NetworkScanner:
            Shhhhh! Quiet! Genius at work!
            I am completely serious. I think you are a brilliant young man.
            Much success to you. :thumbsup_tone1:
            • P Offline
              pugsly @ianperrin
              @ianperrin
              Yup good work on getting the updates…
              MAC is working again, but the entries are all duplicated. ;)
                Speedy-one @pugsly
                @pugsly same here -.-
                • slametpsS Offline
                  slametps @Speedy-one
                  @Speedy-one said in MMM-NetworkScanner:
                  I freshly install rather than update the module, and working flawlessly.
                  regards,
                  Slamet PS
                  • P Offline
                    pugsly @slametps
                    @slametps Deleted the module and did a fresh install, still showing duplicate entries.
                    • slametpsS Offline
                      slametps @pugsly
                      @pugsly said in MMM-NetworkScanner:
                      Lucky me. Btw, had you installed v0.0.1?
                      regards,
                      Slamet PS
                      • P Offline
                        pugsly @slametps
                        @slametps Yes i did, and that one worked fine using MAC. I have actually reverted back to that one, so I don’t get the ‘last seen’ message anymore.
                          bluedoors
                          Any chance of an enhancement to scan outside the local network mask? i’m not sure if that is a config option in arp-scan that isn’t surfaced?
                          I have my MM on ethernet in one subnet, but want to scan for MAC addresses in another subnet (my Wifi). or at least a broader CIDR range
                            bminer1
                            Does anyone have issues with the “occupied” and “vacant” part working? I tried to set it up and test it but i have had no luck. I want the mirror to turn off when i leave and turn back on when i return. I love this idea but need a little help configuring it to work.
                            My config is below:
                            	        module: 'MMM-NetworkScanner',
                            	        position: 'top_right',
                            		header: "Network Scanner",
                            	            devices: [
                            	                    { macAddress: "lower case", name: "B Phone", icon: "mobile"},
                            	                    { macAddress: "lower case", name: "B Work Phone", icon: "mobile"},
                            			    { macAddress: "lower case", name: "B Work Laptop", icon: "laptop"},
                            	            showUnknown: false,
                            	            showOffline: true,
                            	            keepAlive: 300,
                            	            updateInterval: 10,
                            		    showLastSeen: true,
                            	            residents: "B Phone",
                            	            occupiedCMD: {notification: 'REMOTE_ACTION', payload: {action: 'MONITORON'}},
                            	            vacantCMD  : {notification: 'REMOTE_ACTION', payload: {action: 'MONITOROFF'}},
                            B I 2 Replies Last reply Reply Quote 0
                              bminer1
                              I am also getting duplicates as well. Any help on this?
                              alt text
                                derek7467 @bluedoors
                                @bluedoors modify the js file to scan your subnets? If your subnets were 192.168.1.0/24 and 192.168.2.0/24 you could scan 192.168.1.0/23 to scan both subnets, right? Same gateway for both subnets?
                                  binderth @bminer1
                                  @bminer1 said in MMM-NetworkScanner:
                                  Ah, nice: Is this doing, what I suspect it’s doing? ;)
                                  occupiedCMD: Notification to be sent when a resident returnes home e.g. {notification: ‘REMOTE_ACTION’, payload: {action: ‘MONITORON’}} would turn the mirror on when a resedent returnes home.
                                  What does “returnes home” mean: Changing from “offline” to “online”: trigger the action (vice versa for vacantCMD). It does only trigger once? Would it be possible to call an external URL with this? - and then: does it trigger if any resident leaves or can I specify which resident leaves?
                                    bminer1 @binderth
                                    @binderth I tried testing it by turning my WiFi off on my phone, waiting a few minutes to see if it turns off and it doesn’t turn off. I even physically left the house for dinner and came home to it still on. I love the feature and would do almost anything to get it to work. I’m new to all this stuff so i don’t have the skill to debug on my own.
                                      binderth @bminer1
                                      @bminer1 yes, this is nice! would be killer, if it were to be configured per device! ;) it seems from the way in the config, it was intended to fire regardless of which device leaves or comes up again…
                                        bminer1 @binderth
                                        @binderth When i read through the Read ME, it says that the Residence determines when to turn on and off. I want this to work for me so then i can put my wifes phone in there as a resident and that way, when both of us leave, it shuts off. when one of us is home, it stays on.
                                          binderth @bminer1
                                          @bminer1 ah. ok, I get it (didn’t have “residents” in my config either). So, this one is realy “every resident is offline”: i do something. “At least one resident is online again”: i do something. So this would then be a generic presence detection.
                                          Would be cool, if it could also be bound to specific residents. So I can have Actions regarding on them also.
                                            bminer1 @binderth
                                            @binderth I think you are on a right track. We just need to debug the “simple” task of turning on and off and then the fun can begin with other stuff.
                                            • 6
                                            • 3 / 6
